Red circular banding due to flats
7 replies539 views
Maxence Ouafik avatar
Hello everyone,
I have an issue I can't seem to fix in my latest data : after I've calibrated and debayered my subs, some strange red circular banding appeared :
I tried to troubleshoot this issue and determined it was related to my flats. You can see the same frame, dark-substracted and debayered, without any flat :
My Master Flat looks like this :
The issue is obvious when you take a look at the debayered flats (of course, I don't use those to calibrate, but wanted to see the issues in my flats)  :
While this issue may seem minor at first glance, the final stack is inusable
I tried to take new flat again and again with different source of light and ADU value but the issue is, at best, reduced.
It's the first time I have this issue and it scares me because I'm afraid it may ruin another night of imaging
Now for the technical aspects :
  1. I shoot with a ZWO ASI 533MC connected to a RedCat 51. No filter was used
  2. My subs were 5 minutes long, at gain 100, offset 70, -10°C and bin 1x1
  3. My flats were taken using NINA FlatWizard set to 50% mean ADU. I used my Ipad and a white shirt. It's the same method I always use and its the first time I have this issue.
  4. Those flats were taken at 1/10", gain 100, offset 70, -10°C, bin 1x1. I think they are a tad too short and had better results with 3 second flats (though the issue is till present)
  5. I took darkflats at the same temperature and exposure time. My flats were dark substracted to create the Master Flat. Then the subs were dark-substracted using a 5 minutes master dark and flat-substracted, using the master flat. No bias were used. Calibrate and Optimize were left unchecked. It's my usual preprocessing routine.
Any help would be greatly appreciated !
Thanks and clear skies !
Maxence
I wouldn't say that those lights are unrecoverable at all. That is where DBE comes in handy, if you know how to use it.If you post the stacked up light I'm sure we can help you there. I'd suggest you take your flats without NINA help (you are not the first to have issues with NINA's flats), at dusk pointing the scope at the zenith and away from any source of light and no significant moonlight. Inncidentally, you could use one of you previous master flats, if you keep them.
Helpful Concise Supportive
Thanks for your help!
Inusable was probably an overstatement haha
I guess DBE can correct part or most of the issue but I would prefer to fix the root cause of the issue rather than use processing techniques to make it disappear.
What concerns me is that, without understanding the cause of this issue, it may reappear during my next imaging night. And since I have very few of them because of the weather, I don't want to waste any data
However, if all else fails, I'll try my best to perform a DBE and ask for help if needed
Respectful
vercastro avatar
Try taking sky flats right after sunset. You might have some weird reflection issues and sky flats are usually fairly neutral way to troubleshoot.
If not you can use MMT with 16 layers in chrominance mode to remove colour banding. Turn off layers until the colours go away. Probably around layer 12-14.
Rick Veregin avatar
Your dust donuts are subtracting okay, which suggests your overall flat exposure is okay–if it wasn't your donuts would over or under correct. Also, the luminance looks okay over your image, just the colors are not right, forming those colored rings. If you think about it, there is no way a dust donut should be biased green or red, they block light period, so should be neutral in the debayered flat if everything is okay.  So the biased donuts seem to correspond to the colored rings you seeing in the flat.
It looks like there is a stray source of light at the center left of the flats–light is getting in somewhere, or reflecting somewhere, or non uniform in some other way, creating these concentric colored rings centered on the left center edge. They might have been some reflection from a filter, but you aren't using one.
You have done a lot right with your flats. You need to make sure everything for your flats is the same, which you have done. Exposure is usually difficult to match, but that is okay, as long as you have appropriate darks for flats and lights, which you do.
Some further suggestions for the flats, try things one at a time to isolate the issue, even if it is is much after the fact. I have rescued images with flats taken much later, when something changed in the setup during my night observing:
1) Are you in a totally dark place when doing your flats, so that stray light cannot get in? You might even want to have something that blocks extraneous light from the iPad, with just a hole cut in it for the light that enters your lens.
2) Take a few sets of flats, with different orientations of the iPad, rotate it for different flats, and see if the center of the colored circle moves around from the left edge–the iPad area may not be that uniform in brightness across the screen (even if it was in the past). You could even take a few flats with just room light, or using the sky, see if that makes a difference and gets rid of these colored rings.
3) Your average flat exposure appears to be okay. But you need to check the histogram of all colors–typically you will find the green histogram peak  is to the right, while the blue is in the middle and the red to the lower end left.  You need to make sure no histogram peaks are too close to the top/right (usually green) or at the bottom/ left (usually red) of your histogram trace. If either of those channels are in non-linear regions, or even perhaps clipped, the different color channels will behave differently, potentially causing those colored rings.
It is a process of elimination, try different things and see what happens.
Good luck
Rick
Thanks for all this precious feedback.
I tried taking some sky flats to see if there'd be a difference and the concentrinc pattern seems less pronounced :
Original to make the comparison easier (some dust motte have disappeared after trying so many things with my setup haha) :
Stray lights causing strange reflections inside my optical chain seems the most plausible answer indeed.
I'll try to isolate the cause of this issue and I'll get back to you as soon as I have !
"Fortunately" I have a lot of rainy days ahead of me to troubleshoot !
Thanks again,
Maxence
Respectful Supportive
Marc avatar
Yeah, I guess internal reflections are a possibility.
Just throwing this out here since I had my share of weird issues - any chance there is some dust on the chip? Depending on what this dust is made of, it might actually refract light. For me, I actually had tiny amount of metal flakes landing on my filters whenever I screwed my camera into my scope (tight threads, I guess). Which then seemed to have caused individual stars to look completely bonkers, with weird refraction patterns around them. After a careful dissassembly of the camera and some brushing/cleaning, those isses are now gone. But it was super-difficult to even see by eye. Now I always make sure I screw on the camera with the whole assembly being in a horizontal position… probably just superstition, but you know… smile
To give a conclusion, I was never able to troubleshoot the cause of this issue... Nonetheless, I was able to mitigate the impact on the picture with the help of DBE on separate channels. You can see the result hereif you want.
The good news is that, during my last session, I did not have this issue, using my L-extreme filter. Hope it was just a one time problem...
Flat troubles with dark corners
I'm having trouble with using flats to get flat images with a full frame sensor and 2 inch filters. Due to the large size of the of the sensor and the size of the image circle, the corners on my shots are significantly less illuminated than the c...
Red circular banding suggests vignetting issues similar to author's corner illumination problems.
Nov 9, 2020
Help with flats frames on asi 1600mm pro + 200mm f2.8
Hello everyone,I have several problems to be able to make the flats frames in the HA and SII filters im my setup (canon 200mm f2.8@f2.8, asi 1600mm-pro, filters optolong). I'm trying to use all possible types of ADU, but the image only gets worse...
Red circular banding due to flats — Flats calibration issues causing image artifacts.
Jul 5, 2020
Correct calibration workflow for DSLR
Hello masters, I am looking for a help creating a correct calibration files for my DSLR workflow in Astro Pixel Processor. I checked 2 tutorials straight from APP developers, but I still don't understand couple of things. I shoot on my Canon 6D a...
Troubleshooting calibration issues with flats in post-processing workflow.
Aug 25, 2020
About the calibration and usage of cameras with the Gsense 4040 sensor
Dear all, for almost exactly two years now we (Dr. Karl Remeis-Observatory Bamberg) are using a Moravian C4-16000 EC which houses the Gsense 4040 sensor from Gpixel for our university astronomy lab course and public outreach purposes. Initially we ha...
Discusses sensor-specific calibration issues potentially relevant to flat problems.
Feb 28, 2024
Flats wrong orientation during calibration creating dust motes?
I have run into this very bizarre flat calibration issue in Pixinsight. Just some background, I imaged a target with my Luminance filter on my 6200mm pro last night, 60s each frame, for a total of 250 frames, at gain 100, default ASIair offset (50), ...
Directly addresses flat calibration orientation issues causing artifacts.
Feb 14, 2024
