Andy Wray avatar
I've had an HEQ5 Pro since I started this hobby and it has just about managed my 8" Skywatcher 200pds, filter wheel, camera, OAG, guiding cameras etc..  It does struggle with DEC backlash even though I've belt-modded it and tweaked it.
I know I need to look to upgrade my mount, but wondered what you would suggest?  I'll want something that could handle maybe 1.5 times the load.
Any suggestions?
Chase Newtson avatar
Hi Andy, as a curiosity, what is the total weight of your imaging train?
I'll let people who actually have experience with these larger mounts chime in, but I know the EQ6-R Pro is a very common recommendation, at a 44 lb capacity.
I personally am thinking about pulling the trigger on the Ioptron Gem45, as my first and current go-to mount is the Gem28.  I have been enjoying it with my much smaller setup compared to yours haha.
But again, I don't yet have experience with any of these larger mounts, but could be a starting point in your research.
Good luck and clear skies!
–Chase
Tommy Blomqvist avatar
The EQ6-R Pro should work well with your configuration.
The only real downside with that mount is it's own weight.
Marc avatar
I recently got the iOptron CEM70G, which fits your description. If you are on a budget, the EQ6-R is also a very viable choice.
I ultimately went for the CEM70 because of the more forward-thinking engineering, the weight, the greater carrying capacity and the built-in gadgets, like USB hub, guide camera and digital polar scope. But it all comes at a premium, of course.
Well Written Concise
Nadir Astro avatar
If you're already used to SkyWatcher mounts, remote, EQMOD, etc. logical upgrade seems like AZ-EQ6. I'm using mine for more than 5 years now and it's a great mount ! Also had HEQ-5 before.
Torben van Hees avatar
Budget is a very important part of that question.
The difference between something like the EQ-6R and something like a 10Micron 1000 or AP Mach 1/2 is not so much in peak or even average performance under normal seeing conditions. It‘s that these premium mounts allow you to reach this performance effortlessly. You stop thinking about the mount. Even if things go wrong, it‘s never the mount. In essence, you pay either time tinkering or money up front.
Andy Wray avatar
OK, I've narrowed it down to EQ6R Pro, CEM70 and EQ8R Pro.  I can afford all of them (if I don't tell my wife how much they cost).  Just wondering what you would choose:
* At the moment, I don't have a permanent setup, so need to setup and strip down every night.  That would lead me to the EQ6R Pro or the CEM70
* I would like to invest for the future, so that would tend to lead me to the CEM70 or the EQ8R Pro
* Anyone with the EQ8R Pro here who can tell me just how heavy it feels when setting it up each night?
Any other options that people can think of that are reasonably portable to setup manually in the backyard, but that could be good for a permanent observatory downstream?
Andy Wray:
None of the above but considerably more expensive.
Andy Wray avatar
Andy Wray:
and those would be?
Ross Salinger avatar
If you have the money the MYT is the way to do. I bought mine used and I love it. I've had scopes as big as a C11 on it with no problems. I had it out at my observatory permanently mounted for about 3 months while my CEM120 was being serviced (upgraded). Otherwise I really like the CEM70 which is the smaller version of the 120.
Rgrds-Ross
len2376 avatar
For me, because of my frame, weight would be the biggest issue. I bought a GEM45 to use alongside my HEQ5. It is lighter and so much more manageable. In use better in pretty much all ways. So before getting a heavier mount than a HEQ5 I would load it up with whatever the extra weight would be and carry it out a good few times before making a choice. I think that if you were really thinking of a permanent installation I would get that done first. Then it becomes a different story.
David Moore avatar
I also have the 200PDS and it's on an AZ EQ6 which copes with it very well as long as there isn't more than a breeze. You don't need the EQ8 unless you are going to get a 10" or greater or your wind speeds are an issue. The EQ6 is slightly heavier and can cope with a heavier payload.
Marc avatar
Andy Wray:
I have a somewhat similar scope/setup like you (4" APO and 8" Newtonian) and I did order the EQ8-R last year, but ended up returning it.  Mostly because it had mechanical issues, but I also disliked the whole "workflow" of setting it up.
The mount head is heavy. Not too heavy, but it is annoying nonetheless.
The head connects to the tripod with two big hex screws, which are awkward to get to. So the process of putting the whole thing together and breaking it apart is a bit frustrating, especially in the cold. Also, you absolutely cannot transport the EQ8 and tripod in one piece, so this process has to repeated every single night.
If you get the original steel tripod, prepare to be surprised. That thing is heavy as f... There are third-party wooden tripod options of course (also: cheaper).
The USB hub does not really work; apparently it does not provide sufficient power to the ports or whatever, but equipment won't be detected reliably by your PC when connecting through the built-in hub.
The carrying capacity is severely overkill for something like an 8" Newtonian or similar. This is not an issue as such, unless you factor in the hassle of setup and teardown. But for my 4" APO, it actually was a problem because balancing was difficult to achieve and the long saddle caused problems for the 360° rotation. It's a short scope after all..
As mentioend earlier, this is why I ended up buying the CEM70 - you can fairly easily transport it with the Tri-Pier tripod attached (about the weight of the EQ8-R mount head), it has the same sort of functionality (USB hub, home sensor etc) and carries up to 32kg (70pounds) visually (probably 25kg for astrophtography). So unless you are very, very dedicated or are absolutely going to build an observatory in the forseeable future, I would stay clear of the EQ8. It's a great mount for sure, but I would not want to have it in a mobile setting unless my scope absolutely requires it (say: C11 and up, 6" refractor or Newtonian >= 12" etc)
thekubiaks avatar
Mach 2
just trying to improve my guiding with an AVX
Hello everyone, I simply want better guiding with my AVX, and I'm willing to "tear it apart" to change components whenever I need to. I saw this video of a person changing the gears and adding a belt to get smoother motion (I think, and...
Author already has HEQ5 Pro; this discusses AVX modifications instead.
May 11, 2024
What is the main difference between the Skywatcher EQ-5 Pro and the Skywatcher EQM-35 Pro?
So I am quite new to this hobby and started to look for an equatorial mount, I came across the EQ-5 Pro and the EQM-35 Pro but I noticed that both have the same weight capacity and both have a goto controller. This got me wondering, what mount is bet...
Discusses mount upgrade decisions; relevant to evaluating mount options for astronomy.
Dec 26, 2020
HAE69B
Hello! I've been discussing this mount with a few owners and I am hearing mixed opinions. I am considering setting up either a 130mm refractor or a 185mm refractor at a remote imaging hosting site. If I go with the smaller refractor I'll put ...
Discusses alternative mount option that could handle author's upgrade needs.
Apr 4, 2024
