Hi all,
I’ve recently acquired a new-to-me ED 127 FCD-100 Aluminum with the 2.5” hex focuser. I’m planning out the imaging train for it, and I want to use it at its full focal length to complement the Askar 103 I already have. I’d love to hear from folks who have experience with this telescope and what advice they can share.
I have the Hotech 2” SCA flattener. I plan to use a rotator, an OAG, and a 2” filter wheel in front of the camera. Most setups would have about 5 pounds behind the flattener. The specs on the hex focuser claim a 10 lb. weight capacity. I will have an autofocuser.
Can I trust the hex focuser, or should I plan on buying the ES 3” focuser or a Feather Touch ($$$)?
Should I disassemble the flattener and thread it onto an M68×0.7 to M48×0.7 reducer ring rather than slide it into the compression ring?
Would the ES 1x flattener be a better choice given its 48mm exit lens (as opposed to the Hotech’s 42mm)? The camera will be an APS-C, not full frame.
I have an EQ6-r Pro mount that I’ll need to get the pier extension for. I’ve seen reports of an early model of this pier extension that had issues. Have they been resolved? I understand they now come with some sort of rubber gasket or something where the pier joins with the tripod?
Any other advice or learnings you might share? Thanks in advance.
