Jan Klíma:
Hello guys!
I just got a new mount EQ-6 R PRO => I'm trying to connect it to ASIAIR PRO via the USB port that the mount has, but it doesn't work!
Everything is connected and otherwise functional.
I tried to switch BAUD value from 9600 to 115200, but it didn't help :-(
Please - what about that? Did I forget some step?
Best Regards
Jan Klíma
You need to have the baud rate on the mount USB port set to 115200 regardless. It sounds like there’s another factor contributing to your connection issue here, but regardless of all else, if you have the mount baud rate on anything other than 115200 you will not be able to connect.
Are you running the most recent version of ASCOM? If so, this sounds like potentially either a COM port issues or ASI driver issue.
For what it’s worth, I know the key selling point of the ASIair products is that it makes it “easy” to have a remotely connected, wifi mount, but it is easy to get this same result simply using a windows capable mini PC. That way you are not beholden to using the ASI software for everything & can instead use the non-ASI software tools of your choice, which are often much better anyway.
i am using a beelink mini PC that came pre-loaded with windows 10 pro, which allows for simple remote connection & control through a separate windows computer using windows Remote Desktop. There are also smart phone apps for iPhone or android that allow you to connect & control the mini PC through your phone if you want. I have the mini PC attached to the mount & connected to my home network & control it all through my separate laptop from inside the house if I’m outside with the mount using the same method. Using an actual PC allows me to use NINA, phd2, Stellarium, etc.
Going the remotely connected windows mini PC route is not difficult to set up & gives the same remote connectivity/wifi benefits that the ASIair does. The ASIair devices have a beefy looking wifi antenna for a booster single. I bought a USB plug-in high gain wifi antenna for $20 to boost the wifi to the mount PC & connectivity is never an issue.
food for thought if you aren’t able to get the ASIair to work & decide to return it.
