Stuart Taylor avatar
I'm trying to learn Pixinsight so I've been watching lots of videos.
Two processes that most people seem to use are dynamic background extraction (which deals with gradients) and background neutralization (not sure what that does).
But they don't always do them in the same order. Some do BN first and others do DBE first.
Does the order matter?
Thanks
Eddie Bagwell avatar
I'm not an authority on PI and have probably watched a lot of the videos that you have. That being said, I use ABE and DBE first before I use BN based on the consensus of the information that I have collected from videos and vlogs.
I use ABE before LRGB Combination and DBE and BN after LRGB Combination.
I use ABE before LRGB Combination and BN after LRGB Combination.
Ok, thanks. I've not tried automatic background extraction. Do you need both then?
Sean van Drogen avatar
Have been using this for a while now
Stuart Taylor:
Thanks
I do BN first as it allows you to chose the grid points you want on DBE. I don't do "blind" DBE if I can help it unless it's a star field. BN does make the average background level at the minimum level possible and balance out the RGB values of the same.
ABE is fast and gives nice results just by using the default values. I use it on the images before combing. It doesn't hurt to use both.
Sean van Drogen:
Thanks for this. Looks v useful! I should have said I am only imaging with an OSC, so do I use the left hand branch?
Tom Boyd avatar
I almost never use BN as part of my standard processing work flow. I DBE first on an unlinked screen stretched version of the raw stack. I then color calibrate using Photometric color calibration tool in PixInsight. I will then, after decon and some noise reduction, often use SCNR to remove any remaining unwanted green. If I use BN, I use it later in the processing workflow when  I am combine datasets such as RGB and Ha and need to neutralize the background post color calibration.
Marc Ricard avatar
You should consider adding MureDenoise at the start of your workflow. It's very good at reducing small scale noise (a.k.a. Poisson noise). It's the first step I apply to my channel masters after integration. Next I crop them and apply DBE. Adam Block has created some excellent videos that explain the intricacies of the various settings of this process. If you're using a mono camera and you collect your color subs sequentially (one color at a time). You should try running DBE on each color master especially if you have to contend with severe light pollution. You can then apply background neutralization with the Photometric Color Calibration process.
Stuart Taylor:
Sean van Drogen:
That would be a good question but yes follow left hand side until the end, but most important takeaway always start with some sort of background extraction either DBE or ABE
Sean van Drogen:
Great. Thanks. So far, my workflow for OSC has been
crop
DBE
SCNR
EZ denoise
EZ soft stretch
then finishing in Photoshop with Astro Flats Pro
Tom Boyd avatar
Stuart Taylor:
Sean van Drogen:
crop
DBE
SCNR
EZ denoise
EZ soft stretch
You need to add color calibration into your flow. Calibration is done after DBE...
Ring Artifact after Background Extraction in Pixinsight
Dear community I recently got my new EQ6-R mount that finally allows me to take some nice image with my 10" Newton. So far everything works great, but I noticed a specific issue with my current setup. As you can see in the picture below, I get a...
Discusses DBE process and workflow optimization in PixInsight.
Oct 8, 2020
PixInsight Noise After Dynamic Background Extraction
Hi All, I'm brand new to PixInsight and are processing my first image in it. Totally bumbling my way around at the moment, but are excited by the potential once I learn how to harness it. After I run a Dynamic Background Extraction, I seem to get...
Discusses DBE workflow ordering, directly relevant to author's DBE question.
Oct 21, 2020
Pixinsight Dynamic Background extraction adds Color artifacts
I struggled with some color artifacts in my images, thinking it was my flats that are done incorrectly. I've done some tests with no flats and the Color artifacts are still present. After some more testing I've realized that the Dynamic Backg...
Discusses DBE color artifacts, relevant to understanding DBE process behavior.
Feb 6, 2024
