Hi Trevor, Hope you are still following your post.
Here is my AT130 EDT as it is presently. It rides my Losmandy GM811G HD mount, with a ridged (threaded) imaging train. When I added my Pegasus Astro Falcon2 rotator I decided to go to the arduous task of making the imaging train solid.
Adding the AT 0.8 FR/FF did wonders for the image, although did reduce the FOV to 728mm at F5.6, it has fairly perfected the imaging capabilities of the telescope. Round tiny stars clear out to the corners.
I’ve outgrown the need for filter wheels, but need LP filtering, so I’ve incorporated a filter drawer at the camera face (ASI2600MC Pro). I use a quad Antlia LP filter mostly but also use an Svbony SV220 3nm filter. Both are my first adventures into multi-band filtering and I’m really happy with my results.
I hope you are as happy with your AT130mm EDT as I am with mine. I jumped from my 80mm first triplet, to the 130mm. A real leap of faith.
