Hi Niall!
Here are my most recent GRS-centric (so to speak) images of Jupiter.
All using a similar setup: a Celestron C11 classic, at f/25 or f/20, all RGB integrations, using an ASI290MM cooled camera, and an Astronomik RGB filter set.
Conditions are very variable, but with seeing generally in the "good (3/5)" to "fair (4/5)", since usually the worst seeing nights does not result in images I botter sharing…
The color balance is variable too, even as I try to keep it similar, with presets in PixInsight and PS5, and without tinkering on the ASI settings for that matter.
Probably came from the sky conditions.
I integrate three to four sixty seconds individual channels images using WinJupos, for R, G and B, and combine them for a total interval of 10 minutes for each final image.
Some of my brazilian friends, which you contacted too, are willing to contribute to this project.
