What ist the best light pollution filter for EAA with OSC out of a bright suburban sky (Bortle 6) --> 50% LED-lights/ 50% High Pressure Sodium-lights
5 replies1.6k views
What ist the best light pollution filter for EAA with OSC in combination with a fast (f/2) optical system out of a bright suburban sky (Bortle 6)? --> 50% LED-lights/ 50% High Pressure Sodium-lights?
Multiple choice poll 51 votes
8% (4 votes)
8% (4 votes)
31% (16 votes)
29% (15 votes)
8% (4 votes)
2% (1 vote)
4% (2 votes)
4% (2 votes)
6% (3 votes)
0% (0 votes)
Bernhard Suntinger avatar
What ist the best universal light pollution filter for EAA with OSC ZWO ASI 2600MC and Hyperstar Celestron C11 that can be used for any kind of astronomical object (stars, nebulars, galaxies, PNs, etc.)?
The streetlight are 50% LED-lights and 50% High Pressure Sodium-lights.
Has anyone experience with a fast (f/2) optical system and EAA light pollution filters?
Dale Penkala avatar
I do not shoot at f2, but have used the Optolong L-Pro for as fast as  f4 with what I feel is very good results. It is my go to filter and shoot with it 80% of the time and the other 20% I use my IDAS NBZ filter for dual narrowband imaging.
Dale
Concise
FredAstro avatar
In m'y backyard i have this kind of environnement.
Generaly i use the ZWO dual narrow band filter for Nebula and the optolong Lpro for Galaxy.
astrodawg avatar
Bernhard Suntinger:
At F2, I’m not sure how well the L-pro will work due to the angle of incidence at that ratio. The hutech light pollution filters like the IDAS-LPS-D3, have “flat top” cutoffs of the band passes, which is more conducive to F2. When you get to that ratio it does change the conversation.
Juan Fernández Martín avatar
I'm using the Optolong L enhance with a F5 small refractor, under suburban sky, with good results for emission nebulae. Best wishes.
AstroRBA avatar
Bernhard Suntinger:
Hi - I used to have that exact set up. You'll have trouble with any filter at F2 - The L-Enhance and L-Extreme are the worst. I'm in a bad B8 and I finally just stopped using filters at F2 BUT the L-Pro was probably the least troublesome. If you're using ShapCap for your EAA, the gradient removal tool works ok sometimes (it's an option under "Pre-Processing" and "Background Subtraction"..
Interference-Style LP (Maybe even enhancement) filters, Fast Short Optics and the Problem with Long Period Variable Stars! Lesson Learned?
The following is something that I just posted with my last image, since it is relevant to the data generated and processed. I am partially reposting here, and changing where appropriate to those who may not see my image Rosette West Widefield - In OS...
Discusses LP filters with fast optics, directly addresses your f/2 system concerns.
Feb 18, 2024
Experimenting with dual band filters
Hello everyone, I've recently added to my Newton 20cm f/4 + ASI2600MC a filter wheel with two 5nm Antlia Dual Band filters, one Ha-OIII and one Hb-SII. Another slot of the FW has an old IDAS LPS-2 (light pollution suppression). The idea is to acq...
Explores dual band filters for OSC camera similar to your ZWO ASI 2600MC.
Mar 2, 2024
