Help. Pollution or something else ?
19 replies355 views
Jjmorris90 avatar
Hello
I just started taking photos in December so extremely new to me. Though I’ve came across a little nag.
im using a skywatcher 200p on an eq5 pro. I use an asiair and a asi120mm mini as a guidescope. My main camera is an unmodded canon 700d.
basically whenever I try to photograph the target I get a white cloud on the image. Upon processing the image is just unusable. White fog all around.
i took nearly 2 hours of lights of m31. All had this white fog which moved over time over the FOV.
i do not know what it could be but it’s ruining all my pictures.
i have attached a few pics from my Asiair. Excuse how small they are. As you can see it moves from the top to bottom of the screen. Even with flats it can’t be used as there seems to be some sort of change during the session.
thanks
You should upload a higher resolution image of the frames but, yes, it's light pollution, quite strong as well.
Gernot Schreider avatar
Do you have street lamps or other artifical light nearby ?
You could have stray light from these sources.
Gernot
Jjmorris90 avatar
*** The site says 1MB only  ***i
Salvatore Iovene avatar
That's the upload limit for forums, for the Free accounts. But if you upload to your gallery, it's much higher.
Well Written Concise
Jjmorris90 avatar
Gernot Schreider:
Gernot
There are LED streetlights yes but not in direct view of the scope. The scope was pointing at the sky.
Jjmorris90 avatar
I have uploaded a photo in my gallery. This is post processing. You can see the awful white bands around the image.
the raw files are in fit format so not sure how to upload those
Jjmorris90 avatar
All I can see is monochrome fits files. No colour information that I can see. Weren't you using a Canon DSLR?
Jjmorris90 avatar
Yeh I was - canon 700d via an ASIAIR
Something went quite wrong along the way then, because your lights/darks/biases are 16bit monochrome fits files and your flats are standard CR2 files.
Concise
Jjmorris90 avatar
I was under the impression they remain mono until debayering in post processing ?
They are not mono, they are OSC. Here is what your fits files say:
SIMPLE  =                    T / file does conform to FITS standard
BITPIX  =                   16 / number of bits per data pixel
NAXIS   =                    2 / number of data axes
NAXIS1  =                 5208 / length of data axis 1
NAXIS2  =                 3476 / length of data axis 2
EXTEND  =                    T / FITS dataset may contain extensions
COMMENT   FITS (Flexible Image Transport System) format is defined in 'Astronomy
COMMENT   and Astrophysics', volume 376, page 359; bibcode: 2001A&A…376..359H
BZERO   =                32768 / offset data range to that of unsigned short
BSCALE  =                    1 / default scaling factor
PROGRAM = 'PixInsight 1.8.8-11' / Software that created this HDU
COMMENT PixInsight Class Library: PCL 2.4.15
COMMENT FITS module version 1.1.9
COLORSPC= 'Grayscale'          / PCL: Color space
Once converted from "supposed" Bayer format into colour they all return equal colour planes. IOW, I can't see any colour at all. I suspect that they were saved as grayscale files originally then converted into FITS.
Jjmorris90 avatar
COMMENT   and Astrophysics', volume 376, page 359; bibcode: 2001A&A...376..359H
Odd. I get colour when I’ve stacked in siril. Not sure what’s going on.
Neither I. It does say Bayer pattern further on in the FITS header. Converted into RGB doesn't bring any joy though as the colour planes are essential identical. I can see the Bayern pattern in the flats' CR2 however.
Jjmorris90 avatar
Hmmm. Next time Il save the files directly to the camera as opposed to the asiair
Torstein Thomassen avatar
It looks like you have a light leak, try to cover the primary mirror side of the telescope next time with a jacket, tin foil or something to test it.
Concise
Jjmorris90 avatar
Torstein Thomassen:
Will do thank you. I know that when I put the dust cover over the lens to take flats light gets in through the bottom
David Moore avatar
Have you tried a dew shield as you may have reflections off the tube. What happens when the street lights go out if you have them? Have you tried a woolly hat or something around the bottom of the tube? Is light getting in around the focusser somewhere?
Concise
Jjmorris90 avatar
I’m going to get a dew shield. I’ve not tried when they go out. Usually at midnight. I will try when the weather permits it.
DSLR and narrow band imaging
Hi all, Looking for some help, I am very new to all of this (3 weeks in) and sometimes it is really difficult to see through all of the info available online. My setup is a skywatcher Mak 127 with a focal length of 1500mm, a skywatcher EQ5 pro goto m...
Similar beginner setup with EQ5 Pro mount experiencing issues.
May 22, 2020
Weird noise pattern in several sub frames
I was going through some of my sub frames from the other night and came across several subs that contained weird interference noise of some sort. The camera was capturing all night long. At 2:30AM about half way through the session, there were 7 sub ...
Noise patterns in subframes could relate to white fog artifact issue.
Sep 26, 2023
Large halo around target after stacking
Hi everyone, I’ve taken ~5 hours of 5 min Sii subs of the Pac-Man Nebula with my 130mm refractor and asi2600mm. I ran subform selector in pixinsight with the parameter that eccentricity <7 to filter out the initial bad frames and then blinked the ...
Large halo around target after stacking may indicate similar processing problems.
Aug 15, 2023
EdgeHD 8 - Flat problem on Green and O3
Hi! I'm having some trouble getting my green and O3 filters to calibrate properly. The image attached is an example of what's happening. The image on the left is without flats, the one on the right used flats. Both images were run through Gra...
Flat frame calibration issues could cause white fog appearance in final images.
Nov 10, 2023
