12” newt, OD of the OTA is about 14.25”/362mm. so I am figuring I should opt for a 400mm panel, yeah? 3nm antlia SHO, LRGB in the wheel
I was considerin6g the wandererastro White Dwarf Flat Panel 400mm (manual knob $370), or the gemini panel (dimmable, usb, like $270?).
I can’t spring for much more than the wandererastro in terms of budget (kinda stretching it already), but the manual control took me for a quick pause. I currently just leave the large A2 light tracing panel at one brightness and vary exposure , but I have to use 3 tshirts to dim it enough to get decent exposure times in LRGB (not too fast, there is banding for sure on the panel at too fast exposures) and the panel itself is unwiedly / showing age in the short time I’ve had it.
But the gemini I may have seen one report of illumination falloff to the edges, but that was also the flip down motorized panel and I can’t tell differences between various flat panel models. Guess I’m fine with a manual knob as long as the panel itself is a good one to go with and has no weird variability, given i’m already varying exposure instead of making adjustments to brightness.
Anyone have advice, maybe just that the wandererastro is a fine choice, flicker free, good, even, etc? Or to consider something else? Just looking to avoid making a mistake when spending a good chunk of money to ease my current problems.
