I added a 294 MM to my equipment last fall in addition to my 1600 MM and 294 MC (all pro versions). I went back and fourth between the 2600 MM for several months but final decided on the 294 MM for several reasons:
First, I have a rasa8 that really is intended for 4/3 sensors or smaller. Second, I have 9.25 SCT that I wanted larger pixels for sampling at the 4.63 (2x2 binnig) for the larger scope and then ideal sampling at 2.315 (1x1 binning) at shorter focal length with the RASA8 at 400 mm FL. Even with the 12 bit mode at 1x1 binning, the results have been incredible. With the 1x1 mode as luminance layers, it double the resolution aka almost like a scope with 2x Focal length. I added a lum layer to M33 in this example and the difference is wild. I was able to resolve individual stars at in M33 with 400 mm FL in NGC 406 within M33. Definitely check out the difference between the prior non lum versions and the final image.
M33 Triangulum Galaxy 2022 Update Version L+Ha+OSC RASA8
Resolving Stars at 3 million light years!!! NGC 604 Nebula in M33 (Breaking the rule to compare to my backyard to HST Images)When comparing single subs and fully calibrated subs between the 1600 and 294, the 294 MM wins every time with SNR as well as diminished star haloing on the same filters and no microlensing.
I have only had one image where I saw an horizontal banding that has been previously mentioned with my version HOO of Thors Helmet. This was my own doing where I had accidentally set the offset to 10 on NINA instead of an offset of 30 for my other images. Otherwise, I have had no banding issues or inability to calibrate out amp glow or dark current. You can see a similar length HOO image of the dolphin head has no banding.
Thor's Helmet NGC 2359 HOO
Dolphin Head Nebula SH2-308 HOO RASA8With that said, my calibration process is: done with 30 subs for each calibration frame type in order to have adequate powered statistical sampling:
1) 30 darks cooled to same temp at lights
2) 30 6 seconds flats using neutral density film (longer flats to eliminate any banding present)
3) 30 6 second darks to calibrate out my flats (dark flats or flat darks) either way they are time equivalent darks to my flat length exposures.
Finally, I have really enjoyed 294 mm for short focal length at 280 mm and 135 mm focal length. Check out my last 6 months of wide field images in my gallery or on
TAIC (THE AstroImaging Channel) this weekend as I talk about my experience with short focal length astrophotography.
A Winter Wonderland: The Rosette to the Christmas Tree Nebula (SHO Hubble Palette with Rokinon 135 mm)
Rokinon 135mm SHO Hubble Palette Heart and Soul Nebula: Complete Redo Edit after several incredibly helpful critiques
Lake Side Fire: Flaming Star, Tadpole, and Spider Nebula SHO (First Light Askar 400 at 280 mm)I still really like and use my 1600 MM on other rigs while I use the 294 mm for my primary target any given night.
Hope that helps and Makes Sense!
-Brandon
