Hello guys, This is a very long post but I felt that the people willing to give me some suggestions will need to know the history of the OTA as well as the setup. I’m swallowing my pride and asking for your help here. I always try to fix things myself before asking for help and I can tell you that the others I have asked for help have not given me the “fix” for my problem here! I’m looking for some help with a problem I have had with a 12” f5 newt. I’m looking for others that have experience with large newts or (very similar optical trains) that have experienced the same or similar problems I’m going to describe.Let me give you some background here because I think you will need to understand just how much I’ve worked on this setup and what all has been done. 1st, I’m a big fan of newts and I use them as my main imaging instrument. My 8” & 10” newts I’ve always had very good luck with round stars etc… Feel free to look at my other images in my profile. They are not what I’d call perfect but they are very acceptable to me and was happy with them. This 12” is NOT acceptable in any way at this point to me! “OTA Background” The OTA is a 12” F5 Steve Swayze primary with an 1/18th wave Antares 3.1” secondary mirror. 2” Moonlite focuser with dual 7”x8” inside/outside reinforcement plates to eliminate tube flexture in that area. See images that I have attached. I have also modified the primary mirror cell with extra heavy duty springs and oversized fine thread collimation screws and added an extra “but lighter” set just for extra support between the collimation screws. This is all sitting in a set of custom Parallax 14” rings with dual 24” Losmandy mounting plates, an Orion CF 80ed riding a top for guiding. This all weighs in at 76lbs and is 47” long from end to end and is housed in my back yard Roll of Roof observatory. “Mount Background” When I 1st had this scope setup for imaging (2yrs ago) I run it on a Celestron CGE Pro that had problems with the drives motors. (CGE Pro owners know what I’m talking about here) but later on with the help of a few people I rebuilt the mount and converted it over to the OnStep drive system. While this made a significant difference it just wasn’t what I had hoped for so I pulled it off and decided if I ever get a better mount I’ll give it another try.Well as it worked out I was lucky enough to acquire an AP1200 mount that has performed incredibly well with tracking numbers that I didn’t even know existed. (I don’t need to give any details on this mount they speak for themselves) So I decided to go ahead and give the 12” OTA another try to see how this mount would handle and track with this scope. Considering this OTA to mount ratio is only 54% (yes its over the 50% rule of thumb for mounts) I’d still have thought I’d get more rounded stars with this setup! “The Problem”It doesn’t seem to matter what length of sub I use, I always seem get these stars that are egg shaped from the middle of the FOV right out to the edge of the field. BTW This is zoomed in 100% to see the egg shaped stars. (See the pic’s of the sample image along with guiding numbers for reference) Collimation is spot on and when I use a single beam laser in the focuser perfectly centered in the primary center ring, it does NOT move regardless of where you point the scope, so I believe that tube flexure and or primary shift isn’t the issue. Am I wrong or missing something here?I have also gone thru and built the jig, and adjusted the tilt of the camera using the method described in this article/tutorial https://www.macobservatory.com/blog/2021/11/28/how-to-remove-sensor-tilt-from-your-astrophotography-camera-while-indoorsWhile this helped it did NOT fix the whole problem, and I am planning on going back and tweaking it in better if possible. “The Imaging Train”I’m using my ZWO 071mc pro with a Starzona filter drawer attached to a Quattro Coma Corrector. The filters I’m using are as follows: Optolong UV/IR CutOptolong L-ProIDAS NBZ Dual Narrowband filter. All filters produce star images that are identical or extremely close to each other. Thanks in Advance to any and all that reply! Dale
