Hi New to astrophotography
4 replies115 views
Matthew Abey avatar
Hi My name is Matthew I got back into astronomy about 6 months ago to finish and update a 12.5 inch newtonian on a german equitorial mount my father and grandfather built in the early 90's. It was strictly a visual telescope then.
It was handed down to me alittle over a year ago so I made it completly autonomous from the goto drive, focuser to the weather station dew control. All using arduinos. I machined all the stepper motor mounts and any updated parts my self and I think it turned out well. I went to the black forrest star party this past weekend and captured what I think are some decent shots for such low integration times and no coma corrector with a astro modded 450d.
Im also looking for criticism on how I can image better since im very new to this. my favorite shot I took is of NGC 891 that Ill put a link below.
http://astrob.in/full/314103/0/
peleks avatar
well i am not a huge pro, but i think You need to collimate mirrors and there is a small tip for precise focusing with camera :
aim  Mizar, thats what i do, it is a nice double star for focusing
do it trough screen with max digital zoom
when you adjusted focus so You can see difraction (dont know how it is called properly) spikes on star
reduce iso by 1 step or 2 steps and refocuss again, do it so untill you reach iso 200 smile
Good luck and clear sky ! smile
Matthew Abey avatar
well i am not a huge pro, but i think You need to collimate mirrors and there is a small tip for precise focusing with camera :aim  Mizar, thats what i do, it is a nice double star for focusing
Thanks for the advice. I checked my culmination and it is slightly off. What would that cause in a picture so I can pick it up. Also I used Backyard eos for my focuse with the full width half maximum setting on the star Vega. Idk how well a small duble star would pickup on the live view but I will try.
Thanks
peleks avatar
bad collimation will give You comet like stars , to pick up  Mizar, increase ISO to 6400 or more,, but if you have already +/- focused then you can see it with 1600 very easy  smile
Matthew Abey avatar
Ok thanks, the next time I get out ill try focusing on mizar instead. I will also nail my collmination. Thanks for the advise. smile
Howdy from under the clouds of Texas!
Hello everyone! I like to consider planetary imaging as my primary form of imaging, but now that I think about it, it's in the shadow of deep sky imaging. While we (me & my father) image planets every about 85% of the times it's clear, de...
Fellow amateur astronomer with father; shares equipment and observing experience.
Nov 26, 2015
Advice for an upgrade on my EQ-5?
Hi all, my mount is supporting a newton and i'm thinking to buy a third counterweight and a new bar. What do you think about the extra counterweight and which bar do you recommend?
German equatorial mount upgrade advice relevant to his similar mount setup.
Aug 24, 2018
Welcome!
Hi all! Let me introduce myself first: My name is Andreas Dietz and I live in the geographical middle of Bavaria. I often wondered why technical equipment for stunning astrophotos always has to be in the range of several thousand dollars/euros. Espec...
Shares experience with affordable equipment setup for astrophotography pursuits.
Sep 26, 2016
Looking for advice for mount and OTA purchase at NEAF :)
Hello all! I am relatively new to AP and am using my Nikon D810/D500 with a 200-500 F5.6 Nikkor Lens. I have added a 1.4 and 1.7 teleconverter at times for some more range. At the moment I am piggybacked on my astronomy clubs C14 for image acquisitio...
Mount and OTA purchase guidance applicable to his equipment considerations.
Mar 20, 2018
Siril v0.9
Hello, I would like to present you, Siril, a astrophotographic tool that has just been released in the end of 2015. 1 - Presentation: Siril is meant to be Iris for Linux (sirI-L). It is an astronomical image processing tool, able to convert, pre-proc...
Astrophotographic processing tool useful for his imaging-capable telescope project.
Jan 5, 2016
