Issue with OSC Blue Channel Noise (sometimes)
5 replies430 views
MirachsGhost avatar
I've been using this telescope, coma corrector, filter and camera for over a year. On two occasions I've ended up with some very strange blue noise in my image.
Here is a single dark corrected and debayered 240sec sub as an example.
https://www.astrobin.com/vqokyo/
Additionally, here is a blink of 80 subs.
https://www.youtube.com/watch?v=3ntoSO11Xcw
Few more notes:
1) This happened to me one other time, but it was a different filter (broadband vs narrowband)
2) Flatts don't seem to have an impact. Flatts do remove the vignette and dust moats, but do nothing for this issue.
3) I gathered data on a second target this night (M78 ) with no issue.
4) This is from PI, but I have checked using Deep Sky Stacker and Siril and they give similar results.
Any thoughts?
Thank you in advance and clear skies!
Nathan
Well Written Helpful Engaging
jewzaam avatar
I want to say I've seen this when there's a strong source of light causing reflections or leak in the imaging train.  I have not seen it specific to a particular channel.  Maybe a strong light source nearby with blue or some way that only blue leaks into the imaging train?  Just thoughts off the top of my head.  Good luck!
Respectful Concise
It looks like an issue with the filter, which might happen with steep light cones, with maybe a slight tilt of the filter. The pattern has all the hallmarks of an issue with dichroic filters transmission.
MirachsGhost avatar
Thank you.  The filter drawer I use has a little vertical play. Not a lot, maybe 1mm. What about flex between the coma corrector and the focuser draw tube? Is f/4 fast enough to cause these issues? Sorry for all of the follow ups. I've been fussing with this data since November, and starting to go mad. Just strange that it isn't every image with this setup.
Thank you again.
1mm play is plenty to give this sort of issues at f/4, which I reckon is similar to that causing newton's fringes. I don't believe that flexure is a more likely explanation but I can't rule it out as I'm not there. In my imaging trains with similar cameras and filter holders nothing of that sort has ever happened.
daywalker avatar
process of elimination i guess… remove filter draw if you can mount the filter elsewhere in your image train .
Best wishes 2u.
RCC: Please critique my dumbbell nebula (I’m new to mono imaging).
Hi all, I’m new to mono imaging and would like some honest feedback about my latest image. I use a very basic, straight forward SHO workflow in pixinsight. I usually struggle with stars and my background. In this case, I feel like the whole image jus...
Jul 14, 2025
Both posts describe astrophotographers encountering unexpected and problematic visual artifacts or anomalies in their captured images that they're seeking help to understand or resolve.
Flats undercorrecting vignetting
Hello all! I'm facing issues trying to calibrate my light frames with flats, they seem to be undercorrecting the vignetting on the frame: The equipment I'm using is the following: - Modificated Sky-Watcher Quattro 250P OTA - Sharpstar 1x GPU ...
Aug 6, 2025
Both posts discuss technical issues with astrophotography equipment and image processing problems.
Dark bands at top and bottom of Minicam8M
EDIT: QHY support responded with the following statement: “We can basically confirm that this phenomenon stems from the light-gathering limitations of the Minicam8M sensor structure at extremely fast focal ratios (F4), rather than from mechanical obs...
Nov 8, 2025
Both posts discuss technical imaging problems with astronomical cameras and equipment troubleshooting.
