Recommendations for Astrophotography Lenses/Equipment (DSO specifically)
23 replies824 views
nickastrobin avatar
Hi All,
I am really excited to be a part of the Astro-photography journey that I started a few weeks ago.
I recently got a Star Adventurer Pro tracker (not 2i) and tried my hands on with it and was able to get comfortable with the wide-angle lens setup during my last trip.
My setup:
Star Adventurer Pro Pack
Sony A7III (Unmodded)
Sigma 100-400mm f5-6.3 DG DN OS
Sony 20mm 1.8G
As I was able to take decent tracked shots of the Milky way without missing the PA during the capturing process I went ahead and tried my hands on with the DSO though I didn't have best lens or equipment available for the telephoto lens that was attached to my Sony A7III.
I tried my hands on the Pin-wheel galaxy. I did have some share of trouble initially and just pointed my lens based on the star hopping I could do at that point in time. I came back from my trip with a question on how to save some time (if I can using some guider or other cheaper way) in the field in order to locate the DSO with an external means or probably other means available to us.
I couldn't take the calibration frames for the DSO as when I tried to put on the lens cover to my Sigma 100-400mm lens, the focal length changed. People who have this lens might exactly understand what I went through . The focal length ring is pretty soft on this lens and it moves with the slightest of touch/push. So that was that!
I processed that image (just to see if I got the target framed correctly) to see if the tracker had performed well with the telephoto lens on or not. Sooner, after stacking the images I was able to see the Pinwheel Galaxy in my stacked file however the target was just at the corner of the frame. BTW, I used the following FLs: 107mm and 130mm. Truth be told, I was elated at first to be able to achieve that much with my first stint at doing DSO photography however little later I was disappointed for probably two reasons:
-Inability to take Calibration frames.
-Lens Selection (couldn't do much about it as that was the only lens I had with the maximum focal length)
-Inability to frame/locate my  target precisely.
My questions to you all are related to this experience and I hope to get some guidance on how to improve this experience in the future.
These are my questions around this:
  1. Which Macro/Prime or Telephoto lens should I go for photographing DSO (Nebulae, Galaxies, Plieades etc.) for Sony A7III mount?
  2. I don't think I would be getting my Sony A7III modded for Astro soon so please advise what else can be done/added to my kit for improved colors in the DSOs I will be shooting.
  3. In order to be precise with locating the target and framing the target accordingly, what steps would you recommend/advise? Would an external app/device help with this?
  4. I do have a Canon 1100d, I am not sure if I want to get that astro-modified and buy a lens for that mount (EF-S) because I am not sure how long that Camera body is going to last (considering I have been using it for almost 10 years and have used it extensively so not sure how much shutter count is left before it is rendered useless). I would prefer doing my DSO Photography with Sony A7III and getting a lens for Sony E-mount rather than spending for Canon (which might breakdown any time on me considering the age and amount of use). What would you recommend?
  5. I have read about Samyang/Rokinon 135mm F2 however I am not sure if this model's performance & quality is also dependent on the quality of the piece I get or does all the units perform the same? I remember this issue being present with Samyang/Rokinon 14mm f2.8 model where not every unit in the market was considered a good piece. Please advise on this.
  6. My budget is little tight however do recommend any other piece of equipment that will help with my DSO photography in the field. Any guidance/links/documents that can help me locate the objects with precision and not doing the guess work in the field.
Sorry for such a long post. I hope to keep my posts shorts in the future but as you can understand I just started with this interest hence a lot of doubts/concerns to be shared with you all
Hoping to hear some suggestions/advice on this soon.
Clear skies to all!
Long post with lots of question so I'll try to answer some of those.
1. Pointing and/or finding stuff with a DSLR and no goto mount. This is a tricky one, even for me. One thing I did/do is to mount a telrad-like pointing device on the hot-shoe of the camera with a some off-the-shelf component from ebay and so DIY. I then aligned it to the best of my abilities to the center of the camera's sensor (using Polaris, as you don't need a tracker to do that). I then star-hop to the object I want to shoot, if there are enough stars visible.
Another solution is to use the same hot-shoe and use a Iphone/mobile holder they sell to use some apps like SkySafari to do just about the same thing (provided that you align both camera+lens with what is shown on the screen at high magnification), only you know see where the camera is pointing at. I've been told you  can get within 0.1 degree of the actual location with modern Iphones.
As for lenses I'd recommend you stick with primes. A good selection of tests can be reached from my Astrobin page. Most of them can be found used at very good prices.
kuechlew avatar
maybe you're pushing a bit too far with up to 400mm on a star tracker but maybe you get it to work. In case you live on the northern hemisphere we now have "galaxy season" and there are not so many large nebulae available for a lens and a DSLR. Pinwheel is already quite a challenge for a DSLR + lens combo.
The Samyang 135mm is a fine lens. There is always some sample variation but it seems to be reasonably controlled for the Samyang 135mm. For examples that can be achieved with this lens you may look here: Samyang 135 f/2 - AstroBin
You're not the first one to miss a target by star hopping: April fools day - time to reveal our major fails - AstroBin
It takes some preparation and this is how I do it:
1) You need a wider zoom, it can be a cheap kit lens
2) Install Stellarium on your computer and add your camera and lens combination to Stellarium. Add several wider focal lenghts covering the whole range of your equipment.
3) Search for your target in Stellarium and frame it the way you want to take images
Example: Heart and Soul Nebula, a target frame with 135mm on my Olympus (270mm effective focal length) may look like this
4) Look for specific patterns of the stars in your target frame which may help you identify whether your framing is correct or not. You need this because you won't see the faint nebula in your images if you work with short unguided subs. So you're photographing "into the void".
As you can see there are star chains, "double stars" (circled), polygons etc. Tipp: Triangles won't help you because you will see plenty of them in any part of the sky ...
5) Now while keeping image orientation and centering switch to wider focal lengths until you see familiar and easy to find bright stars in the sky. It helps to know the major constellations so you may start by learning them. A very good, cheap and nice book is "The Stars" by H.A. Rey.
In my case I end up with:
Mirfak in Perseus and Ruchbah in Cassiopeia are easy to find in the sky and I now have a framing with 35mm
6) Highly reccommended: Take some additional frames in Stellarium with focal lengths between your widest framing and your final framing.
In my case I add 45mm and 75mm:
It helps to watch out for patterns i.e. "Mirfak just on the upper left edge in the image"
Watch out for "patterns" like the fact that gammy Perseus (upper left) and Segin (lower right) are just a little bit out of the frame.
7) Optional step: look for an easy to find star with the same declination as your image centre. This may not always be achievable but in case you manage to do so, you can put this star into the centre of your image and then you only have to move the RA axis to centre your final target,
In my case Navi fits the bill:
In the field you now execute the following steps:
1) in case you found a star in optional step 7 put it right in the centre of your image. Digital cameras have the capabilities to display a grid - ideally a crosshair - which will help you to do so. You may use your longes focal length to do so.
2) Switch lenses to your wide angle zoom - without shaking the tripod and messing up your polar alignment
3) Move your RA axis until the image in your display looks like the one from step 5 at the same focal length (in my case 35mm). Check whether your camera has a "boost mode" for live view to see the stars. Actually for a beginner it's better not to see too many stars in the display ...
In case the display is too dark and you don't see the stars well, you have to take images and look at them. Quite cumbersome I have to admit.
4) Now continue zooming in and double check for the images from step 6. If you did everything right, you will see gamma-Perseus and Segin leave the image at about the same time if your centering is correct. Watch out for similar patterns for other targets.
5) At some point you have to switch lenses to your longer zoom. It helps a lot if your zoom lenses have an overlap in focal length. Take some time to check that you didn't mess up your centering while switching lenses. If you did and lost your target take some time out to get your blood pressure back to normal and start from zero, including polar alignment ...
6) Once you reached your target focal length take an image and compare the patterns you see with what you expect. The target image will show many more stars than Stellarium so it may be a little bit confusing. It takes some practice to find your patterns and the more you identified the easier it gets
Comparing to Stellarium I didn't nail it (a little bit too high and too much to the right). The soul nebula is cut off so I have to move on a tiny bit more along the RA axis. It helps a lot if your mount/tracker allows slow slewing because at that stage you need tiny changes. Doing this manually is a nightmare. Of course framing not too tightly helps a lot in the process.
I hoped this helped. Of course an ASIAIR or a NINA will replace this "manual platesolving" by a fully automated process. I'm still a firm believer that knowing the sky and being able to find the target on your own increases the satisfaction of our hobby.
I hope this helped and I'm eager to learn if someone found a better, easier or more straightforward method.
Good luck, have fun and clear skies
Wolfgang
Helpful Insightful Engaging
Yogesh S avatar
For Framing you could do plate solving.
If you have a spare Raspberry Pi, you could load astroberry or stellarmate os on to it and use Ekos to plate solve and adjust the targeting accordingly. This is what I do.
Side note, you need to disable auto slewing to make sure the pi doesn’t get overloaded because the RAW image is pretty large.
It also works if you have a spare laptop/mini pc and use software like NINA to do plate solving.
There is another alternative, by using your phone. You can send the jpg to your phone or capture the live view screen and send that image here, it will do plate solving and tell you where exactly you are pointed at.
The Samyang 135mm is a very good lens for wide field astrophography. I did read somewhere that the quality depends on piece to piece. I have however used it only few times, I did get good quality stuff from the lens when I used it.
For devices, I would recommend you get StellarMateOS or Astroberry on a Raspberry Pi as a start off, later you can upgrade to mini pc.
Clear Skies,
Yogesh S
Plate solving with a tracker ????
Yogesh S avatar
Why not, you just have to disable auto slewing and move RA/DEC manually. Repeat it until you are within range. When you have technology why not use it!
Yogesh S:
Auto-slewing with a tracker?? Repeat what, pray? It hasn't got a Dec axis, at all! And what tells you the OP has got a PC with him when doing AP?  If I were him I wouldn't. Why don't assume the lowest common denominator when advising things to a newcomer to the hobby?
kuechlew avatar
Yogesh's tipp to check final centering with astronomy.net via the iphone may not be a bad idea at all. A lot of digital cameras allow easy image transfer to the iphone. I share Andrea's doubt that platesolving will help you get to the target though …
Clear skies
Wolfgang
There are a lot of assumptions in plate-solving your way to a target, manually moving a camera + lens sitting on a  ball-head. You can rest assured of that. My advice is at least test-and-tried because I use it myself.
Yogesh S avatar
Leo’s Triplets - M65, M66, NGC3628 - My First every galaxy image
I centered this target by using plate solving that is available in Ekos. Complete dead center would probably be difficult with a star tracker depending on FOV, but you will be close to it.
It may not be perfect as go-to mounts, but hey it helps.
Yogesh S avatar
Yogesh S:
Sorry if I wasn’t being clear, I mentioned turn off auto slewing on the software, if it is on Ekos it keeps on taking pictures and keep plate solving it until I stop it.
kuechlew avatar
Hi Yogesh, I believe Andrea's point is that it's not so well suited for a beginner and I tend to agree. Plate solving tells you where you are, not how to get where you want to. An automated system calculates it on its own and executes the automated slewing steps. It's easy and straightforward to perform this manually if you're trained to think in an equatorial coordinate system, looked up the target coordinates and operate your tracker like an equatorial mount i.e. use the ball head only for declination changes. But an absolute beginner may not yet have the skill to do that.
nickastrobin has been provided with three options. Each of the options seem to work for one of us, so he may try what works best for him.
Have fun and clear skies
Wolfgang
Helpful Insightful Respectful
nickastrobin avatar
Wolfgang
Thanks for sharing such a detailed step-by-step process! I did try quite a few things you had mentioned in your reply however only had the chance to try it couple of times. Probably with time and practice I will get better. This was my first stint with DSO Photography and using the Star Tracker . Thank you again and Clear skies!
nickastrobin avatar
Yogesh S:
Clear Skies,
Yogesh S
Hi Yogesh, thanks for the quick and precise advice! I do have some further doubts:
-From what I have read ASIAIR Pro platform or any other ASIAIR model doesn't support Sony A7III? I am confused as to why it has to be compatible with the Camera when I am using a separate camera (Guiding Camera) which will be connected to the SA and to my phone using the ASIAIR App or did I misunderstand something here?
-What if I use Auto Guiding setup like below? Would it still need to be compatible with my Sony A7III?
ZWO Mini Guide Scope
ASI120MC-S (color)
ASIAIR Plus
Star Adventurer
Sony A7III
-I don't want to use the laptop in any case for the guiding as it will not be feasible for me to have a power supply wherever I go and it's going to be a task setting all these things up and providing power to them. I like the idea of using the ASIAIR app which is available for ASIAIR Plus and PRO, if only that is something I have as an option. Thoughts?
For now, I think those are the only ones that are coming to my mind but based on your response I might have more questions for you.
Pardon my ignorance here. I am trying to go through as much info as I can to educate myself in this field but it's a vast one, I tell you that
TIA!
Yogesh S avatar
Yogesh S:
Clear Skies,
Yogesh S
ASI120MC-S (color)
ASIAIR Plus
Star Adventurer
Sony A7III
TIA!
Do you have one of the ASIAIR already?
If so you are probably limited in terms of camera compatibility, as they are aiming for a ecosystem that supports only ZWO products. There are few cameras they support out of their camera lineup, if yours isn’t in the list then probably you are out of luck.
ASIAIR products help you in the image acquisition process. It is a whole package where you can automate a lot of things including image framing (for goto mounts), focusing using a focuser, filter wheel, image acquisition itself, etc.
You can do all these manually if the camera isn’t supported. However with your setup you can do auto guiding with the ASI120MC-S and the mini guide scope using the ASIAIR, and leave the imaging to your intervalometer if you have one for your sony camera. It perfectly works.
With ASIAIR you are probably limiting yourself in terms of camera and other accessories upgrade. I hear they support mounts that are not from ZWO (not sure about future mounts that gets released). I don’t own an ASIAIR device. If you are looking for a portable setup and haven’t bought one of the ASIAIR, you can take a look at astroberry or stellarmate os on a Raspberry Pi 4, you can use a powerbank to power the raspberry pi.
Hope I was able to help you.
Yogesh S
Clear Skies!
kuechlew avatar
Just my 2 cents: Before you start with autoguiding in your shoes I would make my first steps with short exposure times. You will need plenty of them and it looks irritating when there is no target object in the image but its perfectly feasible. Once you enjoy the overall process of astro photography you may take the decission how to move up in your equipment. With the recommended Samyang you won't need guiding anyway because you will get sky limited quite fast.
You may have a look at the book "Astrophotography on the go - using short exposures with light mounts" by Patrick Moore. The author shows some of his own achievements with exposures in the range 15 to 90 seconds, all of them unguided. Admittedly with some mounts 90s unguided may not be achievable but you can always split into 2x45 or 3x30s without getting too much issues.
As already pointed out I prefer a "take it easy and step by step" approach over expanding your equipment too fast and then stumbling over the own feet.
Have fun and clear skies.
Wolfgang
kuechlew
Just a short correction: the book is from Joseph Ashley, the book's collection is " by Patrick Moore" although I gather none of them were edited or read by him, main issue being he is long dead.
kuechlew avatar
kuechlew
You're right, apologies for getting this one wrong.
nickastrobin avatar
Yogesh S:
Yogesh S:
Clear Skies,
Yogesh S
ASI120MC-S (color)
ASIAIR Plus
Star Adventurer
Sony A7III
TIA!
Yogesh S
Clear Skies!
Hi Yogesh,
Thanks again for the information!
I don't own the ASIAIR as of now and might not go for it. Instead I will take the Stellarmate/Astroberry route for the reasons you mentioned above.
I did some research on the ASIAIR compatibility with my existing camera and looks like a better option is Stellarmate/Astroberry in terms of wide compatibility range with different products. I might just buy the Guide Scope and Guide Camera as mentioned above and not the ASIAIR and instead use Stellarmate/Astroberry on Raspberry Pi4. However, another thing that came up during my research on this is that EKOS may or may not be compatible with Sony A7III. I haven't heard back from Stellarmate support yet so still waiting on that confirmation.
With the Stellarmate/Astroberry (which one would you recommend out of the two for my setup and need) integration with my SA, Guide Scope, Guide camera, and Sony Camera (A7III) do you think I would be able to achieve Auto-Guiding and Dithering at the same time using EKOS/Kstars? Would I need to consider something else as well here?
Do you have any links/tutorials that I can take a look at to learn more about this setup?
TIA!
Regards,
Nick
Respectful Supportive
nickastrobin avatar
Wolfgang
@kuechlew I will definitely look into finding that book and read through it. Thank you for sharing!
kuechlew avatar
Wolfgang
Astrophotography on the Go | SpringerLink
I got the kindle edition: Astrophotography on the Go: Using Short Exposures with Light Mounts (The Patrick Moore Practical Astronomy Series) : Ashley, Joseph: Amazon.de: Bücher
The hardware mentioned in this book is no longer up-to-date but its strength is in describing the approach. I like that it is an honest book, it clearly states the limitations of light mounts and short exposures too. I believe it's a good way to get started and create first encouraging results.
Wolfgang
kuechlew avatar
Yogesh S:
Yogesh S:
Clear Skies,
Yogesh S
ASI120MC-S (color)
ASIAIR Plus
Star Adventurer
Sony A7III
TIA!
Yogesh S
Clear Skies!
Hi Yogesh,
TIA!
Regards,
Nick
You may have a look at this video: HOWTO: Make a POWERFUL smart TELESCOPE! Better than much bigger telescopes! - YouTube
For INDI drivers for your camera you may have a look at the INDI community: Tutorials (indilib.org)
Unfortunately I never got my Olympus E-M1 MkII connected in a robust way and had some general stability issues with my overall setup.  I hope you have more luck. I went for Stellarmate because the price is reasonable given the time it takes you to set up everything from scratch. Others may prefer to invest the time instead of the money.
Good luck and clear skies
Wolfgang
Supportive
Yogesh S avatar
Yogesh S:
Yogesh S:
Clear Skies,
Yogesh S
ASI120MC-S (color)
ASIAIR Plus
Star Adventurer
Sony A7III
TIA!
Yogesh S
Clear Skies!
Hi Yogesh,
TIA!
Regards,
Nick
With Star Adventurer, you can only guide and dither in RA, since DEC is manual.
Wolfgang in the comment above have provided good tutorial links. I would like to add Stellarmate Channel in to the mix as well. They provide good step by step process as well.
Clear Skies
Yogesh S
nickastrobin avatar
Yogesh S:
Yogesh S:
Clear Skies,
Yogesh S
ASI120MC-S (color)
ASIAIR Plus
Star Adventurer
Sony A7III
TIA!
Yogesh S
Clear Skies!
Hi Yogesh,
TIA!
Regards,
Nick
Wolfgang
Hey Wolfgang!
When you say you had stability issues with your setup, did you mean while using Astroberry or Stellarmate? I am planning for Stellarmate as it's 64-bit and have heard that the support is good too. Are you using SA or SA 2i by any chance? Did you run into any connection or driver related issues with your SA/SA2i (wired/wireless)?
New here! Hi from SoCal, USA
Have been doing wide-angle work (Milky Way, star trail shots, etc.), and would like to get more into astrophotography - initially using my DSLR and a reasonably-priced telescope to do planetary and DSO work - but maybe I'm asking too much. I can ...
DSO equipment recommendations directly address author's interest in affordable setup.
Aug 17, 2020
Ordered ASI1600MM-C, what else?
Hi all, I just ordered the camera ZWO ASI1600MM-C Pro few days ago and still waiting it to be shipped, so i can use it next to my QHY163M or even individual sometimes as i have 1.25" high quality filters with it to be used. I am thinking about w...
DSO equipment recommendations match author's interest in deep-sky imaging gear.
Jun 10, 2020
New to Samyang 135 f/2 and would like to get set up to use with a non-DSLR astro camera
I was interested in acquiring a Samyang 135mm f/2 (or Rokinon) to do widefield deep sky imaging. I apologize if the following questions are repetitive. It is my interest to not use a DSLR, since I do not own one that I am willing to astro modify, yet...
General astrophotography lens recommendations applicable to deep sky imaging.
Dec 29, 2020
Best M48 or M42 threaded Barlow / Focal extender ?
Hi again community, I am looking for a good quality focal extender / Barlow - is there an optical difference ? - (that don’t produce much coma). I want a fully threaded solution, as this is just for astrophotography - and just have a M48 thread at th...
Covers astrophotography equipment recommendations and optimization strategies.
Dec 23, 2020
Hello from San Diego!
Hi friends! My name is Daniel and I am just starting in astrophotography. I work as a research scientist during the day and have a background in cryo electron microscopy, which uses CCD/Direct Detection cameras and similar corrective software as astr...
Equipment recommendations directly applicable to starting astrophotography journey with trackers.
Jan 2, 2021
