Patrick Stevenson avatar
I have a CGX mount that works perfectly.  I use a 60mm guide scope with an ASI129MM camera.  Some directions I point I get the message that RA isn't moving.  It says the old "check the cables or other obstructions".  I do check the cables and frequently recalibrate.  Still I get the message on my controller that RA isn't moving.  Usually I just move to another target and it works.  I am losing good targets because of this.  Ideas?  BTW, the mount was used and I got it on Cloudy Nights.
TKS
seanhagerty avatar
Are you calibrating at each new location?  I have found that PHD2 needs to calibrate guiding at each new target.  YMMV
Of course If I had read the post, I would have seen that you do frequent recals.  My bad.  I have nothing else to offer.  Nothing to see here, move along.
PHD2 problems with guiding
Hi there! I have been trying to get my mount set up with my computer for a really long time now. I just got a new EQDIR cable and the PC finally connects to the mount, so I am now able to slew it wherever I want. My equipment: NEQ6 ProGuidescope (50 ...
PHD2 guiding software issues may cause RA movement detection problems.
Mar 15, 2024
ASI Air Mini just steers into the completely wrong direction
So I just recently got the ASI Air mini. my Gear: SA GTI, modified canon eos 600D, zenithstar 61, zwo mini guidescope and mini guide camera. I wanted to photograph the soul nebula and told the asi air how to frame it with the sky atlas. at first it p...
ASI Air Mini directional steering issues similar to RA movement failures.
Sep 29, 2023
