William Optics and Fuji Camera compatibility
2 replies174 views
YaniMaravillo avatar
Hi, I have a Fujifilm XT20 and I wanted to use my camera for deep sky astrophotography. I'm planning to acquire a William Optics telescope, maybe a ZS61 or 73, but I am not sure how I can connect it to my Fuji camera. I know  WO telescopes only has adapters and t-rings for Nikon and Canon. Is there a way I can use my camera with the WO telescope? I've seen images here using the WO and Fuji combo, and I'd love to know how you do it. smile What particular adapter and t-ring do I need to buy? Also, will the ZS73 work with my mirrorless apsc camera? Based from the specs, it's for full-frame cameras.
I'm thinking I should buy an EOS to X mount adapter, then use the 48mm T mount for Canon so I  can attach my Fuji camera to the WO telescope. Will this set-up work?
I'm still a noob when it comes to astrophotography and still have a lot to learn and what better way to learn than to ask questions from seasoned and more experienced astrophotographers. Thank you in advance! smile
Lightbeam avatar
https://www.telescopeadapters.com/165-fuji  Hello YaniMaravillo this is who supplied  mine for X-M1. I also got a chinese one for my T20 but it was rubbish. Hope this helps .
Lightbeam.
Paweł Białecki avatar
Hi Yani Maravillo,
have you solved your problem? I'm asking because I'm in the same situation as yours smile I want to buy a Zenithstar 61 for my Fuji X-T20 and plug it into my camera with EOS-to-Fuji-X adapter (with a William Optics' T-Ring for Canons). I'm not sure it will be working (focusing distance, backfocus etc.).
Redcat 51
Hi! I'm thinking of buying the RedCat 51 by Williom Optics. I have a nikon d5300 dslr which is a crop sensor camera. In william optics' page, thay say that the RedCat 51 is compatible with full frame and crop sensor cameras. What adapter do I...
Discusses William Optics telescope with different camera; may contain relevant adapter information.
Aug 2, 2019
Sony Alpha 7s settings
Hi guys, I've just bought a Sony A7S for Deep Sky astrophotography with a WO Zenithstar 73. Jumping from a Canon 70D to the A7S isn't that obvious, so I was wondering if one of you would be kind enough to share the most accurate settings for ...
Fujifilm camera deep sky astrophotography setup similar to Sony A7S query.
Nov 25, 2018
Tele-Vue 76 APO
I have just bought in second hand a Televue 76 APO . I wish to use my de-filtered Canon 6D full frame for astro-photography. What prime focus and reducer/flattener should I buy for astro-photography which is best compatible with my Canon ? Thanks Yve...
William Optics telescope compatibility with camera; discusses reducer/flattener selection for astrophotography.
Nov 27, 2017
