Andy Wray avatar
I've noticed a few times that Stellarium and my scope seem to be out of sync.  My setup is:
HEQ5 Pro Mount
PHD2 autoguiding with an orion starshooter and guide scope
APT as my main platform including platesolving
EQASCOM as the telescope driver
Stellarium as my planetarium
Sharpcap for polar alignment
I think the best way to set this all up is to set them all up to J2000, but not quite sure where I need to do that.  I've set J2000 in APT and Stellarium; is there anywhere else I need to do that? i.e. within the platesolvers/Sharpcap etc
Make sure that the time and location are really accurate everywhere, including the mount's firmware. J2000 is the way to go for about everything.
Gernot Schreider avatar
Andy Wray:
HEQ5 Pro Mount
HEQ5 Pro Mount - see, EQMOD
PHD2 autoguiding with an orion starshooter and guide scope -no
APT as my main platform including platesolving - yes
EQMOD as the telescope driver - yes
Stellarium as my planetarium  - yes
Sharpcap for polar alignment - no
Stellarium or other planetarium software or APT will send target coordinates to EQMOD, which acts as the mount driver via ASCOM platform, so you need to ensure that all software along this communication is set to the same coordinate system, best is to use J2000 as currently commonly used.
The mount driver will translate this to JNow coordinates and to mechanical movement commands.
J2000 is a coordinate system, which has star positions as of the year 2000. Meanwhile we have 2021 and stars have moved, so some stars will show up in different positions due to their movement. These current positions are reflected in JNow. So before actually any calculation of mechanical movement the software needs to translate J2000 in JNow positions. This why you have to ensure that all components "speak" the same coordinate system to avoid confusion.
However the star's movements are small, about 1 arcsec / year and thus the difference between JNow and J2000 is about 20". Depending on your FOV this may be of relevance or less of relevance. Regarding other moving objects this is a different story.
Cheers
Gernot
Helpful Insightful Respectful
Gernot Schreider:
The mean difference between astrometric J2000 coordinates and mean of the date/apparent coordinates is much larger than that! RA is more than 1-1.5min (angular more than 15') and Dec around 40-45 arcsec.
Gernot Schreider:
@andrea tasselli
you are right. The difference between J2000 and JNow is not only the proper motion of the star but also and mainly due the precession of the earth. The precession has a full cycle in 25,920 years, thus 1° in 72 years or 5' per year, varying with dec.
Cheers
Gernot
Loosing over half my Exporsures due to Guiding, how can I Improve?
I've been upgrading my gear recently to a ASI air and a guide Setup. It has times in which it works really well but looking at the data over a night, I can confidently throw away over half of my data because the guiding just wouldn't work pro...
Discusses guiding setup issues similar to author's PHD2 autoguiding configuration.
Oct 15, 2023
Canon R5, ASIair Mini compatibility problem?
Hello, For the first time, I tried using my Canon R5 with my C8-N reflector on an AVX, with a Orion Deluxe Mini guidescope and asi120mm mini guide camera for guiding, all controlled by ASIair Mini. Here's all the failures I had before I gave up: ...
Mentions Orion guide scope and autoguiding setup comparable to author's system.
Dec 25, 2023
