I use the autorun tab for my filter selection for taking flats. I have a sequence of my filters and exposure times depending on which setup combination I use. I then select the two “autorun blocks” for the flats and run that.
However, I now noticed that it takes the first image on filter A and then goes to the first image on filter B and back to filter A again etc. It used to do all images on filter A (first block) and then go to the next filter (block) in the autorun programme. (sorry for the bad explanation…). My programme in the plan mode runs as normal.
Is this an update or a setting somewhere?
