Flying with gear, any issues with TSA?
8 replies732 views
Chase Newtson avatar
Hello fellow astrophotographers!
I am traveling to Florida, and will not have a checked bag.  So, since Minnesota has been very cloudy and very negative the past two months, I was looking to bring my Skyguider, camera and lenses with my tripod to get some data from not so negative temperatures.   Now I know as a general, photography and accessories are not an issue when it comes to TSA for carry on luggage.  My main concern is my latitude wedge, I have the William Optics Latitude base, which is a decent piece of machined metal.  I have never brought something like this onto a plane, do you think this could be a cause for concern with going through security?  This is my first time traveling by plane with gear.
Also, feel free to mention any travel stories you may have!  Anything to prepare me haha
Thank you all,
Chase
Arun H avatar
I took an iOptron Skytracker Pro with me in carryon baggage for the 2017 eclipse. Complete with counterweight and bar. I was asked to open my bag so they could see what it was. Surprisingly, the TSA security guard knew what the counterweight was for and I had no issues both ways! Similarly, I have taken my Fornax Lightrack II and wedge with me in carryon with no issues.
Well Written Helpful Concise Engaging
Thank you for the reply!  I am leaving my counterweight at home for this trip, and it's nice to know they didn't have issue with a 3 pound counterweight!  My 2 pound wedge should hopefully not cause an issue then!  I will update back if there is a story worth telling XD
Thank you Arun!
-Chase
Poochpa avatar
I flew last month from Buffalo, NY to Tucson, AZ with a tracker mount and the WO latitude base, as well as a scope, camera, lenses and accessories and had no problems or even any questions.
Mike
Bill McLaughlin avatar
OK, this will not be helpful but is amusing. There was a story, a few years ago, that a photographer was carrying the common air puffer lens cleaner, the Giotto Rocket Air Blaster (I have two, they are great for puffing off filters in a filter wheel) and they confiscated it because "it looked like a grenade".  Never mind is is rubber and plastic.
Alex avatar
I'm an electrical engineer for a large equipment manufacturer.  I often travel with tons of electronics, some very unconventional, and I've never had a problem.  What I have found is if I put it in checked luggage, then it will get a "random" search and inspection.  This usually isn't a problem, unless you are concerned with them repacking your luggage in a caring, secure manner.  I once opened my duffel bag to find the glass jar Yankee Candle that I had packed securely was sitting on top of my luggage and had shattered all over my clothes.  This resulted in me picking glass out of my skin and feet from all the pieces that fell onto the floor and got lost in the carpet despite all the cleaning I did.
Due to the fact that checking luggage leaves it up to an anonymous person somewhere, I tend to shove all the electronics into my carry on bag if I have anything fragile to prevent an unfortunate discovery upon reaching my destination.  I send my carry on through the security checkpoint scanner, and about half the time I have to take it out and explain what it is.  I don't like to be in a rush, so I usually get to the airport an hour or more before boarding time (except at little tiny airports that I can get through in 5 minutes).  So when they ask me what is in my carry on I calmly and politely explain what each item is and what I do for a living since I am not rushing to get to my flight, and I've never had a problem except coming back into the United States from a foreign country where they want to take the swab to my equipment.
That said, for my mobile astrophotography setup I have a Pelican case for my camera, SkyGuider Pro, and all accessories that is small enough to be carry on luggage.  Having everything packed together neatly and not in a big heap like when I am traveling to the field for work helps as they can see each item instead of a bunch of things stacked on top of each other that the scanner can't penetrate.  As much as I dislike the TSA, it's a fairly thankless job most of the time, and the employees are just people.  I always offer a smile, hello, and chat while going through the checkpoints, and I think that more than anything helps.
I just got back from the trip, and both ways I had zero issues, no checks or anything.  The security in Florida appeared to keep my bag in the scanner a bit longer than normal, but ultimately no issue.  This was nice as I have a history of getting random checks in the past haha
Bill McLaughlin:
haha, that's interesting!  Glad I didn't bring mine!
Alex:
Alex
Yea, I do feel much better now that I have gone through my first flight involved trip with gear.  I do need to invest in a decent Pelican Case for this stuff!  I have one that can fit only the essentials, that I use to bring the gear up to the Boundary Waters on a canoe.
-Chase
Mike Butorac avatar
What about batteries? I will be flying with a Celestron PowerTank Lithium LT. I think I do need to keep that in my carry-on, but I'm hoping that won't be a problem.
Mike Butorac:
Hi Mike, I did a quick google of your powertank and you should be fine with no issues.  You definately will need to keep that in your carry on, but the TSA rule is up to 100Wh, and 101-160Wh with airline approval.
Hope that helps, and safe travels!!
Helpful Respectful Concise
First Astrophotography Setup
Hello fellow astrophotographers! I am excited to venture into the world of astrophotography and have been diligently researching and assembling my first setup. I have some prior experience with photography using a Nikon DSLR, but now I'm eager to...
Beginner setup advice may help with portable astrophotography equipment choices.
Jul 25, 2023
Compact Astrophotography Mount
Hi fellow AstroBinners! I am a begginer in Astrophotography, my dream is to shoot galaxies with long exposures to get the details. So I am looking for a setup to achive that. At the moment Im using a small EQ mount, with a tracking motor that plugs i...
Compact mounts relevant to travel astrophotography with limited luggage space.
Nov 2, 2023
Questions about autofocus with the Rokinon/Samyang 135mm f/2.0 ED UMC
I am looking to expand my travel rig and add this lens for a wider field of capture. In particular I would pair it with my QHY 268MC, C-sized camera. I have noticed a couple of mounting setups, each of which include mounts and connections that pair w...
Travel rig expansion directly relates to portable astrophotography setup planning.
Aug 7, 2023
