From my own tough experience with getting started in AP sometimes we may have the tendency to try to fix issues with gear and money which may need addressed by patience, acquiring skill and investing more integration time. I purely judge about myself but I would advise everyone to consider his/her motivation to invest in additional gear. Is really the current gear limiting progress? Certainly not in my case ...
I had a look at your images. They are all quite nice but except for the fascinating Polaris with IFN they are all below 4h of integration time, average may be even below 3h. Results will certainly improve with moving to a dedicated astro cam due to higher quantum efficiency and lower noise levels. But at some point you will need to put in the additional hours. If you look at the IOTDs you will rarely find one with a single digit integration time. What you consider lack of crispness may be caused by SNR.
Good luck with your decision and clear skies
Wolfgang
Thx and yes. Integration times need to go up.
i mean you are of course right and i could just go on and use my z6 for imaging (what i will do anyway).
there are 2 big reasons i want to get a dedicated deep sky camera to compliment my z6.
1. The z6 has a big limitation as i (and everybody else) basically needs to shoot at around 50% histogram illumination. Otherwise stacked pictures will produce artifacts that are impossible to process out.
2. the pixel scale of the z6 is quite big. Around 5.7 if i remember correctly. They suck light in like nothing else and the asi2400 fullframe (same sensor) cleans the floor with the smaller pixel sensors that are out there. (6200, 2600, 533).
but i really want smaller pixels for galaxies. Galaxy season is always around the corner.
Michael Ring:
One thing I have asked myself is if you ever have used Stellarium and compared which targets are easy to image with those two cameras, always keeping in mind that by cropping the ASI2600 to 9MPx you will get the same field of view.
Before I decided on which camera/telescope combination was right for me I spent quite some time in Stellarium to look for things I wanted to image on Astrobin and then checked in Stellarium which combination works well without having to do too big mosaics.
So I came up with my decision of ~400mm telescope and APS-C size camera (Ignoring full frame because it is so much more expensive), a lot of the 'standards' work well with this combination, especially when you can crop a little bit.
Your Esprit 120 is in another league than my 40mm as it is arround 840mm so you will have another set of targets (or details of the standard targets) that you will want to cover.
If they all fit for the ASI533mm, you have a winner, if you need to do 2x3 or even bigger mosaics then you have something to think about.
A few posts above you mentioned that you would like to upgrade to get sharper images, when this is one of your goals, then how good is your average guiding and how is your seeing?
Michael
I regularly spend hours in stellarium, just ask my wife 😅 i really think i will find objects to photograph with both sensors. The size of the of the 2600 (same pixel scale) would be a benefit of course.
can’t really say anything about my guiding. Until now i used a star adventurer with camera lenses and a mgen.
i build (with help of astrobin users) my new rig. (Eq6r, esprit 120, mgen, mini pc with nina).
guiding could become a problem at long focal length and small pixels but i am not worried to much about that.
if it turns out to make problems i can always go off axis guiding.
