Recently I encountered an extremely difficult mosaic and spent more than half year to devise a solution. The figure below shows what the problem is.
This is a mosaic created in PI, using MGC (and my own reference image) for gradient removal, Linear Fit for matching the brightness/color/contrast of the panels, and Gradient Merge Mosaic for mosaicking. These are quite standard in common mosaic workflows. The upper half shows the result directly from Gradient Merge Mosaic. It looks quite fine. There are no obvious mosaic seams and residual gradient in individual panels. The bottom half shows the result after stars are removed. Once stars are gone, you can see all the defects in this mosaic. The standard workflow just cannot unify the gradient and brightness in all panels. This mosaic is un-processable. As soon as I enhance the nebulas (any extended features), the mismatched panels will become apparent. I tried several different methods for gradient removal and panel matching, including those in PI and APP. None of them worked.
This PDF file contains the full story, including all the tests that I had done, the cause of the problem, and my solution to it. I hope it will be useful for mosaic maniacs like myself, as well as developers who seek for improving their mosaic algorithms.
Wei-Hao
ps, I cross-post this on CN. If this is not allowed here, I apologize. Please delete it.
pps, a partial mosaic created during the test phase was published here a while ago. I hope I can publish the full mosaic some time soon.
Somehow, this post was assigned to the APP forum without my agreement. Actually, this is more about PI than APP, although it also involves APP. If there is a forum manager, please help to move this post to a better place.
Here is the starless version of the Southern Cross region from the ABC survey fields (taken by myself and
And the Ha image mosaic of (roughly) the same area - posted a couple of months ago with the stars.
