Catalogues for how deep an image is?
13 replies497 views
Dale Penkala avatar
Hello Everyone,
I recently took an image of M106 and I’m trying to find out what magnitude 2 galaxies are in the image. They are circled in the attached image but here is a link that shows them much clearer in higher resolution. https://www.astrobin.com/i0m1c5/B/
I normally use Sky Safari Pro 7 but it only goes down to 18th magnitude and does not show the 2 circled galaxies. I’ve done a lot of net searching and best I can guess is 20-21 magnitude.
Can someone point me to the catalogues you guys use that gives you this kind of data?
Dale
Ben avatar
Rajat Kumar avatar
Hey Dale, I suppose you can also use the platesolve and annotate image tool (something similar sounding) in pixinsight. You may need to download some database. Just google how to use the tool (if you don't know, i.e.). I had once played around with it. Was quite effective.
Dale Penkala avatar
Try the CDS portal:
http://simbad.cds.unistra.fr/simbad/sim-id?Ident=m106&NbIdent=1&Radius=30&Radius.unit=arcmin&submit=submit+id
Thank you Andrea, I’m looking around the site now trying to figure out how to get the sky charts to work with.
Much appreciated.
Dale
Dale Penkala avatar
Ben:
Simbad query at the coordinates of the object you're after may be?
http://simbad.cds.unistra.fr/simbad/sim-coo?Coord=12+18+25.99996678193+%2B47+26+43.0074717368&Radius=5&Radius.unit=arcmin&submit=submit+query
Thank you Ben, The 2 galaxies are in there but are not identified unfortunatly.
Dale
Dale Penkala avatar
Thanks Mintakaite,
I watched Adam Blocks video on using it but again still can’t identify the 2 galaxies circled. There doesn’t seem to be much on using that tool.
Dale
Wei-Hao Wang avatar
Dale Penkala:
Dale
The two galaxies are on the SDSS R9 survey. Unfortunately I can't make out the numbers. I'd to rescale the image. Just add the SDSS R9 survey to the AnnotateImage script under Render (click on the big green plus sign on the left). From the SDSS survey number you'd use Vizier to get the underlying data.
I think, squinting really hard as the field is choked full of labels, these are the two little critters:
SDSSJ121822.66+472721.8
SDSSJ121832.13+472602.1
Dale Penkala avatar
Wei-Hao Wang:
Try this:
https://skyserver.sdss.org/dr12/en/tools/chart/navi.aspx
Thank you so much I’ll look at this closer!
Dale
Dale Penkala avatar
Thank you for all this Andrea! When I get back in front of my computer I’ll try this using your suggestions! I’ll see what I can find out magnitude wise!
Dale
rhedden avatar
Try this site:
Aladin Lite
1) Search on M106
2) Check the SIMBAD box in the pop-up
3) Click the green dot over the object in question.  Information will pop up.
You'll at least get a name for the faint fuzzies in question, which could lead to their magnitude with further searching.
Dale Penkala avatar
Try this site:
Aladin Lite
1) Search on M106
Thanks I’ll see what I can find out!
Dale
Enlighten Me Please
I often hear about the Hubble Palette but do not know much—can someone kindly give me a bit of a rundown? Thanks!
Concerns image depth catalogues, not Hubble Palette methodology.
Aug 17, 2020
Image Stacking and processing with IPAD
Hello everyone. I just got an ipad air and I want to process my RAW images with it. I have experiances with computers I used Deepsky Stacker and Siril. I will go to the camping in two weeks therefore I need to learn the programs you recomended in suc...
Image processing software comparison; author seeks catalog identification tools.
Sep 23, 2023
