Which System would you choose:
Multiple choice poll 33 votes
27% (9 votes)
73% (24 votes)
Andrewrckt avatar
TL;DR:
Basically, I am looking trying to figure out how to stretch my budget of about $3500 for a telescope in looking between Redcat 71 with additional equipment OR just an Esprit 100ED.
To start, I have been using my Canon R6 camera, with a 24-105mm L series Canon Lens on a Move Shoot Move star tracker.  I have had some decent results, however, I feel quite limited by what I can do with this setup (despite Milky Way season approaching).
I would like to start to capture some more deep space objects on a more robust mount.  I have chosen the EQ6-R pro mount as my star tracker mount, as it has great reviews and it seems as though it will allow me to grow with it with larger payloads (not included in the $3500 budget).
Now for the payload question.  I am looking at the RedCat 71 telescope or the Esprit 100.  Basically what conflicts with me at the moment is in regard to what I should buy.  I know they are two different setups at different focal lengths and likely capture different areas, but I would like to just have a starting system and I have heard great reviews on both these telescopes.  Now, the idea would be to buy a Redcat 71 and other equipment (Filters, ASI Air Pro), or just an ESPRIT 100, use my Canon R6 and slowly add equipment over a few years.  I will eventually replace the Canon R6 in the imaging train for a Monochrome Dedicated Camera, but that isn't in the budget this year.
Any advice would be appreciated as I make this journey into astrophotography.  FYI:  I live in a Bortle Class 4 area, Boston, MA suburbs.
kuechlew avatar
Hi, don't miss out on the Perseid and Geminid meteor showers with your current gear.
I would go for the ESPRIT 100 and add the automation part later on. With the EQ6-R you have a capable goto mount. I believe the ESPRIT 100 will provide you with a larger variety of objects to aim at. Looks like a wide field equipment which can provide a lot of fun in the upcoming season. I assume you need an additional field flattener. for your full-frame camera.
Clear skies
Wolfgang
Andrewrckt avatar
Hi Wolfgang,
Yes, with the ESPRIT 100ED, I would need a field flattener, but I believe that is included in the telescope accessories: 8x50 RACI.  Unsure if I will need anything else, but I would purchase any necessary accessory to get the telescope to be compatible with the R6.  Thanks for that suggestion!!!
Clear skies,
Andrewrckt
Björn Arnold avatar
Let me chime in with a broader reply here as recently people have more frequently asked „which equipment?“ questions.
There’s a variety of things to consider and especially to learn when one starts with astrophotography.
Sometimes it’s easier to say don’t use this because of X or Y…
The RedCat71 is a fully corrected system while for the Esprit, you need to buy an additional corrector. The RC71 will certainly give you a lot of fun for wide field.
For galaxies, a light bucket might be better, i.e. a reflector of 8“ or more aperture. At least many people take this approach.
From a technical point of view, the Esprit is a classical refractor design (w.r.t. focusing etc.) and so there’s a larger variety of auto focusers for example.
In addition, I am not sure if the RC71 can be used for solar imaging since I don’t know if the corrector is removable. The Esprit would be the better choice for solar imaging. (Assuming that you wouldn’t use an objective filter. For that topic, I should emphasize that one should know what one‘s doing - for your and your equipments safety)
As you can see: the choice depends on your needs.
Both systems are of very good quality and many great images were taken with either.
Björn
Andrewrckt avatar
Björn Arnold:
Björn
Thank you for that response.  I have thought about expanding to solar imaging in the future.  Part of the push for buying this rig now will be for the upcoming solar eclipse in 2024 as I am in New England and planning to travel to VT or NH for the event!  Didnt realize the Redcat many not be appropriate for this application.
I am most definitely leaning toward the Esprit 100 over the Redcat due to the capabilities of the scope.  I know both are capable though, but also curious, would you rather spend all your budget up front this year on the scope alone or the scope and some practical accessories.  I am thinking placing all the budget on the scope and slowly buying accessories for the imaging train would be better rather than buying a "cheaper" scope (in the sense of budget, not quality) and accessories to start.
Respectful
Rouven Spaar avatar
Personally, I have this scope:
Teleskop-Express: TS-Optics 70 mm f/5 Quadruplet Flatfield Apo with 3-Element FPL53 Objective
I am very happy with it, it has the same specs like the redcat, you can put a autofocuser on it and it is half of the price of the redcat. I'm not 100% shure about it but I think it has the exact same objective like the redcat and meade. You can save up the 1000 Dollars from the redcat for your dedicated Astro camera, if you don't decide to go for the Esprit.
Clear skies
Björn Arnold avatar
Hi Wolfgang,
Clear skies,
Andrewrckt
The 8x50 is the finder scope. You‘ll have to put the corrector on top.
Andrewrckt avatar
Björn Arnold:
Hi Wolfgang,
Clear skies,
Andrewrckt
Thanks for that correction!  As you can tell, newbie...my only experience stems from DSLRs and star trackers, but diving deep into the rabbit hole.
Andrewrckt avatar
Clear skies
I will take a look at it!  Thanks for the suggestion.  One issue I have with the hobby getting started is the shear number of options out there.  It is a pro and a con at the same time!
Björn Arnold avatar
If you have solar imaging in mind, I strongly recommend to read more about it in the beginning. There are different goals which require different hardware and you may even end up at the point to purchase a dedicated solar scope.
My solar imaging isn’t focusing on the helioshpere and hence I can live with a „cheap“ Herschel wedge and a few filters. Haven’t thought about solar eclipses but the heliosphere is likely the major part of it and you‘ll need an Etalon to capture this signal. (@experts: please chime in if I start talking nonsense but I just want to emphasize that you might invest 1000$+ to make your scope solar eclipse fit or purchase a dedicated solar scope).
CS, Björn
Concise Supportive
Andrewrckt avatar
Björn Arnold:
CS, Björn
Thanks!  I think that is part of the reason why I want to start this process of purchasing equipment now.  I know my main focus will be on DSO rather than solar, but the solar eclipse definitely peaks my interest as an event I would like to capture.  I am okay with $1000 investment over the next 2 years to get that image in the future.  I think for now, I am looking for a versitile scope that I can utilize in this hobby and continue to learn and grow.  That is the ultimate goal getting into this is the continual progression of growing and learning a new skill.
Andy Wray avatar
Errm  . my wfe gave me a Skywatcher 200 PDS newtonian as a beginner scope on an HEQ5 Pro mount.  It's actually been a great way to get into the hobby and relatively inexpensive.  Looking back, the Skywatcher 150PDS on the EQ6R Pro may have been a more general OTA (better wide field of view) supported by a mount that would have no issues coping with it.
Björn Arnold:
Heliosphere? We are in the middle of it!
If you were thinking of the chromosphere you would be in part right. However, in dealing with a full solar eclipse you'd not need any of those etalons or in fact any solar filter at all. Standard equipment would suffice.
Ed Dixon avatar
To do anything at night, you will need a few things.  This includes a good mount, reasonable refractor scope, quality astro camera, finder scope, software,  and a laptop or miniPC at scope to control things.  Things tend to go further after you get these.  Reasonable mounts are 1K and up and similar for reasonable reflectors.  Guide scope and camera is maybe 200-400.   If you go the Pixinsight route, that's about 250.  Good astro cameras start at 1K (cooled) and up.  Laptop/MiniPC starts at about 300.  It adds up pretty fast.
One option is to start smaller at first.  Get a good refractor and use it with your rotator mount.  iOptron also has a the SkyGuider Pro package for about 500.  Get a good astro camera and use that combo for 6 months.  Then branch out after you get more experience.  Slower at first for most is a good concept… crawl before you walk, walk before you run…
Andrewrckt avatar
Ed Dixon:
Thanks for those tips!  Starting I have a L series Canon Lense with a Canon R6 (mirrorless full frame) attached to it.  I have a Move Shoot Move star tracker on a sturdy mount, so been capturing wide-field astro for about 2 years now.  I have a subscription to Adobe Photoshop where I do my imagery processing along with Luminar AI and do this all on my laptop.  I have been stacking all my imagery in Deep Sky Stacker and am getting more comfortable with the imagery processing.
The reason why I consider myself a newbie is mainly because I have been using my photography gear for astro which I collect mainly for landscape photography.  I havent dived into a dedicated telescope yet, so just want to make sure when I make this transition, the telescope is something I can grow into rather than start too slow.  I am one that loves to struggle greatly at first as that is a huge motivator for me to keep digging deeper into a topic.
For a guide scope I am looking at the ASI120MM Mini on a WO 50mm guiding scope.  Mount I am upgrading to the EQ6-R Pro.  I am debating about either getting the ASI Air Pro Controller, but will likely start by installing Astroberry on one of my raspberry pi computing systems I have laying around the house (I have 2 - 8GB Raspi 4's laying idle right now).
For the camera, I want to start with my Canon R6 at first but will want to upgrade to a monochrome camera, filter wheel, and filter system to record individual bands.  I am a meteorologist that does a ton of satellite meteorology, so used to wavelength filtering and banding, just in reverse (looking at earth rather than looking up).
One other reason to get the telescope right is the wife wont likely let me buy multiple telescopes in back-to-back years, but accessories are easier to explain (haha)...just hide them in her Amazon orders.
Thanks again and Clear Skies!
Andy Wray avatar
Given what you just said, I am going to suggest that you focus on field of view.  i.e. what is it that you want to capture for the next couple of years?  Galaxies,  nebula, wild field or some combination of a couple of those.  FOV is obviously a combination of the OTA, the camera sensor and any coma corrector/field reducer that you may use.  There are many tools on-line where you can enter the details and see the FOV or just use stellarium.
Ref the EQ6R Pro mount choice:  I think that's great as it will last you for years.  My wife gave me the HEQ5 Pro when she started me on this journey and it is just a tad difficult to get right with a heavy load.
On the control computer side of things:  I opted for a Windows 11 miniPC that runs APT, SharpCap and PHD2 fine and that works fine with NINA too.  The ASIAir is great, but a bit of a locked-in system.  My windows mini PC did cost me £230 which is way more than the PI, but I'm very happy with it.
Andrewrckt avatar
Andy Wray:
Very good ideas here.  I have been using blackwater skies to try and figure out the FOV based on the different systems I am looking at.  I think with all these suggestions I am going to go with the Skywatcher 100ED as I can use a 0.7 reducer to get some wider field shots, while still having the ability to use the full reach of the 550mm focal length if needed.
The dedicated computer system sounds tempting to me as well.  I will explore both options.  I have played with APT a little bit, but excited to play with it more as I dive further into this hobby.
Andrew
kuechlew avatar
Andy Wray:
Andrew
For setting up an own mini pc you may be interested in this playlist (with more videos to come up): https://www.youtube.com/watch?v=ejXiAW_nAeA&list=PLvMGHP27Lbqf_DkFkR_0Dy-vTBK7FTxfh
I had so far little but good experience with NINA while I didn't manage to get a robust setup based on Stellarmate and a raspberry PI. Others seem to have no issues with this though.
Clear skies
Wolfgang
Michael Ring avatar
EQ6-R is a solid choice, for Telescopes I think the Esprit gives you a lot of options to keep you busy overthrew next few years. Besides guiding I‘d highly recommend to already now buy an autofocusser as it will save you from a lot of nearly sharp shots and you can easily automate focusing every hour over a long winter night.
I would not go for ASI Air as you are locked in into the Zwo Ecosystem.
You will start feeling that pain when shopping for a mono camera, you can save a lot by buying a no-name mono camera instead of the Zwo camera.
Matt Moring avatar
Reading through this I think you could potentially get a lot of bang for you buck with an Heq5pro. I would pick one up 2nd hand and fit new bearings. Easily done and about £50 for the bearing kit here in UK. Adding a rowan belt mod would give you a capable mount. I would look at an Astro camera such as the zwo 533 £800 (good for planetary and DSO imaging). Add a Skywatcher 130PDS reflector giving you 650mm focal length and will balance perfectly fine on an HEQ5PRO. Cost is about £250 for this amazingly underrated reflector. Add an asi air plus, guide scope and guide camera for another £500. That would enable you to get a complete semi portable rig, dedicated camera, guiding and tablet based goto system with enough change to add an l-extreme filter for nebula photos. Good luck with your journey.
Michael Ring avatar
I took that route, started with a HEQ-5 and I must say it is a capable mount but also limiting because it cannot handle well longer scopes and some very interesting telescopes that are in the 8 to 12kg class.
So in the end I spent double and upgraded to the EQ6-R, I wished I would have started with an EQ6-R in the first place.
Helpful Insightful Respectful
Roger Nichol avatar
I highly recommend the Esprit 100ED on the EQ6-R - this was my first and current scope and would be what I chose again if starting out again.
I have automated almost everything apart from camera rotation, but you can do this gradually. I paired it with an ASI2600MC, filter wheel for dual narroband and LP filters, Sesto Senso 2 autofocuser (this is a game-changer and I would highly recommend), ZWO OAG with an ASi120mm-mini (the OAG works really well and leaves space on top of the scope to mount a mini-PC with Pegasus Pocket Powerbox Adv.
Picture below might help:
Andrewrckt avatar
Roger Nichol:
This image helps out a lot.  It is very similar to how I envisioned my set up in the future.  I am going to start with the R6 to start but eventually switch over to dedicated cooler camera system.
Ed Dixon avatar
As a snapshot of gear and costs, here is what I use for most of my DSO imaging:
AVX mount 800
William Optics GT71 1100
ZWO EAF focuser 200
ZWO 30mm guide scope 100
ZWO 120mm-S guide camera 180
ZWO ASI294MC Pro Camera 1000
AData 1TB SSD and enclosure 120
Camera cooler power supply 50
Intel NUC miniPC 500Wifi module for communication for inside display/control 50
Total 4100
 I have 3 other ZWO cameras I also use at different times (ASI174MM, ASI224MC, ASI485MC) as well as a Nikon D780.  I have three other scopes I also use at times… Celestron 8SE, Celestron C6N, and William Optics Z71.  I also have solar imaging gear that is added to the WO GT71.
This does not include things like cables, cases, chairs, tables, lights, and other misc accessories.  It adds up pretty fast.
Solar Photography during the Solar Eclipse *recommendations needed*
Hello, I've got an itch to purchase a solar-dedicated telescope for the April event in the US. I've got my bases covered with the equipment for the photographing of the actual eclipse (RedCat 51 + Canon 5D Mark IV Camera, Canon 100-500 RF Len...
Not relevant; focuses on solar eclipse photography, not deep space objects.
Feb 6, 2024
ADM Vixen vs ADM Losmandy for C8 ?
Hey all, hoping to get some advice. I have my Redcat 71 currently sitting on my AM5. I am looking to put my C8 on and swap between the 2. I was wondering what dovetail bar I should get. I know the C8 isn’t technically “heavy” but I’m unsure if when f...
Relevant; discusses Redcat 71 mount considerations for equipment decisions.
May 31, 2024
Any Low Cost Astrophotography Setup Suggestions For Great Results?
Hello. I am looking for astrophotography setup suggestions/ideas for $2000 or less in total that would be able to deliver great imaging results, such as of Deep Sky objects like galaxies in a natural color and also objects like comets as well. I curr...
Relevant; addresses budget astrophotography setup under $3500 for imaging.
Apr 21, 2024
So You Want to Buy a Big Refractor: My Decision, Setup, First Light and Beyond
I recently decided to add another scope to my fleet, gaggle, herd (whatever a group of telescopes is called). I have a William Optics GT71 with 0.8x focal reducer that I’m very happy with and a Celestron NexStar 8SE which is great for visual and plan...
Relevant; covers refractor telescope selection and setup for deep space imaging.
Feb 17, 2024
A great idea for a group... Thank you Frank!
I've had discussions with some of my astro colleagues in the past about the fact that these open clusters seem to be a little bit under appreciated. Now, thanks to Frank, we have a group to showcase these interesting and beautiful subjects. After...
Discusses astrophotography equipment relevant to imaging open clusters.
Aug 14, 2020
