Currently running a 350ml FL F4.9 Redcat 71 WFID with an ASI 6200mm w/ all the other monochrome essentials and having a blast. Image scale is 2.2arcs/pixel. While an amazing setup, I would like to get something at a longer FL to give me more flexibility in targets.
Considering something in the 500mm-900mm range so I can shoot planetary nebula, globular clusters, and galaxies. Specifically the Pillars of creation, m33, m51, crescent nebula, dumbell nebula. I prefer to remain under sampled a bit as I like to take my scopes up to the mountains, which sometimes have wind so a bit of under sampling affords me flexibility in guide performance. i’ve done some research and the data shows my mount with the rowan belt mod kit can safely handle a little over 24 pounds imaging.
I’ve done some peaking around astrobin and online and come across some different scopes:
107PHQ Askar
SQA106 (would put me right at the limit of my mount’s listed imaging weight capacity)
Ultracat 91 (probably too short FL but still an amazing scope)
If I were to upgrade my mount later this year to the am5n, which I probably will, I’d also consider the following -
Askar 130PHQ
Ultracat 108
Ultracat 131 (probably outside my budget but a man can dream)
Takahashi 160 ED
SQA130
What I can’t decide on is FL vs speed….There’s a lot of nice F7 scopes but I don’t feel like they post the best photos on astrobin compared to scopes with slightly less FL but faster (F4.8-F.9) For the objects I listed which way would you guys recommend? Something that is 500mm-650mmFL and faster, or something 700-900mm FL but 2x as slow?
