Seeking advice for shooting Witch Head Nebula (IC 2118)
4 replies274 views
Crimsus avatar
I am gradually getting more involved in amateur astrophotography. I've done some nice acquisitions (haven't had time to upload more, I just have one uploaded now). I really like the Witch Head Nebula ( IC 2118 ). I want to make IC 2118 my next night of acquisition, but I am seeking some advice on getting some good sub-frames. What I am looking for specifically are some recommendations on exposure and ISO settings based on the past experience of others. I had some great results with the Flame and Horsehead nebulae with an exposure of 240s at ISO1600, but I have read that the Witch Head Nebula can be a little tricky. Weather conditions permitting, I intend to do about 2 hours of total acquisition.
I am currently using the following gear (I haven't found a money tree yet, so it's the best that is available for me):
Canon 90D (astromodified)
Canon 70-200mm f/4 L series (will probably shoot at 200mm @ f/5.6)
iOptron Skyguider Pro
ZWO ASI120MC-S w/ZWO mini guide scope
BackyardEOS, PHD2, Pixinsight 1.8.8-12
Martin Doppelbauer avatar
The witchhead nebula is notoriously difficult because it is quite faint and right next to a bright star (Rigel).
I have shot 2 min subs at ISO 400 with my EOS2000D.
See here: https://www.astrobin.com/va3yda/?nc=&nce=
Well Written Insightful Respectful Concise Engaging
Brian Boyle avatar
Hi Crismus,
Welcome to the hobby.
The Witch Head is a much tougher target that the Flame/Horsehead - and it is starting to get a little late in the year, so you will have to chase it into the west.
The set you have looks fine for the Witch Head and the proposed sub-length is good to.
However, the critical thing for the Witch Head is the brightness of your sky.
I image from Bortle 3, and here is a 2hour image I took at f'5.5 (admittedly with a 100mm refractor) https://www.astrobin.com/ldtju1/?nc=&nce=
Here is an another image I took at  200mm but at f/2.5 in 3hours.  https://www.astrobin.com/d2zf27/
I also tend to take slightly shorter subs, simply because I am always sky-limited, and CPU/disk space is not so much of an issue for me.  More sub = better rejection as far as I am concerned.  Also a tracking/guiding error results in the loss of a shorter exposure.
If you live in roughly similar conditions to mine, you should get something like the 1st image in terms of SNR, but closer to the 2nd in terms of resolution.
If you live in brighter sky conditions, it will be increasingly tough to get a decent image in 2 hours.
You may wish to leave the Witch Head for next year, when you can get a longer crack at it.  There are some. lovely bright DSOs (Rosette, Seagull) just a little further to the East.
Good luck and clear skies!
Crimsus avatar
Brian Boyle:
Unfortunately I'm going to be at a Bortle 4 location. There are some darker areas around the region, but they aren't exactly safe at night (crime).
I actually did Rosette for Valentine's Day, so I've got that nebula covered for the year. Yeah, it is late in the year, but unfortunately weather, COVID, and other issues have prevented me from getting out to do shots in December.
Thank you for the info!
Brian Boyle avatar
Bortle 4 is still pretty good….
Andromeda in a bortle 6, should I use a light pollution filter ?
Hello forum, I am planning on shooting Andromeda next week. It will be my first attempt at a galaxy. I recently bought a Optolong L-Pro but haven't had a chance to try it yet so I really have no idea how it will affect my subs. I am wonderingR...
Light pollution filter advice relevant to nebula imaging acquisition planning.
Dec 1, 2023
Preparing for comet aquisition - need some advice
Hi to the community, lately I tried for the first time to get some images of a comet with a guided sope. Although I was kind of successful, there are some questions that arised. There are a lot of processing tips out there, but the process of data aq...
Comet acquisition guidance applicable to nebula sub-frame acquisition strategies.
Feb 16, 2024
Benefit of shorter exposures?
Since I got my ASI533MC-Pro, I've usually been using 300s exposures, although I have seen many other people using shorter exposures, and getting low-noise images in a fraction of the time I am (With similar sized telescopes, a 130mm F5 reflector)...
Exposure duration discussion directly relevant to author's exposure settings question.
Feb 12, 2024
