Best ISO for DSLR-Mirrorless
13 replies642 views
David avatar
Hi all,
I'm not sure to be in the right section, and I haven't read anything about this here.
My subject is how to choose the best ISO setting for AP with DSLR/mirrorless (the best compromise with read noise and dynamic range I think).
It would be interesting here :
- to have a feed back of the ISO you are currently using with your camera
- to have advice of electronic engineers, you are some here in Astrobin, to choose the best ISO depending the camera we are shooting with
- share informations to improve our photons chasing
Here are some interesting links :
http://dslr-astrophotography.com/iso-dslr-astrophotography/
http://www.sensorgen.info
About me, for now I'm shooting with a sony A6000 at ISO 400. I'have read it's the best choice for this camera.
PS : sorry for my english ;-)
Clear skies
David
Björn Hoffmann avatar
Hi David, I have the same setup as you and I use it quite similar. I usually work at iso 800, but I use the Samyang 135mm at f2.8 so in the end I have the same amount of light as you. However, I typically only use 60s and even this will now change to 30s due to the star eater problem, at least until I did some testing. There are a lot of information out there about best sensor performance and I believe that most of them will point to 400-800.
Gary Plummer avatar
I use a Sony A99 and also shoot ISO 400, made my choice based on the information at sensorgen.
David avatar
Thx for your answers !
I just bought a second hand nex-3N, an old version without "star eater" option and with micro USB port to plug an intervalometer.
So, with this camera, without autoguiding for now (maybe later…smile, my best choise should be 60 sec at 800 ISO !?
Marcus, I'll certainly ask you for advice to astromod this camera ;-)
To go back to the purpose of this discussion, it might be interesting to draw up a list established by Astrobin members with best settings for each DSLR/mirrorless camera, don't you think ?
For example, with the Sony A7S, best ISO seems to be 2000, with 30 sec exposure to avoid star eating.
Jeff Weiss avatar
Any recommendations for Canon M1 or M3?  I've been using 800 or 1600 but not sure about that.
-Jeff
bobzeq25 avatar
The original poster has the right idea.  You shoot at the lowest ISO you can, without running into large read noise.  Better dynamic range, better star color.
The ubiquitous early Canons need to use 800 or 1600, lower ISOs have too much read noise.  Newer "ISOless" cameras can generally use 200 or 400 (for some reason lower than 200 is often strange).  You gain nothing by going higher, unless your tracking is a limitation.  That's where I image with my newer Nikon D5500.
intermediate ISOs are often strange, your best choices are the standards, 200, 400, 800…
The Sony star eater problem is a wrinkle I'm unfamiliar with.
Helpful Insightful Respectful
Gary Plummer avatar
Interesting to see Sony also have a star eater, I thought it was a Nikon specific problem! Albeit most Nikons now have Sony sensors.
David avatar
Here are some tests to find best ISO for astrophotography with different Sony cameras.
I followed the method of Ian Norman's article
Results, according to my tests, best ISO are :
- Nex-3n : 800
- A6000 : 800 or 1600
- A7s : 3200
Both Nex-3n and A7S are modified (astrodon)
Siegfried avatar
The big peak of Histogram (Background) should come of 20-30% from left side
(Dark), and the brightest object should not be overexposed. At my given
Skyquality between SQM 20,3 to 20,90 I use on most Objects ISO400 and
ISO800 at F/4 and 4 minutes exposure time.
To reach such long exposure on a bigger Telescope (I use a 800mm Newton Telescope) you need guiding too…..
On Samyang 135/2 I often use ISO800 and 60sec.. at F/2 without guiding.
Siegfried
dave80s avatar
Nikons from D5300 through D5600 ISO400 seems to be the sweet  these all have a 24MP Sony sensor.
Dipl.-Ing. Jörg Woker avatar
Hello,
with may canons I use 800ASA max due to noise. I have the 10D(a), 20D(a) and 1000D(a) for the night and various up to 1Ds MkII and 50D for daylight, also an 'M'.
If quality is not the main issue also ISO-auto works properly with the newer cameras, except the "high-iso" is activated, but even in available light situations actively I don't apply more than ISO 800. For me thats the best compromise between speed and the work to do preparating the pictures for use (noise, colours, contrast and the felt sharpness). Those cameras with ML on them seem to perform a little bit better, if it is my imagination or technical reality, I don't know. The ML-intervalometer is useful in every case.
Joerg
bobzeq25 avatar
Depends on the read noise.  The lowest ISO you can use is best (better dynamic range), but early Canons have unacceptable read noise at low ISO.  With them you need 800 or 1600 to get past that.
My D5500 is "ISOless', the read noise changes little with ISO.  So I can use 200.  I'd use 100, but for some reason, that ISO is strange.
There's no gain in sensitivity by going higher, but there may be other issues.  I use 400 on my camera tracker, just to shorten the
exposure.
Matthieu BUI avatar
You should take care when shooting with a sony camera. On MK1 A7 series star eater is activated when shooting on bulb mode. Since the MK2 series you cannot shoot over 3,2s.
Using the Histogram as an exposure guide
Still trying to learn some of the basics but how effective is using the histogram at determining exposure length? Some of my early attempts have the histogram peak going above the max "y" value on the graph, hence maxing out that region. I ...
Histogram exposure guide relates to ISO optimization for astrophotography exposure settings.
Mar 12, 2017
First DSO Camera suggestion required
Hi, I have Sky-watcher 130 PDS & 60 mm APO Refractor telescopes with iOptron ZEQ45 PRO Mount. Have ZWO 290 MC camera which I use for Planetary & lunar surface imaging. Want to move in dedicated DSO imaging. I live in the red-zone light-pollut...
Camera selection discussion includes ISO considerations for different astrophotography equipment choices.
Sep 1, 2018
