How do you get a reliable weather forecast before a session?
Alex GTony GondolaSonnyE
43 replies606 views
Which weather apps do you use for planning your sessions?
Multiple choice poll 153 votes
6% (9 votes)
11% (17 votes)
21% (32 votes)
8% (12 votes)
14% (21 votes)
4% (6 votes)
37% (56 votes)
Alex G avatar
Hey everyone,
I've been trying to get better at planning my sessions, and occasionally I keep running into this issue: I check one weather app and it says clear skies, but another says cloudy. It feels like it’s a specific time of year or location thing, but I’m not 100% sure.
Do you have a routine for checking the forecast before you decide to have an imaging or observation session? How many different sources do you usually check? Or maybe you know some specific weather forecast or models that give you accurate results?
I'm curious how you all handle this
I have found Astrospheric to be the most accurate for my area here in the central US. I use Clear Sky Chart and Weather Underground for a quick check and then go to Astrospheric for a more detailed prediction.
TiffsAndAstro avatar
Atmospheric if you're in USA.
If you're in the “micro climate” that is nw England, Windows.
Ie: open them and look outside. And have a light weight rig so it's easy to run indoors with :(
Quinn Groessl avatar
A variety. Clear outside, Atmospheric, and the national weather service (since I’m in the US) mostly. The first two are for cloud forecasts, then NWS for rain chances. I don’t set up if there’s an even a slight chance of rain because I like my money.
dummieastro avatar
In the Western United States I use Astropheric and Clear Outside together. Then I pull up the local weather on MSN Weather, click on the map, click on the clouds icon and I get the current radar picture and then move the time forecast out to see how the clouds move. Putting all these together with local knowledge of the usual daily cloud patterns I get about 98% accuracy. That last step really helps to not miss opportunities as sometimes Astropheric/Clear Outside says cloudy but the local radar shows a clear opening.
CS, Bob
Eric Gagné avatar
I use the weather app on my iPhone and ClearOutside. But I’m old school, my favorite method is to look at the sky.
Well written Respectful Concise Engaging Supportive
Alex G avatar
dummieastro · Jul 3, 2026 at 08:43 PM
CS, Bob
Thank you for sharing, that’s a lot of data to check. For my location in Europe I also check 3 sources - Meteoblue, ClearOutside and the Apple weather app. The satellite/radar data let me down me a couple of times, but I should probably start checking it as well to learn local patterns.
By the way, have you ever seen any website or app that combine the forecasts together?
Alex G avatar
Quinn Groessl · Jul 3, 2026 at 08:34 PM
That’s very reasonable. I see the first 2 do provide rain forecast, is the latter more reliable for rain predictions?
Alex G avatar
Tony Gondola · Jul 3, 2026 at 08:14 PM
Thanks for sharing, didn’t know about the first two. And thankfully Weather Underground supports my location.
I actually see all of them are quite detailed, does Astrospheric offer anything special that helps you?
Gamaholjad avatar
BBC weather for me pretty good really. Or I step outside and see if the clouds are rolling in . Having your own observatory means I can look outside coupled with BBC weather and be up and running in 10 minutes. Having your targets penciled in prior is key for me.
Alex G avatar
Gamaholjad · Jul 4, 2026 at 01:27 PM
Nice, do you have an all-sky camera or a meteo station installed there?
Médéric Hébert avatar
Astrospheric for clouds, weatherCan for risk of rain. Even the slightest risk and the rig stay covered.
Alex G avatar
Médéric Hébert · Jul 4, 2026 at 01:59 PM
Thanks for sharing, that’s the second time I see people use smth different rather than AstroSpheric for rains. Any reasons for you personally?
Patrick Graham avatar
I’ll have to try Atmospheric……Clear Outside has done well for me here in southern Nevada but always looking for tools to enhance my sessions.
Alex G · Jul 4, 2026, 01:10 PM
Yes it does. The seeing prediction is really useful and it also maps hour by hour, any of the parameters you want to look at. I find it to be the most detailed and accurate of the three.
Concise
Oops…..got the name wrong
Michele Rainville avatar
I use 3 then go outside and watch even with the three accuracy is no always good
Alex G · Jul 4, 2026, 02:14 PM
I often let my rig do it’s thing unattended. If it starts to rain I’m not minutes away to cover up, I may be hours away, so I want the extra peace of mind from another source. Technically I use both for rains and you can’t get rain without clouds…
It rained down on mines few times in the years. Still there ticking…
Bill McLaughlin avatar
Weather Underground 10 day with a graph of cloud cover % has been the best for clouds. It uses crowd sourced weather stations so it is more granular.
SonnyE avatar
I use the weather app on my phone, and Atmospheric Pro. And I have a weather station on my roof.
But the tie breaker is my eye on the sky.
Typically, I live under a hole in my weather. So I get a lot more clear nights than many others.
But my eye is the best predictor.
Alex G avatar
SonnyE · Jul 5, 2026 at 12:23 AM
I have heard that weather stations give an extremely accurate local forecast, is it true?
SonnyE avatar
Alex G · Jul 5, 2026, 08:48 AM
Not where I live, Alex. they try, but often fail in accuracy. That is why I rely on my method 3, go look.
But even that has failed me a time or 12. Our weather seems to change too fast.
My ultimate hold card is my Delete Key. Using my delete key there is no evidence of a screw up. 🤣
And I can always edit a set of images the next day, chopping off images of no value at the end of a run. Mass extinction at times. (Instead of 200 images pare it down to the last viewable image to 1xx, for example. Then stack what I’ve been given.)
I would add that local forecasting isn’t what it use to be, at least in the US of A. Many local stations have dumped people with actual degrees in Meteorology in favor of a talking head working with nationally distributed data. The data is good as far as it goes but the local knowladge is lost.
Concise Engaging
patrice_so avatar
For Switzerland, meteosuisse.ch provide the best forecasts in general, as it operates based on a refine grid taking Swiss topography into account using the supercomputing centre in Lugano CSCS.
I lacks however data on sky quality. Those can be found on meteblue.
As astrophotography and sailing enthousiast, I must say that specialized applications for specific hobbies let you feel as a part of a given community (be it paragliding, sailing, surfing, etc.) but in my experience meteosuisse.ch remains the most accurate source of data. This is true for planning imaging night but also for planning sailing. It is indeed completely crazy how precisely how wind developpement (speed, direction, and timing of changes) is forcasted 5 days in advance.
