CORRECT ORIENTATION OF CHROMA FILTERS
17 replies391 views
Riccardo Civati avatar
There's conflicting information online about the correct orientation of Chroma filters.
I've always had them with the side that reflects better toward the telescope and the side that creates double/triple reflection toward the camera. Is this correct?
From what I've read on cloudy nights, some say the opposite...
Riccardo
Well written Respectful
Their website isn't useful.
Bob Lockwood avatar
CN will always give conflicting information.
This is not useful?
Per Chroma website,
Orientation for Astronomy and Astrophotography Applications
Astronomy filters made by Chroma do not come with an orientation marker, such as a caret or arrow. This is due to the design of the filter which is built to deliver peak performance regardless of which side is facing the light source or the detector.
However, it is worth noting that some users have reported slight variations in effectiveness when using one side or the other in their specific setups. Other variables in the optical system, such as the properties of the individual lenses, the light source, or the detector are the most likely drivers of this variability.
In general, there should be no significant difference in performance regardless of the filter orientation.
Well written Helpful Concise Engaging
John Hayes avatar
“CN will always give conflicting information.”
I completely agree with Bob on this point! There are some very knowledgeable people on CN but unfortunately the good information is often buried under so much garbage that it’s hard to find.
The question about which orientation is best for filters is a common one and a bit difficult to answer without some careful analysis.
First of all, the effectiveness of the thin film stack that makes up the filter is not affected by which way light passes through it. So that isn’t a driver for which way to orient the filter. The more important question is which orientation reflects the least amount of stray light back onto the sensor? If you sit down and carefully ray trace all of the potential single bounce strays, you will find that the amount of stray light will be the same no matter which way you orient the filter. Here are a couple of diagrams showing the situation for two assumptions:
This first diagram shows the simplest situation if the AR coatings are assumed to be perfect. I’ve used assumed values for the transmission and reflectivity so that we don’t end up with some long analytic expression. As you can see, the amount of light from a single bounce stray will be identical no matter how the filter is oriented. That should be intuitively obvious.
In the second case shown below, I’ve shown the situation where the AR coatings are just 2%, which is a garden variety, low-end coating. Here, the result is not immediately obvious. Again, I only considered a single bounce stray and again, you can see that the stray level is identical no matter how the filter is oriented.
Unfortunately, this sort of calculation doesn’t quite close out the argument because it doesn’t consider the SIZE of the strays, which will determine the irradiance of the stray light on the sensor. Here’s what just one case looks like (ignoring the effects of refraction):
📷 image.pngimage.pngI haven’t had time to make a similar diagram for the flipped filter but you can see what happens. If there is a difference between the reflectivity of the AR coating and the reflectivity of the filter (at the transmitted wavelength), there will be a small difference in the brightness of the smallest stray from the surface closest to the sensor. In reality, these values shouldn’t be wildly different so I don’t believe that this should be a strong driver for how to orient the filters.
The ultimate conclusion is that the folks at Chroma are right! It doesn’t really matter how you load your filters. Any differences between the two orientations will be extremely small. And, I should add that this conclusion doesn’t just apply to Chroma filters. It should apply to all filters, so I don’t know why some companies mark the orientation, other than to make it easier to load all of the filters with the same orientation. Up or down…it doesn’t matter.
Daniel Cimbora avatar
Riccardo Civati · Jun 26, 2026, 02:31 PM
Riccardo, did you see this?
pfile avatar
i followed chroma’s guidance, but installed all the filters in the same direction. i had some star reflections with the OIII filter, so i flipped just that one, and the problem went away. i’m not even sure which side has the AR coating, to be honest.
i dont’ doubt john’s analysis but in my case that small difference seemed to make a difference. this is on a GTX110 with the 110TCC and a 6200MM w/ 50mm round chromas.
rob
Luigi avatar
Hi Riccardo,
I have mounted my Chroma filters with the most reflective side towards the sensor. it works fine with my system (TOA130+ 67 flattener, + Moravian C3).
The analysis by John is OK but one should take into account that there are two potential sources of reflections: one is the sensor, the other is the last optical surface towards the telescope by any reducer or flattener you have. The system is thus asymmetric. One of the two sides (reducer vs sensor) may produce more stray reflections than the other. You have thus to check the orientation that works best for your optical system
cheers
Luigi
John Hayes avatar
pfile · Jun 27, 2026 at 04:51 AM
rob
Rob,
That is interesting. The only way that I can imagine that the orientation might matter would be due to a seriously faulty AR coating, but maybe there’s something else going on that I haven’t considered—and it wouldn’t be the first time. I would really like to see what the difference between the two orientations looks like if you can dig out a couple of subs and post them. Adam Block had a similar issue with his scope in Chile and he went to the trouble of flipping the filters the last time we were down there and as I recall, it didn’t make any difference whatsoever. We tore our hair out trying to figure out where some strays were coming from in both of our scopes and we did a lot of experimenting. In my scope, I removed the field flattener and swapped filters to show that neither of those components were causing a particular stray. I ultimately concluded that it had to be due to a bad coating on the camera chamber window. Unfortunately, I wasn’t able to swap the camera to confirm that idea. Dealing with stray reflections is tricky business!
John Hayes avatar
Luigi · Jun 27, 2026 at 10:31 AM
Hi Riccardo,
cheers
Luigi
Luigi,
That’s a good point and it’s something that I tried to address in my own scope when I tried to chase down a particularly troublesome stray. My ASA600 uses a field flattener and I was convinced that a back reflection from one of its components with a potentially faulty AR coating might be causing the problem. So I made an adapter to run my system without the flattener. Unfortunately, it made zero difference; but, that wasn’t a surprising result. In order to get a stray from an upstream component, you need to satisfy two conditions. First, the upstream component has to have just the right curvature to bring the stray reflection back into focus near the focal plane. Second, the AR coating on that surface has to be defective in order to return enough light to make any difference. Both of these conditions are low probability, which means having them both occur is a REALLY low probability. It could happen, but it is very unlikely. I was able to definitively confirm that it wasn’t the source of the problem in my scope so I was able to toss out that possibility. I was able to rule out the flattener and the filters as the source of the problem, which leaves only a component in the camera as a potential source of problem.
pfile avatar
John Hayes · Jun 27, 2026, 03:18 PM
rob
Rob,
i’m looking back at the images. there’s a further complication here in that i originally ordered 3nm NB filters for this system but pretty quickly came to realize that there was some problem with the transmission of the OIII filter.
on a field containing M42 and the running man, what i see is a flipped and reversed image of the brightest stars in the field, with a significant amount of coma, only thru the OIII filter. so near the running man i see the reflection of the bright stars at the bottom of M42, and on the other side of the image near those stars below M42 i see a fainter reflection of the stars in the running man. or at least i think that’s what they are, it’s hard to tell exactly. it’s easiest to see this using blink so i might make some movies.
i also see these same reflections with the images taken right after i got a replacement set of filters, again only thru the OIII filter. however i then flipped that filter and the problem went away. the replacement set is 5nm.
looking back thru my emails, they told me that if the writing on the edge of the filter is right-side up, then the AR coating is on the bottom. this is how i installed all the filters at first. now after flipping the OIII filter, the AR coating is facing up. that means on the OIII filter only, the AR coating is facing the 110TCC reducer.
there was definitely something wrong with the initial 3nm OIII filter - it also exhibited halos and other strange, more diffuse reflection artifacts in addition to poor transmission. but since the replacement 5nm filter has the same subset of star reflections, it’s hard to say if the problems the 3nm filter had were the cause of the “pinpoint” star reflections. i never tried the 3nm filter in a “flipped” orientation.
side note, i’m a little disappointed in chroma given the cost of the filters. when i reached out to ask about the transmission issue i got no response for more than a week, at which time i tried again and finally got a reply. at that point because of the possibility of having received a bandshifted 3nm filter (which this system should not need at f/5.5), rather than asking for troubleshooting help i asked to exchange for 5nm filters and they agreed. subsequently i had the reflection issue with the 5nm and asked them about flipping the filter; when that resolved the issue i just dropped it since everything seems to be fine (and continues to be.)
John Hayes avatar
pfile · Jun 27, 2026 at 04:36 PM
rob
Rob,
Thanks Rob…that’s interesting. Mark McComiskey had similar problems with a 3 nm OIII filter and Chroma replaced it for him. I can’t imaging why you were getting a flipped stray image without involving more of the components in the system. Flipping the filter really shouldn’t make a difference; but, I believe you that it did. I just don’t understand how that could have made a difference. As I said previously, analyzing strays can be difficult—particularly without looking at the full optical prescription. Adam, Mark and I all use Chroma filters and we did some comparisons between our three scopes in Chile imaging a very bright star. My scope did the best. There were strays but they were extremely faint. Adam had the worst trouble with very bright strays and in spite of a lot of experimenting, we weren’t able to figure out a definitive reason. It is definitely something that I’d like to understand better! It may take setting up a detailed model in Zmax where we could do precise stray light analysis.
pfile avatar
John Hayes · Jun 27, 2026, 06:41 PM
sounds like they must have had a bad run then.
i feel like i must be getting a reflection off of the back surface of the 110TCC reducer… otherwise i’m not sure where the flipped image would come from.
i tried to make a little movie with blink of the various artifacts but failed, maybe there are too few frames and ffmpeg only builds a movie with 2 out of the 10 or so frames i fed it.
John Hayes avatar
pfile · Jul 1, 2026 at 04:21 PM
That’s a possibility and it’s what I thought what might be happening in my scope as well. However, when I pulled the flattener, it didn’t make any difference. I suggest that you pull your reducer to see what happens. That will at least show definitively if that’s where the stray is coming from. If it is refocusing a stray back onto the sensor, that can mean that even a very small stray reflection could be causing the problem. A garden variety AR coating should not reflect more than about 0.5%, but that could be enough to cause a problem if it is all refocused back to a small region on the sensor. Even a really good coating at 0.25% could be a problem. The fact that we are looking at such weak signals to begin with is what makes this so hard! That’s why telescope manufacturers should be careful to do some stray light analysis to avoid refocused beams.
Well written Helpful Engaging Supportive
pfile avatar
John Hayes · Jul 1, 2026, 04:34 PM
this is probably easier said than done for me due to spacing requirements. i own the flattener equivalent of the 110TCC, so i could try that instead, though if the reflections persist i didn’t learn anything.
also of course this requires me to open the filter wheel and flip the filter, then find a clear night with the right stars (so far i only observed this on M42 and so i can’t repeat that experiment at this time of year.)
to be honest i probably do need to open up the filter wheel anyway because i’m getting different artifacts, maybe off of the filter masks (which are 3d printed and thus a little shiny.) on fields where there is a bright star pretty far out of the FOV i get spikes pointing to those stars. i hesitate to raise this with AP because the initial reaction always seems to be incredulity when it comes to issues like this. so i have to do a bunch of debugging first.
Bob Lockwood avatar
pfile · Jun 27, 2026, 04:36 PM
The only time I ever see this is after a pier-flip, but this is beside the point. As for the reflections from the AP 110TCC, I’m pretty sure this came up some time ago on the AP user group. They were getting reflections at the rear of the 110TCC and I believe it had to do with the shine of the anodizing and the angle of the taper of the housing. The fix at the time was to make a mask that covered the taper, my 110TCC threads into my OAG and I made a mask that threads into the OAG between the TCC. I use the 110GTX with the 110TCC with chroma 3nm filters with a Moravian C3-61000 and see no reflections of any kind.
I believe AP has since fixed that issue.
Edit: forgot to mention that I’ve had the filters in both orientation and see no difference.
This is the ring I made installed in my OAG with the 110TCC attached.
Well written Helpful Respectful Engaging
pfile avatar
Bob Lockwood · Jul 1, 2026, 09:55 PM
maybe i was not clear about what i was seeing; it’s not that the image is flipped, it’s that the reflected stars i see (faintly) in the images are flipped/reversed images of the bright stars in the image.
that is interesting. the other day i was trying to determine if i could fit a rotator in my image train, and i happened to look back at the AP website for mechanical drawings. i noticed that the various adapters that are used to step down from the TCC to the camera are now different than the ones i have. it’s possible they eliminated the various tapers in favor of flat surfaces.
anyway i’m not sure if something like this could be the cause of the reflected stars (which were cured by flipping the filter anyway) but these kind of shiny surfaces could be responsible for the rays of light coming from stars far out of the FOV of the sensor. i should attempt to flock or mask these surfaces the way you have done.
Brian Diaz avatar
Hi,everyone
My Chroma filters have the name oriented upwards.
📷 IMG_5318.JPGIMG_5318.JPG CS
