NB unmouted filters side matters!
10 replies538 views
GregGurdak avatar
I am so surprise that Astrodon selling so expansive filters and saying nothing about the side direction of them , instructions or something … wow … is like buy it and beat it , find out  for yourself …  I wonder if they ever did any Astrophotography?  Looks like Astrodon has no clue what they are selling or how to use it … I lost like 4 hours to find out what is going on ….
I was having problem during flat frames "session " one of my filters act strange one corner was much brighter and few more reflections on the flat frame … so I open filter wheel and check those little "trouble makers" …so find out that one side is more shiny and gives you multiple reflections when you are holding a little screwdriver on the front of it … the other side is more absorbing… almost no reflections…
If one side appears much more shiny than the other, it would be better to have the shiny side opposite the camera to reduce internal reflections from any light leak on the camera side of the filter.  This would be a particular concern when taking dawn flats, where the area around the camera may be well lit with wide band twilight, and the only light for the flat is heavily narrowband filtered.
so check your unmouted filters guys for better results…. clear skies
Adel Kildeev avatar
smile Unfortunately, Astrodon was sold and a new owner is running company poorly. I did read a lot of complaints about really dirty (!!!) filters delivered, unresponsive customers service etc. I am changing my filters to Baader Planetarium, very reliable and excellent customer service. Sorry to hear about your troubles. Flipping sides may help, but if the filter surface is uneven (which is totally unacceptable), I advice you to return filters and request for refund, nothing else you could do here.
Concise
GregGurdak avatar
Adel, can’t say anything bad about the quality, because mine came super clean and well packed… but they should  notice like -" before use you have to find out which side is good for you because we have no clue what we are selling and how to use it " …. then fine, done , I know what I am dealing with , and planing few night for experiments, cool everybody happy smile
Kevin Morefield avatar
The should be a little arrow on the side of the filter that points to the direction of the light path. That’s how I’ve always oriented them anyway.
Wes Chilton avatar
This sounds like user error…
My 31mm unmounted Astrodon filters all have a label around the edge with a little arrow showing the direction to orient them.
Also, most if not all of the complaints about dirty filters were from before Astrodon was sold to the new owner. The new owner is apparently addressing those issues to most people's satisfaction.
There is no question that Astrodon filter are far superior in performance to Baader's. There are many, many threads across the web about reflections and ghosting due to Baader (especially OIII filters). I care much more about performance than customer service in this particular case.
GregGurdak avatar
Nope,  No arrow on my labels … even side label are glued different directions on the OIII filter … upside down I mean … like I said you have to buy them with the knowledge how to find right positions…. if you have arrows on your label means that before they were marked but not on the new ones which I have delivered a week ago straight from OPT ….
Dave Erickson avatar
Might be true if the antirefeecton side was absorbing but it is not it is antireflecting, distructive interferance. Generaly a BBAR is on one side and a NBPF on the other for Gen 2 filters. This is done to spoil resonance in the filters that causes halos around bright stars. These halos were a major issue with early filters where the NBPF dielectric stack was split between the two sides resulting in a resonant cavity and halos from multiple reflections. Advancements fromTelcom filter deposition methods, IBS and enhanced spinners,  are now used in astro filters as the norm, lucky us.
The BBAR is likely not perfect or a VAR is substituted. In this case there may be additional reflection across the band from the AR coated side. Suggest you do the math, you will be surprised at the result. Likely the filter was not centered in the housing and light was leaking or the edges are not blackned and light is leaking through the filter edges. Are the edges blackened?
Helpful Insightful
GregGurdak avatar
Sure they are by Teflon rings provided by ZWO ASI  with filter wheel … can not been wrong housing because the opening is designed right on for 31mm …. when I turned  filter "upside down " problem was solved when I did my flats …. I am not talking about light frames … just the flats where is impossible to do it ( pure flats ) if the filters is placed wrong side ….
I know a little bit about this… I am glad you found a solution, I understand why it is better and why it is likely not optimal.  Just attempting to help, good luck…
here is a link to Don's website… https://astrodonimaging.com/
I stand corrected on the arrows pointing in the direction of the lightpath - just opened my filter wheel and the Baaders have the arrow.  The Astrodons have a label but no arrow.  That said, this is the first time I've heard the side mattered.
Patrick Nagel avatar
Wes Chilton:
This sounds like user error...
I know this is way late but thought I'd chime in. I just ordered some new ones and yeah they were pretty damn dirty, in fact I ordered a used one from someone that looked better than the new ones lol.
Question about correct exposure for flats (overcorrecting flats)
Hi everyone, I recently switched from a DSLR to a QHY163m + Baader LRGB filters. My first steps went Ok, I think - but I focused on very bright and diffuse objects (M42, Rosetta nebula). Switching to objects with a lot of sky background, I noticed th...
Discusses flat frame exposure issues with filters, directly relevant to author's problem.
Mar 23, 2018
Eliminating reflections
Hi, I've been struggling with reflections in my imaging setup and was hoping for some pointers to improve the situation. Two types of reflections seem to be prevalent: - circles/discs around bright stars (see e.g. https://www.astrobin.com/full/37...
Filter orientation affects reflections; directly relevant to reflection problems.
Nov 28, 2018
