HEQ5 Pro with Rowan belt mod .. what guiding should I strive for?
2 replies161 views
Andy Wray avatar
I'm currently achieving an 0.62 RMS arc secs guiding on my mount using an OAG through my 200DPS Newt with the RA and DEC being pretty close to each other.  I just wondered if I should strive for anything better or if this is about as good as I can expect from this mount?
Yungshih Lee avatar
My guess is that what you described is probably as good as it can go. I have a similar setup, HEQ5 Pro with Rowan belt mod, but I put shorter refractors on it and I could get 0.4 RMS or less consistently with OK to good seeing. A 200DPS OTA plus camera, OAG, etc. is perhaps 12-13kg? My modified Quattro 200p with guide scope is 13kg+, which is very close to HEQ5 Pro's load capacity limit. And given that newts are harder to balance, I'd think around 0.6 RMS is already quite amazing.
vercastro avatar
Yeah that's pretty good for that setup on that mount. Don't worry about it.
Calling all AZ-GTi + ASIair users... What guide settings do you use?
Anyone here using the SkyWatchwer AZ-GTi mount (in EQ mode) along with an ASIair pro? I've been running mine for a few months, usually carrying anything from a Canon 70-200mm f2.8 lens to a RedCat 51. It's been a great lightweight mount and I...
HEQ5 Pro with Rowan belt mod .. what guiding should I strive for? — discusses RMS error targets similar to user's concerns
Jan 24, 2021
