Can't source these rings in my images.
21 replies689 views
Dan Vranic avatar
Hello!
Was finally able to complete the replacement of the primary cell of my AT130EDT and all of my chromatic aberrations have disappeared, but now its time to tackle issue #2.
I get wild rings in my integrations regardless of filter and I can not seem to source them.
Initially I had thought it was caused by bad filters, so I exchanged filters and reversed them too. No real change there, and in my filter-less star tests since getting the new primary have really showed me that the filter/corrector is not the cause.
I am at a bit of a loss as to what is causing these and would LOVE to have some help on this.
Could it be light spill? I noticed it is dark and light on the sides.. could this be tilt too?
I have attached three images - I have attached a few images -  the first is the single sub. second is the raw stack, third is after DBE, and then there is the master flat and final for inspection too.
As you can see, these rings are extremely difficult to process around, and hoping to have some answers.
Thank you!
It is just vignetting.  Nothing to be much upset about. Or that you can do much about it, either. But you can correct it in post, most often, if the there is enough light coming through . What camera and imaging train were you using?
James Ross avatar
What does your sensor face look like? It seems like there's a lot of dust on the camera window at the very least. How are you taking your flats? I can't really see the larger ring structure in the lights so maybe something is going slightly wrong with your flat calibration, or else DBE is getting it wrong - there is quite a strong gradient present in the raw sub so you have to get the DBE sample points correct.
Tilt I'd expect to show up as defocused stars in one or more quadrants of the image, not as this larger superimposed ring artifact.
Martin Palenik avatar
Any reflections around the focuser, flattener, ring border, maybe some matte black paint?
Andy Wray avatar
It looks like you have dust on your sensor plus some vignetting.  All of that would be removed by taking decently exposed flats.
Well Written Concise
Dan Vranic avatar
Andy Wray:
Please see Masterflat attached..
Dan Vranic avatar
James Ross:
Definitely dust.
I use an LED panel and some diffusion. Worked for a few years but seems not to be anymore.
Benny Colyn avatar
Guys, OP is not talking about the dust donuts. It's the under/over correction of the vignetting that this is about.
I'm thinking either
  • whatever is limiting your light cone has a little bit of reflection going on or
  • your optical train - likely the focuser - has a some play causing the flats not to match 100% with the lights.
Insightful Concise
Dan Vranic avatar
Benny Colyn:
I'm thinking either
Appreciate your reply man. I have posted this same question in 4 forums today and everyone has focused on the dust motes and are ignoring everything I am saying about my setup. Even had someone on CN get all high and mighty that I was not using a Newt right.... The AT130EDT is not a Newt lol.
When you say "limiting the light cone" what does that mean? I have a new flattener from a different company on the way to test out some theories too.
Andy Wray avatar
What was the ADU on your flat images?  I tend to aim for around 13,000.   Just wondering, because it looks like they are not compensating correctly when calibrating.
Dan Vranic avatar
Andy Wray:
What was the ADU on your flat images?  Just wondering, because it looks like they are not compensating correctly when calibrating.
I use the Auto-Flat feature of the ASIAIR -
around 32,000. It is a 16bit camera so that is what I thought was appropriate
Benny Colyn avatar
Dan Vranic:
Benny Colyn:
I'm thinking either
=> you may get better responses with the phrases "overcorrection" or "under correction". The "rings" isn't very clear unless you look deeper (by which time many have already hit "reply").
=> ultimately, something is constricting your light cone (from the objective lens to the sensor) and causing lesser illumination on the edges, it is unavoidable with any optics unless your image circle is severely oversized (at which point, I would rather say your sensor is too small and you are throwing away good part of your FoV, but I digress). With a quality APO, that usually should be the baffles in the OTA. Those are thin and should not reflect any light. But with a reducer, you often see (an edge of) the reducer becoming that limiting factor that cuts into the light cone and causes the "edge" on your masterflat. Or it can be the edge of a filter in your optical train. If those are shiny you end up with this. I had a very similar looking issue not too long ago. To cut a long story short, it was a bit of reflection likely from the filter mounting cell. Swapped those out for bigger, unmounted filters and both the vignetting decreased but also the "ring" went away. That's just an example, it could very well be the edge of your reducer/flattener or poor baffling in the OTA. Have a look down the OTA with everything mounted except the camera an check for anything that glitters when illuminated from the front (through the objective).
Helpful Insightful
Dan Vranic avatar
Benny Colyn:
Dan Vranic:
Benny Colyn:
I'm thinking either
Great idea! I will give that a shot. There are baffles all the way down the tube I believe.
Andy Wray avatar
Sorry, I obviously responded too quickly without really thinking through your original question.  You have some really serious vignetting in your light train somewhere.  I thought mine was bad, but yours looks like something physically blocking light in the train.  Maybe some more info about your equipment setup would help.  Camera, filter wheel/drawer/size, where the filters are in the train etc.?
Respectful Concise Supportive
Dan Vranic avatar
Benny Colyn:
Dan Vranic:
Benny Colyn:
I'm thinking either
So, my focuser tube- just the edges- glint and sparkle..
how does one fix that?
Your focuser's end does not glint or sparkle. Don't know where that came from but it is not what's happening. If it were you would paint it over with black opaque paint. But it ain't yer problem.
Dan Vranic avatar
It does - I just saw it myself only a few hours ago.
It is only the outer edge, facing out of the scope. I can see how an LED panel could cause that to reflect back during flat acquisition.
If you used proper flat technique any such thing, even if it existed, would be taken care by the flat. What the use of the flat if not for those instances?
Dan Vranic avatar
Because LED panel is so bright and leaning right on the OTA - it could very well be "over-illuminating" that focuser tube versus when it is actually in an imaging session. Thus the flats would over compensate and leave a ring.
This is the working theory currently.
So it is poor flat technique the real culprit, not whatever exists in the focuser, isn't it? You'll be better off using dusk flats which is always the recommended technique anyway. Incidentally that "flat panel" might not be that flat and should be some 20 times the focal length of the scope away to try and reproduce the "sky" conditions.
Concise
Götz Golla avatar
I had a similar problem with rings last year. Therefore just an idea what might have happened:
It looks to me like your flat is slightly misaligned/shifted in east-west direction. The flat has a steep slope on the edges, thus with a slight misalignment you get the darker overcorrected ring on the left and the brighter undercorrected ring in the right side. This could have happened if you moved the focusser inbetween the lights and the flats  and the image shifted a bit (this is what happend to me last year). Also some other misalignment might have happend.
As I said, just an idea…..
Götz
Dan Vranic avatar
Götz Golla:
As I said, just an idea.....
Götz
My focuser did have the littlest bit of play in it.. so I did fix that too.
I got a diffuser cap to take sky flats with in a couple of days, so I will report back!
