Printing / Accurate Colorization / Photoshop
9 replies693 views
Jay Hovnanian avatar
I've searched a bit and haven't seen a related thread, so I am hoping this is not redundant ....
You spend hours and hours in travel, set-up, acquisition, the long ride home, registering and stacking, and then processing; your image is where you want it to be (at least for now) ... and then, in PS you print from your hot-dog computer/monitor on your hot-dog printer and voila [i]!!  [/i]It is somewhat underwhelming ....
I have tried, allowing PS to manage colors, as well as the printer.  I have - to the best of my marginal know-how and abilities - tried color management, and still, what prints (and the print quality overall is impressive) is nowhere near as deep, vibrant or detailed (especially nebulous filaments) as what the image is in PS, here in AstroBin or even my phone images ....
Perhaps many (if not all) of us have faced this challenge.
Advice will be appreciated.
Thank you
Jared Willson avatar
The inherent problem is contrast. A good modern, monitor might have a contrast range of 1,000:1 or higher–sometimes much higher. Most photographic papers are closer to 70:1 with decent ink, perhaps 100:1 in the best pigment based printers on whitened papers. That means when you print, either you are losing details in the highlights or in the shadows. It's the same problem you had in processing the image in the first place, only now you have to go 10x farther in your stretching than you had to with your screen processing.
There isn't really a perfect solution, but there are steps you can take:
1) Make sure in Photoshop or Lightroom you are using a color managed workflow. I know you said you are already doing that. That's the baseline.
2) Make sure you are soft proofing the image when you make your adjustments for printing. I tend to save two versions of each image–the one that looks good on the screen and the one that looks good when printed
3) Don't be afraid to brighten shadows significantly for printing (even though the result will look bland on the screen). Otherwise, those shadows and faint areas of nebulosity will all go to mud.
4) Don't let the printer manage the colors unless you are OK with a bunch of trial and error. Instead, manage the colors in Photoshop and turn color management off in the printer
5) Depending on the brand of your printer, they all have strengths and weaknesses in terms of color saturation and gamut. I have never, ever gotten satisfying reds out of Epson printers, but, by contrast, I struggle to get the blues the way I want with Canon. Your experience may be different–it will also depend on the specific inks, papers, and paper profiles. Overall, I prefer what I get out of Canon printers since red is so important in astrophotography.
6) One you raise the shadows, you may need to make contrast adjustments. That may result in your losing some saturation in brighter areas. Don't be afraid to pump up the saturation a bit even at the risk of increased noise. Doing this in LAB mode will not raise noise as badly. Often this yields a really bad result on the screen, but a good result when printed.
7) Use the right paper profile–one made for that exact paper. It will increase accuracy. When you start pumping up saturation, that becomes a necessity.
smile Note that most printer gamuts are quite narrow. There may be colors that you just can't reproduce, and you run the risk of posterization and noise if you go too far with the saturation in an effort to force the printer to do what you want. Sometimes it just won't.
9) Start with a test print on a small sheet of paper, then, as you become happy with the result, increase size. This controls cost and ink usage. With terrestrial photography, I rarely have to resort to a test print, but with astrophotography (which is, almost by definition, HDR) it is nearly a necessity.
Good Luck!
- Jared
Well written Helpful Insightful Engaging Supportive
Thanks, Jared.  Interestingly, I had been printing with my Epson XP-15000 on another Windows 10 computer, albeit older.  It still has the old Windows Picture Viewer (whatever it is called ??).  I previously had been opening my finished PS images in that (albeit ancient) viewer, and consistently found that when I played around with Brightness, Contrast and Mid-tones (even though it looked wrong on that screen), the prints were acceptable.  I will make sure that I am doing everything I can (as per your advice) and report back ….  Jay
Brian Boyle avatar
Jay,
I write in some trepidation since I am not an expert in colour, contrast, printing - nor that experienced in astrophotography yet (1.5years in).
But have found myself involved in local astrophotography exhibitions (mostly landscape AP, but some DSO work) this coming winter to support NZ's new national holiday of Matariki.
Many of the professional photographers exhibiting now choose to print on metal (Chromaluxe) to achieve much better contrast than paper for their AP compositions.
It's expensive and specialised, but it has the additional advantage that you can hang the print directly on the wall without framing costs.
Indeed, for the size of an A4 or A3 print (the size you could print off at home), the price is not that much different once the mount/frame is taken into account.
While my photography does pale in comparison to others, I have also printed some of my images off - and they do really "pop" this way.
kuechlew avatar
A basic understanding of the old fashioned zone system - originally invented by Ansel Adams to manage the different dynamic range of black & white negatives and photographic paper - may help too. Test-printing a  grayscale (and if you like a Red, Green and Blue scale) divided into zones (historically 11 zones 0 to X but you may choose your own number) on your printer/paper combination will give you an idea about the brightness levels in your image on paper. It won't save you test prints for final tweaking but you should get closer to the desired result faster. You can investigate before printing what part of your image is in what zone and by how much you have to brighten or darken it to get it where you want it to be.
Obviously it's important that you judge the final, dry prints under the same light you intend to present them.
Good luck and CS
Wolfgang
Brian & Wolfgang  –  Thank you both.  As I move forward in my experience(s) and meld the suggestions and advice of others, my prints are (and will hopefully continue) getting better.  Again, thanks to all, Jay
Respectful Supportive
David Menzer avatar
Don't forget to calibrate the monitor - SpyderX is simple and quick, and will notably change the colors on the monitor.
Dave
Alan Brunelle avatar
Brian Boyle:
Jay,
@Brian Boyle ,
I am glad you mentioned metal prints.  I did a couple rounds of printing of some of my photos last year on metal prints.  The base I chose was with a bright white, rather than the natural aluminum base.  I have gotten good results, but it can still be quite tricky.  When I got my first prints, they seemed a bit dark.  I was able to have them redone, and for the new ones I generated data that were much brighter and contrasty.  These came back more acceptable, yet much darker than what my screen represented.  So the adjustments helped.  But here is the catch, these prints, even the dark ones, can look very different depending on how you display them.  In particular, the quality and intensity of the light illuminating the prints really makes a huge difference.  I think more so than for paper prints.  As my prints are mounted on a wall near windows, the presence of bright indirect light really improves their look.  And when the sun hits, they really pop.  I suspect if I were to illuminate with bright white (gallery style) lights, they would be consistently wonderful.  So be prepared to be disappointed on cloudy days and thrilled on sunny days!
I get the impression that the density of the inks applied onto a metal print may be greater than used for paper prints.  I have no evidence for this, but the light effect seems greater on metal print.  It may be that the base of the metal print is more efficient at reflecting light that passes through the pigments.  I am going to guess that the pigments physically sit on top of the base (white or aluminum) rather than penetrate the white substrate, as seems to be the case in paper.  But for your eye to see the image, light has to pass through the pigments once to get to the backing, then back out again.  Of course, some of the light may also get reflected back to the eye from internal reflections within just the pigment layer.  So if the metal backing does not commingle with the pigments, then it can act more as an efficient reflector.  Just speculation on my part.  There is also printing onto plexiglass.  And with that, you can imagine a back illumination that could be wonderful if done correctly!
Anyway, I think the above lesson learned is, even though issues of calibration, color, hues, etc. are resolved, the lighting used to display the prints cannot be ignored and can be just as important.  So when you evaluate whatever means that you use to print, try to be consistent also with the setting the prints will be displayed when evaluating the printing calibration.  Lighting color and intensity being key.  Maybe someone else will add even more detail on this aspect of print viewing.
I wonder how well home ink jet printers can print on paper under any circumstances.  So many astrophotos contain very deep blacks, in addition to deep colors for those that heavily saturate their images.  This is atypical of terrestrial images.  It is not easy for even the finest photopapers to absorb that much black ink, or colors for heavy saturation areas, without some bleeding.  This can affect apparent contrast and detail resolution.  The professional methods typically deal with that using dye transfer processes that can achieve these goals.  I think this speaks to limitations that @Jared Willson was highlighting.
The other thing, which is a bit off-topic in your question is print size.  I have seen a good number of prints done that are just too large for the intended viewing distance.  Some of these would have been great images if it weren't the fact that when viewed from a natural distance for the room, they looked blurred because the blown up image could not be sustained.  It impacts the apparent contrast and apparent sharpness of the details.  Fine for standing at the back of a room, but...
Also, TVs are now getting pretty cheap and have no bezels.  One could mount a TV in a frame and display it like a photo!  My TV actually reads USB thumb drives, so you could make the photo be fixed or scroll through multiple photos!
Alan
Steven avatar
Astrophotography can be tricky to print. All dark stuff. difficult contrast, a lot of detail.. tricky stuff sometimes.
To start, you probably should be calibrating your monitors. No idea if you do that already. But:
I use a SpiderX calibration for that. A little tool that goes onto your screen, it measures stuff and calibrates the colours.
Next, depending on how serious you want to take it. Go for a matte monitor.
It gives a far better representation to what a print will look like, it gives accurate colours and contrast. Far better than what you might see on a glossy screen or phone.
And like other suggested, the printing medium makes a big difference.
No idea if you have a photo lab nearby that might be able to assist you.
It's getting better, but just like the art and science of acquisition and processing, it takes time ….  Thanks to all who are contributing here.  Building upon the experiences of the community is appreciated.
Printers
Just curious; what type of printer do you professionals use when printing out your final images. Right now, I'm using a Canon Pixma Pro-10 but I have seen other printers out there with a larger color array and even some color laser printers. Do a...
Author frustrated with print quality; seeking printer recommendations and solutions.
Dec 7, 2023
Difficulty Regarding Color in Imaging. This is Not Color Choices or Palettes, but Monitor Calibration for Viewing and Also Printing
Hi All, I am curious about any solutions or experiences others might have had with color. I had a recent, and unresolved issue with color reproduction of an image I wanted to print at a commercial outfit. At this outfit, I have had a number of prints...
Author mentions color management issues between monitor and printer output.
Jan 22, 2024
