What does your backyard setup look like?
VroobelDjenningsTareq AbdullaScott BadgerPistachio_Enjoyer
506 replies44.1k views
Andy Wray avatar
Here's my scope in my very small back garden surrounded by trees and buildings.  What do your backyard setups look like?
Tino Heuberger avatar
Here is mine (a bit of an outdated photo, but still looks pretty much the same)
Dale Penkala avatar
Here is mine in my back yard observatory.
Reg Pratt avatar
The tarp is blocking a streetlight across the street.
Christopher Davenport avatar
Oooooh like this thread, also add some comments about specs and why, to inform for future kit ideas.
Reg Pratt:
Is that a 10inch on a Gem45?
Reg Pratt avatar
Christopher Davenport:
Reg Pratt:
Yup
Linwood Ferguson avatar
Rig porn, I love seeing others, keep them coming.
First is Refractor setup.  This is the travel version with battery, normally in the backyard I have a small handtruck with two power supplies that I also carry the counterweights on.  Below that is the C11 on the same mount, didn't have a wider view of it, and at this point the dew strip is tucked under the dovetail.  The little three legged thing is a weather station primarily in place for a RG-11 rain sensor, so I can be awakened if it starts raining, but it also feeds wind, temps, GPS (clock sync mostly), etc. to the software running on the NUC on the mount (and into my home system).   It also sits with the Planet spikes in small holes in pavers, so I am within a couple arc minutes of aligned just by placing the tripod, very repeatable.
ROBERT FELMLY JR avatar
7" Celestron Maksutov on the Celestron CGEMII mount.  Focused on the moon during the last of the daylight, waiting for night to fall.
Michael Timm avatar
Roy Hagen avatar
William Optics FLT 132 with ASI2600MC camera (OSC), and ASIAIR plus on iOptron CEM60 mount,   and William Optics Z61 with AS071MC (OSC) camera,ASIAIR pro on iOptron GEM28 mount. Radian Triad Ultra Quad band filter on both.
60°N
Power supply ("el cheapo" Amazon) from house
 e
Jérémie avatar
Unfortunately, mine looks like the park of a city...
Jérémie avatar
Surrounded by buildings !
Anyway, the essential stuff are there : Polaris to polar align !
jewzaam avatar
Seems I only have some pix while taking flats.  PC on the right is used for remote access to PC mounted to the scope and to power flats panel (tracing tablet).
Jérémie:
Hey, we got the same ladder!
George  Yendrey avatar
Not quite current but fairly close equipment wise.  At this iteration it consists of:
Skywatcher Esprit 100 ED F5.5 w/field flattener
Moonlite Express Nightcrawler WR30 focuser/rotator
ZWO EFW 2"x5 filter wheel
ZWO ASI 2600MC-P OSC camera
Pegasus Astro UPB v 2.0
Williams Optics ZenithStar Z61 F5.9 (used as a guidescope)
ZWO ASI290MM guide camera (shown here with original WO ring, which is insufficiently rigid for guidescope mount.  The mounting ring has been replaced with an ADM Accesories Guidescope ring set on a D plate adapter - also ADM Accessories)
ADM Accessories D plates, spacers, etc.
Software Bisque MyT mount on a Software Bisque 10" pier on a 5'x5' slab (4" thick slab with 6"x2' edge footers w/ a central 2'x2'x2' concrete 'mass'.  The soil is very fine 'sugar' sand and is considered  fluid for structural support purposes.  Breadth not depth is what provides stability in this type of soil according to my daughter who is a structural engineer.
During the day it is covered with a Telegizmo 365 cover which does a very good job of protecting everything.  When we're away from home on trips/vacations, the entire mount and OTA are moved indoors and mounted on an Ioptron Tri-pier which I use for maintenance/testing before moving the assembly outside.
It is controlled by an Intel Gen 10 NUC.  It, along with the power supplies for the mount and the UPB are mounted in an NEMA 4X enclosure w/cooling fans.  The three cables that connect 'box' to the mount/rig disconnect and coil up on the mount when not in use while the 'box' goes inside my office.  While I can connect to the NUC locally, my normal access is via Remote Desktop or with RemotePC.  Upgrading/modifying my home network wifi infrastructure to provide good/stable wifi connection was a separate project.
The guide scope assembly slides off the top D plate and is replaced by an ADM Accessories D plate compatible hand grip.  This provides a safe/secure means to lift and carry the OTA assembly when it is removed from the mount.
The current configuration that I haven't yet taken pictures of has changed slightly and since making the change I've had over 30 days of either clouds and/or full moon, or both at night despite hot clear days.  The EFW and OSC have been replaced with a ZWO EFW 2"x7 filter wheel and a ZWO ASI2600MM-P.  EFW is loaded with LRGBSHO filter set.  So yes, I've gone to the darkside for monochrome imaging.  Or at least started the move in that direction.
I do have a ZWO OAG-L, but can't really see an advantage for it with my current focal length and FoV.  If I eventually go to a Stellarvue SVX 130 or 152 or even an AG Optical 12.5" CDK, then the OAG would be necessary.  At that point would definitely need an R-O-R observatory enclosure - IMO.
Jérémie avatar
Jérémie:
Ha ha !
Very handy one. One of my best purchase.
My wife use it to access the roof of the cabin where she grow a vegetal roof. I planed to install my mount there but was worried people from the surroundings feel... observed (you know people when they don't know or understand what you do...).
So I am stuck on the ground.
CCDMike avatar
This is mine with a nice view to the south over my little village with bottle 4.
Someday there will be an obsy. Someday....😁
Mike
David Rosenthal avatar
FSQ106EDX on CGE-Pro with Moravian G3-16200
Edge HD 11 on CGE-Pro with StarlightXperss Trius694
Terrance avatar
Here is mine....Capricorn Island Observatory (CIO)
Terrance avatar
Explore Scientific 102 FCD 100 CF, Celestron AVX, ASI183 MC Pro, DIY pier.......
Terrance avatar
Control center.....
Abhijit Juvekar avatar
DSO imaging Setup on home terrace
GSO 6 inch RC telescopeiOptron iEQ45-PRO mountZWO ASI1600 MM-PRO camera with ZWO 5 position EFW.
Sky-watcher 130 PDS TelescopeiOptron iEQ45-PRO mountZWO 1600MM-PRO camera with 5 position EFWGSO coma correctorFinderscope used as guidescope.QHY5L-II-M guide camera.
Older setup
Sky-watcher 10 inch Dobsonian on EQ Platform tracking.
ZWO ASI120 MC-S Camera on Orion 3X Barlow.
Aperture fever (Dobsonians)
Sky-watcher 6 inch Dobsonian (2010)Sky-watcher 10 inch Dobsonian (2016)
older setupZWO ASI120 MC-S Camera on Orion 3x Barlow with Sky-watcher 6 inch F8 dobosnian OTA on EQ5 mount.
widefield
Sharpstar 60mm APO ED Refractor
ZWO 290 MC
iOptron iEQ45 PRO
Steven avatar
I'll have to take a picture of the rigs if I ever get to set them up again smile
