Hi there,
If you ordered the Starizona filter drawer for Hyperstar, that should have come with the standard adapter for proper back-spacing. Direct from the manufacturer, the back focus for Hyperstar 8 v4 from the mounting thread to focal plane is 39.8mm. See this site:
https://starizona.com/blogs/tutorials/hyperstar-specificationsThe critical focus zone on Hyperstar is *really* small (l think on the order of microns), so I only ever used the spacers directly from Starizona. The only filters I had ever used with my Hyperstar were the Optolong L-eNhance and the Baader f/2 Ultra-highspeed SHO set. Those all worked fine. The Baader set was 2mm and the L-eNhance was 1.85mm. Those also worked with the Hyperstar because the L-eNhance had wide bandpass so the bandpass shift from f/2 didn't matter, and the Baader set theoretically are pre-shifted to account for the bandpass shift. I'm not certain whether the bandpass shift would translate into change in star shape though.
If you are using standard Starizona filter drawer and their spacer, did you try recollimating the Hyperstar? I would do that first and then use something like CCD Inspector or ASTAP to check for tilt. Even the slightest tilt on Hyperstar will throw everything off. Lastly, are you certain you aren't dealing with a funky-looking diffraction spike from how you have your cables managed in front of the corrector plate? I tended to keep mine at 90 degree angles to get a nice cross-shaped diffraction pattern, but others have advocated for semicircular approach to cable management to avoid spikes altogether.
Clear skies,
Ben
