Abhijit Juvekar avatar
Hello,
I recently went through lot of research and found OSC and Mono cameras have their own field of expertise (usage) which can not be compared with one another directly.
I currently use ZWO 1600MM-Pro with LRGB and HA-OIII filters as primary setup.
But for getting dedicated OSC I thought of getting following options
1] Player-One-Uranus-C USB3.0 Color Camera (IMX585)
2] Player-One-Mars-C II USB3.0 Color Camera (IMX662)
3] ZWO 482MC
4] ZWO 294MC (non-cooled)
Getting one of the above OSC camera to go along with my current setup of 3 OTAs
GSO 6 inch RC (for galaxies)
Sky-watcher 130 PDS Newtonian (for normal field)
Sharpstar 60ED APO refractor (for wide field)
Any recommendations for above ?
Thanks
That depends on what you want to do with any of them and with what.
Pablo Gazmuri avatar
For proper sampling, pixel (aka photosite) size matters, and it depends on focal length. Each of your scopes would have different ideal photosite sizes.  I would recommend something with small enough pixels that you will have good sampling at shorter focal lengths, that you can 2x2 bin for decent sampling with your RC scope.
See more here, with a calculator: https://astronomy.tools/calculators/ccd_suitability
I don't have direct experience with combining images of different resolutions, but I would imagine it's also helpful to have a similar resolution as your mono cam.
Jim Medley avatar
Here is a different calculator that lets you put in your specific telescope/camera combination and see how it would look https://www.bintel.com.au/tools/astronomy-calculator/  I chose the ASI 2600 mm Pro because I was coming from a DSLR and was used to the APS-C sensor for framing.  It also depends on your choice of targets, wide field might work better with a larger sensor.
Ed Dixon avatar
I have an older ASI224MC, a ASI294MC Pro, and a new ASI485MC.  I got the 485 as a replacement for the older 224 but have not used it much yet.  My focus there was for planetary.  That season is in the fall this year. I have used the 294 many times and it works great!  The cooling really helps for wide field shots where you need more exposure time for targets. I am also working with a ASI174MM and filter wheel, but that's still new to me.
Experimenting with dual band filters
Hello everyone, I've recently added to my Newton 20cm f/4 + ASI2600MC a filter wheel with two 5nm Antlia Dual Band filters, one Ha-OIII and one Hb-SII. Another slot of the FW has an old IDAS LPS-2 (light pollution suppression). The idea is to acq...
Discusses dual band filters with OSC camera similar to author's setup.
Mar 2, 2024
About the calibration and usage of cameras with the Gsense 4040 sensor
Dear all, for almost exactly two years now we (Dr. Karl Remeis-Observatory Bamberg) are using a Moravian C4-16000 EC which houses the Gsense 4040 sensor from Gpixel for our university astronomy lab course and public outreach purposes. Initially we ha...
Details camera sensor calibration relevant to OSC camera selection decision.
Feb 28, 2024
