QHY16200A desiccator
QHY Users Group 4 replies133 views
Duczmal avatar
Can someone instruct me on the usage of the desiccator gel tube with the QHY16200A camera? Does it need to be attached to the camera during all the time, or only after a photographic session, or only when there is humidity inside the CCD chamber?
Thanks in advance for your input.
Matt Harbison avatar
Hi Luiz, I've not had to use mine since I got it, but I've not used it in very humid conditions.  It is my understanding you only use it when you are concerned about humidity inside the sensor window.
Duczmal avatar
Matt Harbison:
Thank you Matt! I will follow your advice, since the humidity is usually low in my observatory.
Clear skies,
Luiz
Richard Bratt avatar
The chamber is sealed so you only will need to use the desiccator if the seal fails, is less than perfect or you open the chamber for some reason.  I had to open the chamber of my QHY23 to clean a tiny oil spot off of the inside of the window.  Excepting that, I have not had to use it again on my QHY23 (~ 2years) or ever on my QHY16200A (~6mo).  So, the bottom line is stick it in a drawer and expect to not have to use it.
Duczmal avatar
Thanks, Richard, for the useful information.
Clear skies,
Luiz
