Lorenzo Scagnolari avatar
Hi guys!
I'm writing to ask if someone can help me out with an issue I had last night, when I did my very first widefield astrophoto with an old 1984 Tamron 35-70mm F3.5 mounted on a Canon 1300D Super UV/IR Cut + CLS Astronomik filter and tracked with the Staradventurer 2i.
I attach to the post the result so you can see what I ended up with.
Basically, when I was trying to focus a bright star or constellation, I wasn't able to see anything (both from live view or camera connect through an iPad) even if boosting the ISO to my maximum (6400) and with the widest aperture possible (F.3.5).
I ended up taking a picture of the area > blind focus after seeing the picture > taking another picture to see if the focus was correct > blind focusing again > taking another picture to check the focus...and so on!
At the end I had an acceptable focus but not a perfect one (I was wondering to use my Bathinov mask but obviously it wasn't possible).
Do you know why I had this issue or anyone had a similar experience using a camera lens?
With my APO 60/360mm I don't have any issue focusing a star, so I tought that maybe the problem is the use of my light pollution filter at 35mm, too wide to see anything even with maxed out ISO.
Thanks a lot for the help!
Lorenzo
70mm divided by 3.5 gives back 20mm of aperture so no surprise you couldn't see stars in LiveView unless they are of first magnitude . The CLS filter obviously didn't help either but it is not going to be a major factor.
Thanks Andrea, this math makes a lot of sense and I didn’t think about it!
So the only way is to focus as I did? Taking test shots and then blind focus between a shot and another until I reach something acceptable?
Thanks again for the help!
Lorenzo Scagnolari:
Yes, that's the way to do it and also the more precise way at any rate. I don't relay on the LiveView with either Canons or Nikons. The only ones I find acceptable in getting good focus are those of the Fujifilm cameras.
Rack & Pinion vs. FeatherTouch
Hi, Can someone let me know the the difference between and pros/cons to Rack & Pinion vs. FeatherTouch focusers? Thanks!
Focus issues with camera lenses may involve focuser mechanism comparisons.
Oct 2, 2020
Getting Decent Looking Stars in the Background
DSO First Attempt Hey guys, first post here in the forums I recently took my first image of a deep sky object (the Lagoon Nebula) and I'm happy with how it turned out for a first try, but the thing that annoys me a lot is that while the nebula i...
Focus problems with wide-field imaging; author mentions focus as potential issue.
Sep 20, 2020
EdgeHD 8's Focal Length 1494 MM, not 1422, dark vignetting in the corners of image
So my ASIAIR Plus is reporting my Celestron EdgeHD 8's Focal Length as 1494 MM, not 1422 mm. I know a little variation is normal, but 1494 mm seems WAY off of 1422, isn't it? I'm also getting vignetting of dark in the corners of image. Th...
Focal length variation may affect focus calibration and image quality consistency.
Oct 7, 2023
Loosing over half my Exporsures due to Guiding, how can I Improve?
I've been upgrading my gear recently to a ASI air and a guide Setup. It has times in which it works really well but looking at the data over a night, I can confidently throw away over half of my data because the guiding just wouldn't work pro...
Guiding issues could cause focus problems and exposure loss during imaging sessions.
Oct 15, 2023
