Andy Wray:
Why bother if you don't have issues with your current guiding?
I do have issues with my current guiding ... it's OK, but I throw away 25% of my subs.
Sorry, I misunderstood your statement "it has worked OK". Throwing away 25% of your subs sounds severe and not OK.
Ratio of image scales between guiding and imaging setup is below 5 and should be ok. So in theory your guiding scope should be able to perfom the job. You may check whether the subs you have to throw a way are randomly distributed over your session or occur in bulks for certain orientations of your scope as I would expect when caused by flexure. In case of random distribution you may just push the limits of your overall setup.
In case you try the OAG make sure you check compatibility of your guide scope with the OAG before buying.
Good luck and clear skies
Wolfgang
