Where to go next? Seeking for advice!
14 replies429 views
Michele Vonci avatar
Last year I bought a second hand Celestron CPC800. The idea was having a sort of multipurpose telescope: good for visual and for occasional astrophotography. The reality is that I have started enjoying astrophotography much more than visual and in hindsight I did not make a wise choice. The CPC800 is not exactly the best for serious astrophotography. I have to deal with field rotation, narrow FOV, weird optical aberrations with the f/6.3 focal reducer…
The question now is ..what is the most sensible step to upgrade my gear? Perhaps buy an equatorial wedge for the CPC800 and piggyback a small APO refractor? Or sell the CPC800, buy a decent equatorial mount (I was thinking of skywatcher eq6-R), an entry level APO and be back in business again?
The first option is probably the cheapest but I fear that eventually the CPC800 will show its limits, it's not even the deluxe version and also I have no idea about the tracking capability of the cpc800 for instance. The second one is probably a bit more expensive and will leave me uncovered from the visual point of view (although at some point I could buy a cheap second hand OTA, either Newtonian or SCT) but with a solid equatorial mount I can keep improving the optical part whenever I have the funds!
I guess there is not a definitive answer, but I'd like to hear the opinion of much more experienced astrophotographers than me!
Thanks in advance smile
Kevin Morefield avatar
Always a tough thing to give advice on which piece of equipment!  I would say this: Look at the pictures here, see which ones you aspire to taking, look at the equipment used, price that equipment and if you can afford it buy it!
This is a great site for understanding what the various choices will bring you.  Once you've got the type of photos you want to take in mind then it's much easier to get into a discussion of things like portability, weight capacity, reliability, precision, etc…
Kevin
Jirair Afarian avatar
Great advice, I concur.
Jirair
Carastro avatar
Personally I would not mess around with wedges, the people that I know have used them have eventually given up and got themselves an EQ mount.  The mount you suggest skywatcher eq6-R is a very good mount.  I would be inclined to go along with your idea of selling the CPC, and getting a smaller APO for imaging and a second hand scope for visual, though some of the Newtonians designed for imaging will probably offer visual as well such as the SW200PDS - though that won;t give you the larger FOV you were wanting.
HTH
Carole
Hi all,
thanks for the suggestions so far!
Carole, I did not consider a fast Newtonian but it is a good idea indeed!
Cheers
Uwe Deutermann avatar
I bought my scope by looking at the results on AB. Here I could see very well what I can get with what scope. And … one scope is anyways not enough if you want to go through different target types. For sure one day I will add a high focal length scope to my collection, and a very low focal one as well. Big nebula are great, but so are tiny galaxies   smile
And wedges, had one… sucks.
So..although no one is giving me a direct advice, two people have already told me that wedges aren't great….two clues make an evidence!
To give to you specific advice is to guess at your personal preferences.  But if you are looking for a gear list to learn astrophotography you would likely want to start with a small APO refractor (like the GSOs resold under a few different names), and a decent German equatorial Mount (like Orion Atlas) .   Pair that with a mono camera (Zwo 1600 most likely) and an off axis guider.
With that you can learn all about AP and take some pretty great pictures.   You won’t spend most of you time trying to fight endless problems but you will be spending several thousand dollars on the setup!
Adel Kildeev avatar
Kevin, perfect advice, sign under each word. I finally came to exactly setup starting with Newtonian, bigger is not always bettersmile
Adel Kildeev:
Funny my thing is I’ve never owned any of that!  But it’s what I wish I’d started with.
Alan Mason avatar
That EQ6-R is a wonderful mount choice.  A smooth and quiet mount it is!
bobzeq25 avatar
The EQ6R is a fine mount.  As far as a scope, I'll let this other guy give you the advice.
"I started out with a CPC 800  on a heavy duty wedge and a Canon 450d.  In hindsight,
I'd have started with an 80mm refractor.  I would have saved a lot of money and gotten
up the learning curve a lot quicker."
Here's someone else on a scope for both visual and AP.
"I got back into astronomy about 8 years ago with the intention of buying a scope setup that could  "here it comes, you
haven't heard this from every new guy"  work great for visual AND AP. So yeah, I bought a C11 CGE. Yeah I know :-).
I finally tried AP just 2 years ago, and it didn't take long to buy a 80ED doublet for AP duties."
The needs of the long exposure camera and your short exposure eyes are just too different.  The camera works, not because it's better,
but because it's different.
If you want a specific choice.  The Stellarvue SV80ST.  Search here for images, a lot of very good imagers
own that scope.
I did not want to open a new thread, so I keep writing here…the topic is related…
I need a suggestion for the mount!
In the end I have bought a Skywatcher Newtonian 8" Quattro f/4 so now I need to get the mount..I narrowed my options down to skywatcher eq6-r or iOptron ieq45…I might actually be able to afford the iOptron CEM60, depending on how well the auction of my Celestron CPC 800 goes on ebay smile smile !
Any direct experience on any of the three mounts?
Thank you in advance
Michael Timm avatar
I am very satisfied with the EQ6-R. It is stable, portable and will carry your newtonian without problems. The price is also affordable and it is very silent when guiding. I can not say anything to the other mounts you mentioned.
Jeff Bennett avatar
If you’re serious, start with a good equatorial mount.  Look for a used one if you have to, but skywatcher mounts are used in many of the best images here.  After that the most user friendly astrophotography is with a decent refractor or Newtonian , but any scope will do until you get very advanced.  I’ve been through all this, spent a lot of money that I didn’t need to.  I’m back to a refractor on a high quality mount.  I enjoy my time imaging a lot.  Do what makes you happy, there are hundreds of great imagers here and all of them give great advice.  Good luck to you, clear skies!
wedge and hyperstar for cpc1100
hello everyone i have the cpc 1100 gps xlt telescope. i want to start astrophotography for deep sky object and im thinking to buy the wedge and the hyperstar but i dont sure how much it will help me… is there here anyone that have these equipme...
CPC telescope astrophotography progression advice relevant to author's situation.
Jul 29, 2017
Tele-Vue 76 APO
I have just bought in second hand a Televue 76 APO . I wish to use my de-filtered Canon 6D full frame for astro-photography. What prime focus and reducer/flattener should I buy for astro-photography which is best compatible with my Canon ? Thanks Yve...
Second-hand telescope purchase for astrophotography; similar equipment selection considerations.
Nov 27, 2017
hyperstar with cpc 1100 gps xlt without a wedge
hello everyone! i want to buy the hyperstar system for my cpc 1100 gps xlt telescope. i dont have a wedge and im a little bit concerned from the field rotation. how much time i can do exposure until the field rotation will start to affect and i will ...
Covers astrophotography setup optimization for Celestron CPC telescope model.
Aug 3, 2017
Which Telescope, Schmidt Cassegrain or Refractor?
Good afternoon guys,I am hoping toget started in astrophotography and wonder if forum members can help me to get started. I am interested initially in the Solar System but would like to move on to DSO’s later. So, my investment in equipment would hav...
Discusses telescope types for astrophotography; author seeking alternatives to current setup.
Jun 13, 2018
Question about Celestron CPC 1100 StarBright XLT
So, I've been doing photography on and off for years with my Canon 5D mk II. I have always been interested in astronomy and astrophotography but never took the leap. I'll be buying my first telescope soon, partially because I can't wait a...
Similar Celestron model; addresses astrophotography challenges with comparable equipment.
Apr 28, 2017
