I looking for cheap lens for astrophotography with my unmodified Canon EOS 6D.
8 replies546 views
Makár Dávid avatar
Hello!
I need some advice with lenses.
I need a cheap lens like 70-200mm F/4L USM for learning Deep Sky astrophotography?
My budget is 500$
What do you think about this lens?
Do you have any other suggestions?
My equipment:
Canon EOS 6D
Skywatcher Star Adventurer 2i
Sabine Leidinger avatar
do you want to get a new or a used one?
I had also heard good things about that lens, got myself a used one and it was a total fail
if you get a used one, test it before you buy it
+ here some food for thought:
Canon EF 70-300mm f/4-5.6 IS II USM
Example:
https://www.astrobin.com/am5c8g/
kuechlew avatar
the Samying 135mm f2 lens is a classic. I doubt you find a cheaper lens with as many top picks and even image of the day awards: Search - AstroBin
 (Of course the honor goes to the photographer not the lens)
Have fun and clear skies
Wolfgang
Ian McIntyre avatar
I started with a DSLR/Lens option. I went with a used EF300mm f4l I purchased from an Ebay vendor in Japan for about $600. I'm happy with the lens and feel like it was a good option to do both astro and daytime photography. That being said, after 7 months, I wish I had purchased a similar focal length refractor instead. I would probably go with something like this that falls within your budget.   https://www.highpointscientific.com/telescopes/refracting-telescopes/apertura-60m-fpl-53-doublet-apo-refracting-telescope-60edr
You will need the t-adapter which is about $20. And from what I know, consider a field flattener.
If you are committed to a lens, I would avoid zoom. You can actually find a 200mm f2.8l for around your budget if you are willing to do used.
Helpful Concise Supportive
Yusra Q. avatar
Samyang 135mm f2 is the best one in that budget.
I own both Canon EF 70-300mm f/4-5.6 IS II USM and samyang 135mm. Samyang is sharper and the focus grip also holds well. But its a manual lens which is not an issue to be honest.
Steven avatar
Would agree with the others, the Samyang 135 seems to be best for your budget. A lot of astrophotographers keep one of these lenses in the back pocket, for good reason. I'm still hoping to get one eventually.
Something that could perhaps work is a cheap APO scope. Like a TS Optic 60/360 photoline
(although you might be pushing your budget as you'd need a flattener and also pushing the limits of the Star adventurer due to weight)
Ian McIntyre avatar
Looking through his images, he already has the Canon L version of that lens.
Chase Newtson avatar
Since you already own a 135mm lens by the looks of it, I'd maybe look into the TPO 180 Ultrawide?  It is $400, so towards the top of that budget, but it includes its own field flattener/reducer, is light weight and shouldn't need any more adapters outside of a T-ring for your camera.  It will also have no problem working with your full frame camera as well.  The front is also threaded to take 2-inch filters, which could be of use if you need a light pollution filter.  At a focal length of 180mm (with reducer/flattener on), it may not have the reach you are going for, but it is a nice triplet design, which is ideal for astrophotography.
https://optcorp.com/products/tpo-ultra-wide-180-astrophotography-lens?variant=32007173898309
I love mine, you could also look at the Askar FMA 180, They are the same scope.
And if you take the jump into a larger mount and telescope setup, the TPO (Or Askar) can work as a good guide scope as well.
If I were to put my money on a Canon lens I'd go with this:
Canon EF II 200mm F/2.8 L II USM
Used it's going to be within the target budget.
Hi from France
Hello all, I’m Fred, I live in France, I do astrophotography with my modest equipment, canon 6d modded and a star adventurer.
Canon 6D lens advice relevant to your equipment and astrophotography interests.
Sep 9, 2020
First Astrophotography Setup
Hello fellow astrophotographers! I am excited to venture into the world of astrophotography and have been diligently researching and assembling my first setup. I have some prior experience with photography using a Nikon DSLR, but now I'm eager to...
Relevant for first-time astrophotography setup advice and lens recommendations.
Jul 25, 2023
