for those of you having a lunatico AAG cloudwatcher station, I have a strange problem and I am looking for fellows having had the same issue and solved it.
I installed my remote setup last week. I have a Lunatico AAG cloudwatcher and the SOLO device. I operate with NINA remotely. The ascom driver of lunatico for the AAG CW is installed. I can connect the weather station tab in NINA to AAG CW, I use a mapped drive, point the .json file check the data and receive “data looks great” and it works. When I connect the safety monitor tab in NINA to AAG CW with the ASCOM driver of AAG CW for safety, I point to the same file, check the data and receive “data looks great” connect, and is shows it is connected BUT the “is safe” never changes and stays unsafe despite I can read in the .json file that it is safe. So I cannot open the roof with NINA whereas I can open it with the dedicated software that is also linked to AAG CW independently and recognised the safe status.
Does it look like the problem somebody had already or like a similar problem once of you had?
Thank you for reading,
CS Frédéric
