Manuel rotator and ZWO asi 55mm space for camera.
11 replies814 views
Stuart myatt avatar
Hi.
I’m looking at getting  the WO Manuel rotator to frame easier and am looking to put it just after my scope and before my reducer / flattened on my WO ZT81.
Will it mess with my focus at all for my camera and if so will i have to reduce the 55mm back focus distance to compensate?
thanks
stuart
daywalker avatar
if you introduce another element then yes it will effect your backfocus.
You will have to find out the spacing of the rotator and then subtract that from yoyr current spacer setup. so that rotator + adapted spacer config = 55
Torben van Hees avatar
That's wrong. If he puts the rotator between focuser and flattener, backspace will be unaffected. It needs to be checked if the focuser has enough in-travel for this: Focus the scope with the flattener and image train and see how far the focuser is out. If it's less than the thickness of the rotator+all adapters, it will not work.
dreamsandmonsters avatar
I just got the WO rotator 2.5" M63 threads for my WO GT 71.
I confirm that the rotator is between focuser and flattener, so it shouldn't affect backfocus.
Unfortunately, it's cloudy right now, but from what I saw on a Youtube video about this specific rotator, it doesn't change the backfocus, but it changes the focus point 22mm forward: https://www.youtube.com/watch?v=9iSk6CoYgfQ
Here's what it looks like assembled (and probably 22mm focused too far haha):
Rotator --> "2 step down rings" --> flattener --> adapters for 55mm backfocus distance --> filter wheel --> camera
Eddie Bagwell avatar
I also just purchased the WO 63mm manual rotator. Works great! Just mount it before the flattener/reducer just like in dreamsandmonsters pic. You can dial in the stiffness/smoothness by adjusting the small set screws on the edge of the rotator. Mine were too loose from the factory.
Stuart myatt avatar
Many thanks for the reply. My concern is that my focus tube is only out by about 1CM and i think if i add the rotator that adds about 2CM to the train. I’m assuming i will have to go in on my normal focus by about 2CM to reach focus again.
Hope that make sense ha ha
thanks
Taylor Ryle avatar
I have the Z81 and the rotator with the 6AIII and it achieves fucus with a centimeter to spare.
Stuart myatt avatar
This is my issue
matthew.maclean avatar
@Stuart myatt
my GT81 is the same way. With the Flat6Aiii flattener, the WO rotator consumes too much distance in front of the flattener and it can no longer achieve focus.
I ended up using a M48 Blue Fireball rotator that sits after the flattener (and contributes to the 55mm back-focus requirement)
John P avatar
Silly question, but is there any logic behind the way the angle indicator numbers are placed when installing it? 360 on top?
It shouldn’t matter what orientation you call 0 (360); the only purpose to the angle scale would be so that, once everything is threaded together, you can associate the orientation of your camera with a particular number that you can write down so that you can easily return to  the same orientation if you wanted to collect more data frames in the future.
John P avatar
Thank you! Makes sense, but I just wanted to make sure I wasn’t missing anything.
Back-focus with Z4
Hi Z4 users, With all these Askar/Sharpstar flat-field scopes, the manufacturer says that back-focus doesn't matter but I am getting some distorted stars in the corners in a radial pattern that looks a bit like when you don't have precise bac...
Back-focus distance concerns with flat-field scope accessories.
Oct 27, 2023
Williams 71 gt with rotator back focus
I have my Williams 71 gt scope set up perfectly with back focus of 64mm.. I bought a Rotator because Williams is too cheap to have one and when I put it on it messed up all the focus, I cannot even polar align now. Has anyone had this problem? I took...
Rotator back-focus compensation on similar scope setup.
Nov 14, 2023
Televue Powermate 5x
How is a Powermate 5x used on a refractor for planetary imaging? Where in the image train does is go? Is 55mm space needed between the Powermate and the camera? My scope is a Zenithstar 103, and the camera is an ASI224mc. Thanks!
Discusses 55mm spacing requirement for camera with reducer/flattener in refractor.
Oct 6, 2020
Backfocus using Skywatcher Esprit 120ed Reducer/Flattener
hi, I recently purchased the reducer for my Esprit 120. After some researches i found out that a backfocus of 60mm instead of 55mm gives a flatter image. Trying out both with the Asiair, i figured out that the focuser stays in the region of 1000 with...
Back-focus adjustment with reducer/flattener on comparable scope.
Aug 11, 2023
BACK FOCUS ISSUE - Williams Optics FLT91
In my recent sessions with my WO-FLT91 with the Flat6AIII flattener, I have noticed that the stars in all four corners are elongated, indicative of back focus issues. I checked this in the aberration inspector process in PixInsight and I am consisten...
Back-focus issues with Williams Optics scope and flattener.
Sep 29, 2023
