Petar_Babic avatar
What mount would you recommend for astrophotography, I was thinking either the ieq45 pro or skaywatcher eq6-r. In the future I plan to use two 80mm refractors. Currently, I have an 80mm refractor and an eq6 mount that is 15 years old.
Diego Colonnello avatar
Answer is,  the heaviest most expensive you can afford…
For example takahashi em 200. Paramount myt.
On the cheap side..   look at AZ eq6.
bobzeq25 avatar
Two good choices.  Are you planning to mount both scopes at once?  That reduces tracking accuracy, weight matters,
even below capacity.
Petar_Babic avatar
Yes, I am planning to use both scopes at once.
GregGurdak avatar
Ioptron CEM60 should do The job don’t bother with 45 …
Petar_Babic avatar
The CEM60 is a little too expensive for me.
GregGurdak avatar
Then go for 45 but good enough for one 80mm scope, not for two of them smile … why do you need to load two at the same time anyway??
Petar_Babic avatar
Because I most often soot from my balcony and I have tops 1h 30min of imaging time and if I had 2 scopes that would double.
GregGurdak avatar
:… if going to open area ( park or something) is in option… I would rather spend some money on the batteries than second set up gear ( telescope and camera filters etc.)open area better star alignment?
Petar_Babic avatar
:... if going to open area ( park or something) is in option
Yes, that is an option.
GregGurdak avatar
There you go Peter smile … don’t spend your money on second identical gears setup…. that’s crazy smile … all the best
bobzeq25 avatar
Get one scope, one camera, and one mount.  Get that working first.  Then consider if you want to add a second.
You'll have experience tracking, can see how difficult it is.
Isaac Silva avatar
Hi guys. I also had doubts about the equipment and, after evaluating, I bought a Sky-Watcher EQ6-R Equatorial GoTo mount and Sky-Watcher 10 " f/3.94 Quattro Imaging Newtonian Telescope. I'll start with a Canon camera (B&H).
Robert Huerbsch avatar
Well I own both an IEQ45 Pro and a NEQ6-Pro hypertuned with the rowan belt mod.
The IEQ45 Pro has worked 100% without issue right out of the box. As in, ASCOM drivers and iOptron commander connecting in windows, connecting mount to SGP, and sub arc second pulse auto guiding. The pointing accuracy has also been excellent, but I use a polemaster. I love the size and weight of the IEQ45 for portability. The polar scope is better than the NEQ6 as well. The NEQ6 (0.6-0.7" RMS) does guide slightly better than the IEQ45 Pro (0.7-0.9" RMS) but the NEQ6 is DarkFrame hypertuned with the upgraded precision worm. I really like that I can convert the IEQ45 to Az because I enjoy visual and have a 200mm newtonian I can use with it. That may not matter to you.
I think most of the time, NEQ6-R will be better than the IEQ45 Pro. I would keep the total weight to 30 lb or less for the IEQ45 and if using a larger/longer OTA like a 5" refractor or 8" newt the NEQ6-R would probably be the better choice. For the 80mm refractor, both will not even notice it ; )  I'd probably go with the iOptron in that case.
Tareq Abdulla avatar
Go with AZ-EQ6
someguy avatar
iOptron CEM25EC mount, any thoughts on it? I'll be using a WO Zenithstar73 and dslr and am looking for something fairly portable. I like the idea fairly decent exposure lengths without guiding. Thanks for your input. Guy.
dkamen avatar
You have to weigh that against the time it takes to assemble and align a very heavy mount with 2 scopes.
Dimitris
Jeffrey Geiss avatar
EQ-6, EQ-6R  (or the Orion Atlas, rebranded EQ6 in U.S.) are the budget mounts I would suggest. The R is better , belt drives make is quiet, but I've been using my EQ-6 for 5 years with very good results. My EQ6 did require me to tune out the worm gears and thrust bearings which meant some reading and some tweaking and a special tool. My buddy's R ran superb out the box at a higher cost. Do not buy a used Orion version of these (Atlas, Atlas Pro) as they will not support them unless your the 1st owner.  Not sure what the Skywatcher service rules are.  You can run them from your computer via EQMOD software. Its an decent solution, not as good as a native ASCOM driver found on other mounts, but its it mature, reliable and complete. These mounts work with almost all the software you will need and there are many Apps that are free to really cheap to get you started. EQMOD-Free, BYEOS(cheap), APT(cheap), SGPro (moderate cost), plus Plate Solvers. If I had the budget years ago and the knowledge I'd gone with a Mach1, now Mach2, but 3x Cost of the EQ6's. I would not recommend a Paramount to a beginner. My buddies have had them, The SkyX is daunting, they have not been bullet proof electronically, they need some annual service. The Celestron's are very good, a friend runs a CGX and its quite a beast and generally likes it. Though I've heard him cussing its guiding accuracy occasionally. That said, I cuss at mine sometimes also.  There are more options than ever but depending on how important the budget is in the end I say a new EQ6R if you can afford it, if not a new EQ6 will give you years of service and will get you to the next level when your ready.
Jeff
Hello from Caves Beach NSW Australia
Hi everyone,I have been an Astronomy enthusiast since I was 9 years old just after the Apollo 1 fire believe it or not.I bought my first telescope in 1973 for $80 at KMart, which I still own.It is a 114mm Tasco Focal Newtonian reflector on an equator...
NONE
Jul 22, 2019
Skywatcher EQ5 Pro or Ioptron CEM25P EQ? Plus telescope choice.
Hey everyone! I am currently looking at going for a proper Astrophotography setup as apposed to my little DSLR lens and Ioptron Skyguider Pro setup. First things first is the choice of mount. I am tossing up between a Skywatcher EQ5 Pro or the Ioptro...
Relevant - discusses equatorial mount selection for astrophotography setup decisions.
Jul 5, 2019
Off Axis Guider Recommendations
Hello everyone. I am about to upgrade my equatorial mount which means I will finally be able to use my 11" Edge HD. I plan on using an off axis guider however, I am not sure which ones are reliable. I have already tried the CELESTRON Deluxe OAG ...
NONE
Dec 27, 2019
New mount
Hi! Looking into upgrading my EQ5 mount to a more stable platform for imaging. I have a 80mm triplet with guiding equipment which I’ve been using for imaging for a couple of years. Currently I’m looking at the HEQ5/6 or the AZ-EQ5/6. The AZ-EQ6 is so...
Relevant - upgrading from older mount with 80mm refractor, similar situation.
Jan 25, 2018
