Doversole83 avatar
Has anyone tried the OCAL collimator on their RC scopes?
The general feedback on this collimator is good but RC scope are a bit special 🙄
The manufacturer has issued this video on how to use their collomator on RC scopes but I would rather prefer direct feedback from people here.
https://youtu.be/EB-tWVhEPTs
hughsie avatar
I have a StellaLyra RC8 and have struggled with collimation for over a year. I have probably spent more on gadgets than the actual scope itself to assist me but have to say that the OCAL and the HoTech Laser Collimator have this winter really helped in getting my collimation where it is today.
On my RC8 there is a baffle extension that needs to be removed before using the OCAL. The circles you can create and cross hair really enable you to centre the secondary and align the primary. I have used it twice and with each iteration (or should I say as I become more fluent with the software) collimation has got better.
Whilst the OCAL will get you very close to collimation, a star test is by far the best method and if you really wanted to nail collimation down then this last step is a must.
SemiPro avatar
I still find the best way is to just to use your average cheshire to rough it in mechanically, and then suffer under the stars for maybe an hour tops using the following method:
https://www.skydude.me/at8rccoll.html
In a nutshell, you adjust the primary to get a nice looking doughnut, and then the secondary is adjusted to get nice symmetrical corners. You might have to ping-pong back between the two as adjusting one can affect the other.
BONUS ROUND !!!!
Mirror spacing is kind of a huge deal for RC's. I have yet to try this, or even find a good way to do it on an RC8 but it is a factor:
https://www.cloudynights.com/topic/423163-precise-rc-mirror-spacing/?p=5461926
Edit: Looks like a decent way to use a ronchi eyepiece with an RC8 can be found here: https://www.cloudynights.com/topic/765474-tpo-rc8-correct-focal-length/
This is the best I have been able to do (so far) on an APS-C sized sensor, while keeping in mind there is a 0.8x refractor FR/FF attached to it: https://www.astrobin.com/7q69z2/
Engaging Supportive
hughsie avatar
BONUS ROUND !!!!
I have never come across the sky dude link, if only I had a lot of pain would have been avoided. Many thanks for sharing that.
SemiPro avatar
BONUS ROUND !!!!
No problem! I think consumer RC's get a bad rep because people try to collimate them like a newtonian and things start getting out of hand.  At the bottom of the page you can also find the link to variations of the same collimation method.
severinbb avatar
I came across this: https://www.cloudynights.com/topic/757247-ai-based-wave-front-sensing-and-collimation/
It provides true analysis of your collimation, and has found that perfectly concentric circles are not necessarily perfect collimation (due to central obstruction centering).
I haven't tried this yet, but I want to
Gustav Lundby avatar
I had good experience using OCAL 3. Here is my view after collimation of my RC8, without removing baffle tube. I have also the focuser tilt and a TS 2.5” rack and pinion focuser.
Last evening star test:📷 HD_23463-RGB-session_1-cbg-csc-St.jpgHD_23463-RGB-session_1-cbg-csc-St.jpg
GregsAstrobin avatar
If you have a 3D printer you can try the camera with concentric circles technique inexpensively with the DCAL, found here:
DCAL Camera Collimator for Reflecting Telescopes by Dave Aldrich | Download free STL model | Printables.com
The focus is fixed but the image is still plenty clear to do the job. I have used on a Newtonian, SCT and Hyperstar.
OCAL 3.0 Electronic Collimator
Does anyone have any experience using the OCAL 3.0 electronic collimator with the Celestron Edge 8 scope? I have one and started learning it tonight, but I have no idea whether I collimated correctly and won't know until I can get out under the s...
OCAL collimator experience with RC-type scope (Edge HD is RCC variant).
Nov 2, 2023
Something's wrong with my Edge HD 8
EDIT: I THINK I'VE GOT IT NOW. If your images look like the ones at the bottom of this post, you may need more than simple Collimation (You've probably got the secondary mirror so far out that Collimation won't work. This can happen from ...
Edge HD collimation issues directly relevant to RC scope collimation.
Sep 20, 2023
