Running a 19.5 lbs William optics Ultracat 91 setup on an AM3n with ZW0 TC 40 tripod to make the heaviest “travel scope” I would run.
I’ve heard folks complain about carbon fiber legs and say I should instead go for the steel. But I’m assuming my setup isn’t too heavy?
I also purchased the ZWO PE 160 lightweight pier extension. Says it has a maximum weight capacity of 26-28 lbs, some folks suggest 22 lbs so I’m right below that. Should I have gotten the pe200?
I also have vibration suppression pads from celestron. And a 7.5lbs counterweight to use. I should be fine I assume?
