How do you manage White Balance in your Modified DSLR
Ali Alhawas avatar
Hi
White Balance : WB
I have read lot of articles recommended many ways to manage WB in modified DSLR images ..
Some saying its not important to do WB in the imaging session as your RAW files have all data ..so you can manage that in Pixinsight  or PS.
Others saying you have to do WB before starting imaging if you really want nice stars colors.. and the way to do that can be :
1- Take an image for the sky in your imaging session,, then use that as a reference to do Custom White Balance.
2- Gray card method at day time.
So ,, As you are a user of Modified DSLR .. how do you handle that.. ?!!
Fritz avatar
Hi Ali,
I go with those who manage WB in post processing. In very difficult cases i go with color calibration using star catalogs. Theli, Fluxx, and Regim - to name a few programms- can do that.
CS, Fritz
Vittorio avatar
everyone said me that with astromodified DSLR the white balance is done in post processing. White balance with gray or white card is done if you want to use your dslr during the day and save your pictures directly in jpeg.
Albert van Duin avatar
I also use WB on the stars in PixInsight, that works great. On the LCD on the camera the color doesn't look that good…
I'm using a CentralDS Astro 6D.
crazygame12345 avatar
I have an OSC Cooled CCD camera, the white balance is well done with MDL5 at linear state. First  let MDL select the original points of RGB automatically, then adjust the scaling factors to equalize the average values in the background. This method, using the Possion-like noise distribution of sky flows, is an effective method for a majority of cameras with good linearity.
Andreas Dietz avatar
Did anyone manage to achieve a good WB as described above on a combination modified DSLR + LPF (e.g. CLS-CCD)?
Fritz avatar
Andreas Dietz:
Yes, I did. When in doubt, try Fluxx: : http://www.skypixels.at/pixinsight_scripts.html (this is he newest secret weapon of the Austrian PI community, but it is a standalone application 8) )
Frank Breslawski avatar
Fritz:
Andreas Dietz:
Your link is broken...
Fritz avatar
Fritz:
Andreas Dietz:
Should be fixed now.
Thank's Fritz! Didn't know this collection of scripts before   smile
bobzeq25 avatar
I use the first approach.  Ignore white balance and just manually balance the RGB channels.
White balance is just a programmed version of doing that.  It does nothing you can't do by balancing RGB
yourself or with tools in processing programs, such as PixInsights ColorCalibration.   In my opinion that's a
better (more flexible) way to go.
I'm not aware of any way to use the camera's white balance in PixInsight.
Well Written Concise
Ali Alhawas avatar
Thanks all for your great information..
I used to do WB in the test images before I start taking my main sub frames.. the reason is to see the image in nice rich colors and good BG .. after that I can decide Exp. time , iso.. etc.
As I do not use a PC at site  smile.. I thing that is the best way to see what you will capture and give you a good idea about your sub frames..
Best Regards..
Luke Arens avatar
Andreas Dietz:
I shot a gray card in sunlight with my CLS filter in place and set custom white balance on the camera. Still have to align channels a lot in Photoshop but it seemed to help a bit.
Tom Marsala avatar
+1 on bobzeq comment. Once I align RGB in post all my worries are gone, even for the blue cast of the  Astronomiks CLS and the somewhat green-blue of the L-enhance.
lucian_nicu avatar
Unfortunately, there is no magic formula for WB. First of all, a certain value of WB may or may not look good, depending on the level of light pollution, the predominant color of light pollution, the altitude of the target, etc. Second, the overall color given by the WB is simply subjective. If I like cooler colors, it doesn't mean that your image in warm colors is not good, or vice versa. It's just a personal choice.
As for me, I adjust WB on the spot only if I have the time and desire to test different values. If I want to start the astro session and then admire the night sky while having a coffee, I set the WB at 4500-5000k and start imaging.
Comment valid only for DSLR imaging, mostly for widefield.
For cooled OSC I trust Pixinsight's color calibration. There have been only a few cases where I have had to use Linear Fit.
Michael Fleischer avatar
Hello all.
I think my answer is a few years too late, but here it is.
I take a shot of a white paper at noon when the sun is shining without clouds, with the wp setting daylight, it will appear quite reddish in your DSLR display but thats okay.
Then in my camera menu I change to custom whitepoint and select the image of the white paper just shot before, that this is my reference file for white.
Then the custom wp for my modded Canon 77d is set, and the colors for my astroimages are correct again when shooting with custom whitepoint setting active.
Cs to you all
Building a flat field box
Hello, I have some questions about creating flats. I found an article on the internet about building a flat field box. The author described that he rotates the box seated on the telescope after taking some flats for a better result of the masterflat....
Not relevant; flat fielding addresses vignetting/dust, not white balance.
Mar 13, 2019
