Polemaster vs TPoint for polar alignment
5 replies546 views
Patrick Graham avatar
I've just purchased a Polemaster polar alignment camera to use in conjunction with Software Bisque's  SkyX-Pro TPoint modeling software.  I'm using the Paramount MX+ mount and I most always get Excellent polar alignment results from the accurate polar alignment tool in TPoint.  I'm still getting some star trailing after about 3 to 5 minutes of exposure time, though.  I'm thinking Polemaster might help eliminate this by fine tuning the PA.  The questions are:
1.  Should I polar align with Polemaster first, then accomplish a TPoint run with or without their accurate polar alignment tool?
2.  Run the TPoint  first with the accurate polar alignment and then fine tune it with polemaster?
3.  Box up and return the polemaster as maybe I'm working against myself here and  just should use one or the other?
It seems to me that the polemaster would be more accurate as it is mounted directly to the RA Axis of the mount.  TPoint gathers data through the optics.
Please share your thoughts and experiences.
Patrick
Andy Wray avatar
Personally I don't use either.  SharpCap in conjunction with my guide camera works just fine and only takes 5 minutes to get really good polar alignment.  Mind you, I'm on a much cheaper mount so probably wouldn't benefit from more serious kit.  That said, I believe SharpCap and a decent guide camera/scope would probably do as well as anything else given seeing conditions.
Linwood Ferguson avatar
When i had a MyT I liked tPoint.
I'd suggest doing that and a Accurate polar Alignment gets you close enough, but if you want even more precision do a tPoint with 16 points or so (pretty quick) and see how close it says it is, iterate if needed.
At some point do a 200 or so tPoint model, you can recal it each night with a dozen or so and check polar alignment at the same time.
It's probably not faster than Polemaster, but having the model will help other things (especially unguided but even guiding), and the recal lets you reuse it, which you don't get with polemaster.
Bear in mind there is no such thing as a perfect alignment; if you look at tPoint's screen it shows there is one for minimizing DEC drift, one for minimizing total drift, one for the true pole, etc…. something like 4 choices you have.  Mutually exclusive.
Helpful Insightful
Chris Bailey avatar
TPoint all the way. I run a 450 point model and easily do 30 minutes unguided.
Thanks to all who responded.  I'll stick with TPoint  and increase my sampling.  I'm only doing 100 to 150 samples.
Pat
Monty Chandler avatar
Personally I love my Polemaster's.  One on each eq6r.  Fast, repeatable and dead on accurate.  The precision is amazing if you take the time to get it dead on.  Close is not god enough.   I put the points of each tripod in the exact same place (indentations drilled into concrete for marking).  Only very minor tweaks are usually needed.  No trailing - guide at .6" (assuming no breeze!)  cheers
Mount or software sometimes reporting wrong PA when PA is correct.
Odd issue. Can't figure it out. ASIAIR (or mount) seem to be reporting wrong stats sometimes. I'm hoping this is a known issue someone has had that has an easy fix. I really love using the ASIAIR Plus and have no other issues with it. If this...
Mount or software reporting wrong PA when PA is correct — relevant to PA accuracy issues.
Sep 10, 2023
I have two polemaster adapters for the MyT
Hi everyone, I purchased a MyT about 14 months ago and have just now started using it and getting to know the mount now that I built an Observatory to house it. I had a friend of mine @Joseph Lupicki made me a polemaster mount for the front of the mo...
I have two polemaster adapters for the MyT — directly discusses Polemaster usage and experience.
Jan 13, 2024
Getting started with a small mount.
Hi Everyone, I've taken a few images now and i am enjoying it. I'm not yet ready to buy a telescope, but I am ready to buy a small portable astrophotography setup. I am thinking of the following iOptron SkyGuider ProZWO ASI290MM Mini CameraZW...
Directly addresses polar alignment tools author is evaluating for their astrophotography.
May 25, 2020
Star Adventurer - Sporadic or intermittent star trails
Hello, I just got a Evostar 72ED (420mm) which I'm using on a Star Adventurer Pro Kit (no guiding) + Sony A7III. Looking into my light frames I noticed that while 60% of my subs are great (which means I got a pretty good PA), I get a significant ...
Polar alignment discussion relevant to author's PA concerns and star trailing.
Sep 27, 2020
