Any remote telescope service with camera rotation as an option for framing?
3 replies342 views
Steeve Body avatar
I’ve got a project that I’d like to complete which would require shooting at many different focal length… from 50mm to 4000mm I’m looking at remote telescope options for the deep field acquisition part.. problem is that I have not been able to find a one letting you select rotation angle as an option for framing. Can anyone point me in the right direction?
Kind regards,
Steeve
Ed Dixon avatar
I think your main choices there will be wider field views and cropping after the fact.  Many of these systems are quite high res so you may have some flexibility.
Torsten Mueller avatar
Hi Steeve,
i dont think that field rotation is avail with the commercial remote observatories. Except, of course, with the big altaz telescopes. But then for a different reason.
The point is, you will not be able to get flats after your session to calibrate your image. These frames are normally taken by the hosts of the telescope.
So as Ed wrote, the best way would be to rotate & crop smile
Torsten
Steeve Body avatar
thanks for the reply folks. I actually have a rotator on my rig, and even though I do new flats every time I change angle I have noticed that my dust donuts are just not moving… and they have not in months… so I’m assuming that’s because they are on the flattener side pre rotator and not the filters/camera side. I understand how rotators can be a reliability issue with quality data / flats from these type of services… but I’m somewhat surprise that literally none offer the option… even for an additional fee…
Preparing for comet aquisition - need some advice
Hi to the community, lately I tried for the first time to get some images of a comet with a guided sope. Although I was kind of successful, there are some questions that arised. There are a lot of processing tips out there, but the process of data aq...
Remote telescope acquisition for comet imaging may involve rotation angle framing needs.
Feb 16, 2024
Nexstar 6se tracking
Hello, when I first got my nexstar 6se i started out with planets and stuff which was fun, but my goal was to do deep sky astrophotography. Now I've got a camera(im upgrading to a newer one) but I have 1 problem. Everytime I find an object I want...
Nexstar telescope tracking relevant to remote telescope operation and deep sky imaging.
Dec 17, 2023
