I have seen in the forum, there was an initiative by Salvatore for imaging collaboration: Choose a target together, share raw, and everyone can process own picture. The advantage of the common work could be for example that also very dim objects can be targeted
It seems the original topic is not working at least I found only old entries.
Anyway I re-started the thread especially here in the SCT group, because I think this collaboration could work more effective, if the team members have similar equipment, similar FOV, similar resolution, and for example the C8, C9, C11 owners (or same size other manufacturers) could collaborate more effectively.
If you think this has sense, suggest a target or share any idea which could make the work easier.
Cheers, Peter
(C8 EDGEHD, AtikOne6)
Cheers, Peter
